Re: Has Tata removed Rear Wash-Wipe from all Nexon variants? Quote:
Originally Posted by arjab It is possible. Fitting the rear wiper is half the story. Integrating it into the vehicle's control electricals is the other half. And expensive.
- Buy a complete rear windscreen of the top model Nexon which has the wiper hole. You can buy the rear windscreen with the demister should you wish
- Rear wiper and motor is a straight fit as the Nexon's rear hatch inner panel is package protected to accomodate a rear wash/wipe system.
- You have to change the wiper combination switch to that of the top model. Also ensure that the rear wipe/wash wiring loom is connected to the wiper actuation switch
- Install and route the washer pipe and its assorted plumbings to the windscreen washer botlle in front. The windscreen washer motor is common.
- Activate the "smart wipe" rear feature, (basically the rear wiper turns on automatically when the front wipers are on), in the Body Control Module. This will require you to take help from your TML Service Centre, as you would be needing their diagnostic software.
You are good to go.
The cheaper alternative: (Indian jugaadu method)
- Buy the top model's rear windscreen and the rear wiper mechanism. Fit everything.
- Make a direct connection of the rear wiper to a simple manual "on-off" switch, mounted somewhere within your reach on the dashboard.
- Use as and when necessary! |
Nearly cracked up reading this. I know you are writing the truth tinged with humour but sudden removal of features does pose a problem for people like me. I want to buy the Nexon but condition of my bank accounts dictate that the buying will happen only next March/April. If features get removed till then, its back to the drawing board for me.
I hop that this is just a rumour and nothing else |
