Old 7th May 2008, 14:31   #1231
My swift Diesel:
City between 14 and 16 With A/C
Highway between 16 and 18 With A/C
ravi_28_8 is offline
Old 8th May 2008, 09:38   #1232
khan_sultan's Avatar
Thanked: 5,873 Times
Here's my FE for Palio S10 [2003, 32K Kms]
9 KM/L: [Normal Petrol BP]
Driving Conditions:
- 100% City, Peak Hour, Bangalore [Bilekahalli/Bannerghatta Road/JP Nagar/Mysore Road]
- Daily 40KM driving
- 75% AC
- 80% of the time gear shift @ ~2000 RPM
- 20% of the time fun driving [Read 4000+ RPM]
khan_sultan is offline
Old 8th May 2008, 10:34   #1233
Thanked: 621 Times
Fe
Bolero DI - 300 km highway, 50 km city - 15 - 16 kmpl (non AC)
Indica V2 - 300 km highway, 50 km city - 19 - 19.55 kmpl ( AC 100 %)
Ambassador 1971 - 300 km highway, 50 km city - 15 - 16 kmpl (non AC)
simplyself is offline
Old 8th May 2008, 12:03   #1234
anyone who can post or knows the city / highway FE of a Skoda vRs... Please Post the same!!
If possible differenciate between when it was driven hard and in economy mode.
Need_4_Speed is offline
Old 8th May 2008, 14:35   #1235
How do you guys calculate these figures? Please explain me too...
udit78 is offline
Old 8th May 2008, 14:55   #1236
FE calculation? Did I get the question correctly?
I didnt get the question? I mean simple way is-
Note down Odometer reading (lets call it odo1)after tank-full,
note down odometer reading (odo2) at next fuel stop - fill the tank to the top.
The difference (odo2-odo1) / (litres filled at fuel stop 2) = FE
Just keep in mind your routes and traffic condition
You can keep a notebook with following column heads
Date / Odo reading/ km traveled / liters filled/ average
Record the readings at all fuel stops - rest is pure arithmetic - helps you notice any change post servicing etc.
Rahul
rahuldeodhar is offline
Old 8th May 2008, 15:23   #1237
wanderlustindia's Avatar
Thanked: 63 Times
After I changed from the stock 13"ers to 205/55/15 on my Lancer, the FE has taken a minor hit. I now get around 9.5-10 kmpl (50% with AC and 50% without AC). The highway FE is anywhere between 14-15 (100% AC).
Ford Ikon (Dad drives it now) returns 11 kpl in the city and 16 kpl on the highway.
wanderlustindia is offline
Old 8th May 2008, 15:28   #1238
Thanked: 67 Times
@wanderlust, hope you considered the change in odo readings due to rim upsize. Typically, your FE should improve if you increase the diameter of the wheel (provided that your shoes do not grow much broader). It would be at the cost of reduced low end grunt
Jeep is offline
Old 8th May 2008, 15:31   #1239
Thanked: 63 Times
@Jeep, the stock tires were 175 section, the new Yokos are 205 section. Thats a considerable increase. You are right, the low-end grunt is affected.
Old 14th May 2008, 17:13   #1240
muke31's Avatar
Thanked: 21 Times
Elantra - GLS
City - 9KMPL
Highway - 12-13 KMPL (speed between 100-150Kmph)
muke31 is offline
Old 14th May 2008, 18:28   #1241
Kool_Kid's Avatar
Thanked: 15 Times
Swift VDI 19 KM/PL @ 14000 KM 40 % AC ( City )
Kool_Kid is offline
Old 14th May 2008, 23:20   #1242
rippergeo
Posts: n/a
Pete'd swift VDi- driven reasonably fast with AC on all the time- 18.3kmpl
driven like a maniac- 14.8kmpl
driven decently- 22.3kmpl
Old 14th May 2008, 23:33   #1243
sujitm's Avatar
I get around 10kmpl from Swift VXi (Petrol) in city conditions wo A/C. Is this normal?
sujitm is offline
Old 22nd May 2008, 23:17   #1244
msdivy's Avatar
Thanked: 2,835 Times
One of threads here mentioned that Govt is planning to increase petrol price by Rs 5. Thought I will fill before that happens. Usually between fills there will be a highway drive. But this time it was only city:
Brand: IOC Normal
AC: 100%
City: 100%
Distance: 390.5
Quantity: 30.15
FE: 12.95
Not bad since I travel from South B'lore to Central B'lore & back daily - hardly get a chance to shift to 4th, or hit 50.
msdivy is offline
Old 23rd May 2008, 15:31   #1245
viper_711's Avatar
Thanked: 93 Times
2006 Indica Turbo DLG
routine drive: Banaswadi Road to 80 ft Road Koramangala - about 13 kms one way
Average drive: 300 kms/week - city driving
90% with AC - 10% time smoking!
Aggressive gear changes - especially on inner ring road (@2500-3000 RPM)
Fuel: always from HPCL Banaswadi Road - Turbojet
Method: Full tank to Full tank - auto cutoff
Tyre pressure check every Saturday same fuel pump.
FE: 13.4 (add 3% for odometer compensation because of oversized wheels - Stock 165/65 R14 - Upgrade 175/65 R14)
viper_711 is offline
