Old 13th June 2022, 10:50   #1
tanbeamer's Avatar
Thanked: 683 Times
Fuel pump failures in Hyundai-Kia vehicles with the turbo-petrol engines
In the past few days, there have been quite some instances of fuel pump failing on Hyundai vehicles with the 1.0 TGDi and 1.4 TGDi engines.
No recall has been issued by Hyundai/Kia as of now though which is baffling.
With all these issues cropping up, my personal avoidance of cars from Hyundai and from its sister companies like Kia and Genesis has only become stronger.
A friend has sent the attached pictures.
Fuel pump failures in Hyundai-Kia vehicles with the turbo-petrol engines-whatsapp-image-20220613-8.31.14-am-1.jpeg
Fuel pump failures in Hyundai-Kia vehicles with the turbo-petrol engines-whatsapp-image-20220613-8.31.14-am.jpeg
Requesting all Hyundai/Kia owners with the aforementioned engines to get their vehicles checked at the nearest service centre
tanbeamer is offline   (43) Thanks
Old 13th June 2022, 10:54   #2
Thanked: 23,829 Times
re: Fuel pump failures in Hyundai-Kia vehicles with the turbo-petrol engines
Fuel pump failures, while certainly don’t desirable, will be covered under warranty.
Direct injection turbo petrols are inherently extremely sensitive to fuel quality. Such instances will only worsen once ethanol blending becomes mandatory. Always buy maximum possible warranty for these new high tech cars.
Shreyans_Jain is online now   (33) Thanks
Old 13th June 2022, 16:05   #3
Thanked: 8,348 Times
Attachment 2319870
Attachment 2319871
There is one more N line which broke down in TS owing to fuel pump failure. This cannot be a mere coincidence, this is on the way to become a widespread issue albeit slowly.
Some workshops are aware of this but not making statements in public. Recently an alcazar too was affected in Delhi.
Seems like this is spreading across random petrol BS6 vehicles, probably due to adverse weather conditions with pumps overheating and not supplying enough fuel. In this case the vehicle needs to be parked for 30 mins to cool down and then see if it starts or not. If it starts, well and good, if it doesn't, the vehicle needs to be towed to HASS. In both cases the FIP needs to be replaced.
@tanbeamer, kindly share the photos of the TS car as well.
sidindica is offline   (10) Thanks
Old 13th June 2022, 16:20   #4
tanbeamer's Avatar
Thanked: 683 Times
Here are the pictures of the TS registered car.
Fuel pump failures in Hyundai-Kia vehicles with the turbo-petrol engines-whatsapp-image-20220613-1.59.16-pm.jpeg
Fuel pump failures in Hyundai-Kia vehicles with the turbo-petrol engines-whatsapp-image-20220613-1.59.17-pm.jpeg
Fuel pump failures in Hyundai-Kia vehicles with the turbo-petrol engines-whatsapp-image-20220613-1.59.18-pm.jpeg
Fuel pump failures in Hyundai-Kia vehicles with the turbo-petrol engines-whatsapp-image-20220613-1.59.19-pm.jpeg
Affected car is a grey i20 N line
tanbeamer is offline   (16) Thanks
Old 13th June 2022, 16:33   #5
sunikkat's Avatar
Thanked: 4,197 Times
Wasn't this the issue that Kushaq had too? Fuel pump failure leading to EPC error.
Has the quality of fuel deteriorated so much or are the new turbo engines not able to cope up with the fuel quality?
sunikkat is offline   (14) Thanks
Old 14th June 2022, 06:09   #6
Thanked: 318 Times
This is a serious concern. The manufacturer should probably investigate regarding the issue at the earliest.
Looks like the testing wasn't upto standards as mentioned by other members of the forum on the Skoda fuel pump threads.
Naparajito is offline   (1) Thanks
Old 14th June 2022, 08:30   #7
Thanked: 321,513 Times
Re: Fuel pump failures in Hyundai-Kia vehicles with the turbo-petrol engines
Very concerned with the complexity of these new engines & transmissions (Hyundai-Kia's dual-clutch AT is another topic altogether), and how they are going to fare in the longer run. Extended warranty is a must, yes. But that doesn't cover the gross inconvenience faced with a breakdown. And out of warranty, these turbo-petrol engine components & DCTs will cost a bomb to repair. It's why - if I were to buy a Creta or Seltos - I'd pick the Diesel AT. More robust engine, more robust transmission, good FE even if I drive hard (turbo-petrol FE sinks with throttle input).
