Search Forums |
Advanced Search |
Go to Page... |
Search this Thread | ![]() 4,607 views |
![]() | #1 |
Senior - BHPian ![]() Join Date: Jul 2017 Location: Pune
Thanked: 65,602 Times
| Auto Expo 2023: MG eHS plug-in hybrid unveiled MG Motor India has unveiled the eHS plug-in hybrid crossover at the ongoing Auto Expo 2023. ![]() The MG eHS is a mid-size SUV that measures 4,574 mm in length, 1,876 mm in width and 1,664 mm in height. Its wheelbase is 2,720 mm and offers a ground clearance of 145 mm. ![]() The eHS has a large chrome grille up front flanked by LED headlamps. It has a pair of fog lamps surrounded by chrome trim and a skid plate. The rear looks pretty conventional with its wraparound taillights and twin exhausts. ![]() Inside, the eHS gets a 3-spoke steering wheel and a digital instrument cluster, while the centre console houses a floating touchscreen infotainment system. ![]() Powering the MG eHS is a 1.5-litre petrol engine paired with an electric motor. Together, they provide 251 BHP of peak power that enables the car to accelerate from 0-100 km/h in 6.9 seconds. Link to Team-BHP news Last edited by TusharK : 11th January 2023 at 12:20. |
The following 8 BHPians Thank TusharK for this useful post: | AdityaDeane, cl500 di, giri1.8, GTO, InControl, RavenAvi, sunnsood, The Rationalist |
![]() | #3 |
BHPian ![]() Join Date: Nov 2021 Location: Mumbai
Thanked: 86 Times
| Re: Auto Expo 2023: MG eHS plug-in hybrid unveiled Plug-in hybrids may help a few fence-sitters convert to EV mobility, however, it makes zero practical sense not to wholly immerse into pure EV if you are not regularly driving long distances (like >100km per day at least). Yes, plug-in hybrids do score over the strong hybrids though. This MG Hybrid got only a 50km battery range which is minuscule. That means you can never use this for long drives on battery alone and will have to spend heavily on fossil fuels. Today it is very easy to do 500-600km one way (like Mumbai Goa) on a pure EV by making only 1 stop in between (fast charging the battery while you grab some snacks) and spending a total of maybe Rs. 1000-1200. With a car like eHS it will still be >4-5k. Plug-in hybrids with at least 200km range even if it comes with a small underpowered ICE still make some sense. Keep the ICE for extremely rare cases when you run out of battery juice, which in the last 2.5 years of EV life, I never experienced. |
![]() | #4 |
BANNED Join Date: Feb 2005 Location: Melbourne
Thanked: 5,534 Times
Completely disagree with this point. Plug-In hybrid are the worst of both world's - they arent good ICE vehicles and they arent good EV's either. Their fuel efficiency is worse than the same vehicle with the ICE engine once you exhaust the battery since its relatively big and heavy and therefore cannot be charged quickly by the engine which in the meanwhile would also be doing propulsion duties. To get the best out of them, you need to keep them plugged in (and hence the name plug in hybrids), which is very difficult for most car owners given lack of access to a charging port where they park the car. Even if you do, it is a bit of a hassle to do it every time you park. Strong hybrids on the other hand have excellent efficiency at all times with none of the hassles associated with plug in hybrids. In the long term a strong hybrid's battery would last longer as well given their size and the fact that SOC charge is kept between 40-60% at most times while most air cooled plug in hybrid batteries will see degradation to the tune of 30-40% over their life time. https://getjerry.com/questions/what-...gradation-rate |
The following 4 BHPians Thank extreme_torque for this useful post: | ecenandu, Nikhil Beke, pkulkarni.2106, The Rationalist |
![]() | #5 | |
Thanked: 86 Times
| Re: Auto Expo 2023: MG eHS plug-in hybrid unveiled Quote:
1. Pure battery efficiency: PHEVs can be run as pure EVs, especially when you do the usual city office commutes. Most people travel less than 50km per day for work and other chores. They don't need to burn oil, at all. Yes once in monthly weekend day trips are possible with EVs with a decent range (~300-400km), again no fuel burning is needed. The cost of EV commutes is ~Rs 1 per km if you charge at home or ~3-4km if you purely charge outside. It is cheaper than the best hybrids can ever imagine (Camry in city real-world efficiency (Bangalore) is 13-14km/l, which is Rs 8/km. 2. Battery comparisons. Comparing Hybrid and EV/PHEV batteries make zero sense. A typical EV battery is 30-50kWh. MG eHS comes with a 16.6kWh battery. Camry comes with a 1.6kWh battery. 3. Talking about battery degradation, you quoted an article on 2013 Outlander. Outlander PHEV uses a very old battery cooling system. MG, on the other hand, thanks to SAIC and CATL, uses the latest tech and the battery degradation is minimal, <10% over 5 years as claimed in warranty conditions. 4. ICE engine power. PHEVs are not supposed to be driven as pure ICEs. You said it is underpowered, but for MG eHS, the maximum power is 284 HP, maximum torque of 480 N.m. The car is easily hit 100 kph in 6.9 seconds. It doesn't look underpowered to me. Camry makes 206HP, 221Nm. 0-100 in 8.3s Let me reiterate, PHEVs will only help a few fence-sitters convert to EV life. No sensible EV (good brand) user will ever dream of buying a hybrid or PHEV, except may be, if today we get a PHEV with 300km EV range and a decent ICE engine at the price of an EV, which is not going to happen. | |
The following BHPian Thanks doctorjee for this useful post: | wocanak |
![]() | #6 | |||||
By the way Camry can easily deliver between 18-20kmpl. I get approx 14-15 kmpl from my Lexus RX450h, 2.2 tonne SUV with a petrol V6 engine. Quote:
![]() | #7 | |
Thanked: 86 Times
As mentioned by you //a plugin hybrid will only have better efficiency when running less than their claimed EV range compared to a strong hybrid// People who will buy PHEVs will (or should) precisely buy for this use case ONLY. As already mentioned, when the daily commute is less than 50km per day. Do you claim that HEVs are more efficient than in this scenario? This is true for many urban residents of India. We mostly commute between 20-50km per day for work. In the comments section of the YouTube video link shared by you, you will see many such users discussing this, who hardly use the ICE, may be for 5-10% of their total commute per year. One doesn't need to keep the PHEVs plugged in always as mentioned, at least not anymore. They can be charged from 0-100 in 3-4 hrs. It may be true for older PHEVs. Finally the range of Camry is indeed 13-14km/l in urban India. There is a post on this on TeamBHP. https://www.team-bhp.com/news/real-w...y-observations | |
![]() | #8 | ||||
Strong hybrids do not have this problem. They are just highly efficient ICE cars. Quote:
I think I have made my point. Peace out. Last edited by extreme_torque : 14th January 2023 at 05:03. | ||||
![]() | #9 | |
Thanked: 86 Times
