Volkswagen unveils 3 T Cross's for Global markets - EU, China and SA with different styling, dimensions and power-trains
India will get the T Cross as a different version but most likely to similar to the Chinese model.
The T Cross was unveiled in Amsterdam, São Paulo and Shanghai
T Cross, EU Markets: Unveiled in Amsterdam
Dimensions: L 4.11 m, 2.56 m wheelbase
Luggage space: 385 and 455 L.... 1.281 L
Engines:
The new T-Cross has a choice of four turbocharged engines: three petrol and one diesel.
The two 1.0 TSI three-cylinder petrol engines with petrol particulate filter generate 70 kW / 95 PS or 85 kW / 115 PS.
The top model is the 1.5 TSI four-cylinder engine with 110 kW / 150 PS.
Completing the range is a 1.6 TDI four-cylinder engine with 70 kW / 95 PS. All engines comply with the latest Euro 6d-TEMP emission standard.
Delivery : Early 2019
T Cross China : Shanghai (FAW-Volkswagen)
T Cross China : SAIC Volkswagen - Yet to launch
Dimensions: L 4.11 m, 2.65 m wheelbase
Tyre size : The 17-inch rim (tire size 205/55 R17)
Engine:
T-Cross is equipped with 1.5L and 1.4T engines, and the transmission system is expected to match the 6-speed automatic and 7-speed dual-clutch gearbox respectively. Not surprisingly, the car is also equipped with a torsion beam type non-independent rear suspension.
Launch: First half of 2019
T Cross : South American Markets - unveiled in São Paulo
Dimensions: L 4.199 m, H 1568 m, WB 2.65 m
Luggage space : 373 - 420 liters
Tyre sizes - 205/60 R16 and 205/55 R17
Disc brakes on all wheels -The discs will be 276 mm in diameter on the front wheels and 230 mm in diameter on the rear wheels
Engines : TSI
- The 250 TSI Total Flex engine generates power of up to 150 hp (110 kW) with gasoline or ethanol at 4,500 rpm. The maximum torque, also with both fuels, is 250 Nm (25.5 kgfm) - it will be the highest torque in the category. This engine will be combined exclusively with the six-speed automatic transmission with Tiptronic function and shift paddles for steering wheel changes.
-The 200 TSI Total Flex engine develops up to 128 hp (94 kW) at 5,500 rpm, with ethanol - with gasoline, at 116 hp (85 kW) at the same speed. The maximum torque is 200 Nm (20.4 kgfm), with gasoline or ethanol, always in the range of 2,000 to 3,500 rpm. This engine can be combined with the manual or automatic transmission with Tiptronic function
T Cross - India - Launch 2020 ? ( name likely to be changed)
Link + Autohome .CN