Disappointing to see India's no.2 manufacturer grappling with quality issues since 3 - 4 years. Wasn't the case before.
GTO is offline   (54) Thanks
Old 14th June 2022, 08:35   #8
Thanked: 8,508 Times
As far as I remember, the Hyundai Venue and the Grand I10 NIOS have had the 1.0 GDI engine for nearly 3 years now. Even the 1.4 GDI engine has been around for a bit over 2 years now. What has suddenly changed for it to have such issues? Is it manufacturing quality issues due to Covid ? Or is it some ethanol blend related issue which the engine is not able to cope with?
On the topic of the DCT, incidentally, just a couple of days ago I saw a Seltos DCT which had passed me earlier, get stuck in the quagmire of the Chandni Chowk flyover mess at Pune. We literally crawled 30 min or so over less than 500m. And just as we slowly got out of it, I saw that car standing over to the side, bonnet held up, occupants standing next to it all puzzled. I had no doubt it might have been a DCT overheating issue.
fhdowntheline is online now   (22) Thanks
Old 14th June 2022, 09:21   #9
asit.kulkarni93's Avatar
Thanked: 2,970 Times
Quality concerns aren't new with Hyundais. It's not a recent development but has been around for a while. The 1.2 Kappa engine i10s also had fuel pump related issues. Some cars also had a broken fuel pump after crashing into potholes. The fuel pump body would bend. Fuel pump motor related issues in i20s and vernas. The diesel engines have issues around the turbo & head gasket too.
asit.kulkarni93 is offline   (20) Thanks
Old 14th June 2022, 09:47   #10
searacer932's Avatar
Thanked: 1,280 Times
This makes me to tilt more and more towards either a Diesel AT (you still have DPF issues!) or a simple Petrol NA engine mated to a CVT/IVT/AT (preferred)
Even a manual turbo petrol car seems to be a risky buy!
searacer932 is offline   (1) Thanks
Old 14th June 2022, 10:17   #11
And here is an N line with TCU malfunction.
Fuel pump failures in Hyundai-Kia vehicles with the turbo-petrol engines-screenshot_20220614101246387_com.instagram.android_2.jpg
And another blue N line being towed due to FIP issue. So this is the 4th case reported of N line's FIP issue.
Fuel pump failures in Hyundai-Kia vehicles with the turbo-petrol engines-screenshot_20220614101551265_com.instagram.android_2.jpg
sidindica is offline   (21) Thanks
Old 14th June 2022, 10:39   #12
Thanked: 194 Times
Even new Jeep Compass 1.4 petrol automatic are facing fule pump issue and the company is replacing them.
docted is offline
Old 14th June 2022, 10:45   #13
Thanked: 217 Times
Fuel grade and quality could be the culprit. For all turbo petrol engines 95 octane petrol is recommended. The standard petrol available in bunks is 91 octane. Only some Indian Oil bunks have it.
Olympal is offline   (6) Thanks
Old 14th June 2022, 16:23   #14
dhanushs's Avatar
Thanked: 11,470 Times
Um.. Would appreciate more clarity on this. Does the manual say that it has to be 95 octane petrol? If so, for which engines?
It's strange for a manufacturer to sell engines using fuel which isnt readily available.
dhanushs is offline   (4) Thanks
Old 14th June 2022, 20:37   #15
prajwalmr62's Avatar
Thanked: 1,216 Times
Hyundai Venue manual says,
Your new vehicle is designed to use only unleaded fuel having an Octane Rating of RON (Research Octane Number) 91 / AKI (Anti-Knock Index) 87 or higher. (Do not use methanol blended fuels)
Your new vehicle is designed to obtain maximum performance with UN- LEADED FUEL, as well as minimize exhaust emissions and spark plug fouling.
It also mentions,
Do not use gasohol containing more than 10% ethanol, and do not use Petrol or gasohol containing any methanol. Either of these fuels may cause drivability problems and damage to the fuel system, engine control system and emission control system.
Discontinue using gasohol of any kind if drivability problems occur.
prajwalmr62 is online now   (6) Thanks
