Old 2nd May 2023, 15:47   #166
condor's Avatar
Thanked: 16,847 Times
Re: IndianOil rolls out green fuel "XtraGreen" at 126 Fuel Stations across 63 cities in India
Originally Posted by autoweirdo View Post
Has anyone tried Green diesel in Harrier/Safari BS6 car? How is the experience post using the same. Currently I am using Reliance Diesel and feel the response is better compared to other Diesel at IOC/HP/BP.
BS6 diesels can see more benefits than with BS4. Try it out. Even cabbies are going for BS6, as told by a pump attendant.
condor is online now   (1) Thanks
Old 3rd May 2023, 01:07   #167
Thanked: 162 Times
Thanks Condor for giving confidence, I have long trip planned during mid May and have mapped XTRA Green Diesel bunks in GMaps with help of IOC app. Will update the experience on completion of trip.
autoweirdo is offline   (1) Thanks
Old 21st May 2023, 14:45   #168
d3mon's Avatar
Thanked: 4,823 Times
Originally Posted by shibujp View Post
I had the same question whether xtraGreen diesel works fine for high end cars like BMWs.
Drive on, Shibu
I tried xtraGreen in both my cars.
1. 530d
No perceptible change. Refinement was great to begin with, so there wasn't much room for improvement. I don't have a fixed commute to monitor the FE, so can't comment on that either. And there was no change in power felt, although I think the power /torque guages in the car did show a minor improvement sometimes.
2. Amaze iDtec.
Since this Honda 1.5 was one of the most unrefined diesel mills sold in India, there was a huge scope for improvement. And the xtraGreen does deliver! Immediately after filling up from an empty tank, there was a substantial reduction in NVH. It doesn't take any time to deliver the benefits as it's not cleaning the injectors or anything. Even with liqui moly diesel additives it doesn't run as smooth as it does on xtraGreen.
I was initially ready to write off xtraGreen after my experience in the 530d, but after trying it in the Amaze, I'll be sticking to it for sure. The higher cetane number is definitely going to help even if some of the differences may be hard to perceive. The ~5 percent extra cost is fully justifiable in my opinion.
d3mon is offline   (5) Thanks
Old 16th June 2023, 17:01   #169
Strykar's Avatar
Thanked: 36 Times
Would XtraGreen fuel be worth trying in a 2011 3.0L D4D Fortuner?
I usually ad 110ml of Amsoil Cetane booster to a 80L tank full.
Strykar is offline   (1) Thanks
Old 17th June 2023, 20:44   #170
el lobo 6061's Avatar
Thanked: 2,400 Times
Only if your car engine is compatible with Bio-Diesel 7% B7. Check manual.
Else you will damage engine & fuel injectors.
el lobo 6061 is offline
Old 17th June 2023, 20:45   #171
scorpian's Avatar
Thanked: 1,297 Times
Definitely,please go ahead with it.
I usually do two tankfulls of extra green then go back to normal for two tankfulls.
scorpian is offline
Old 19th June 2023, 18:06   #172
Strykar's Avatar
Thanked: 36 Times
That was my concern, manual does not state anything about bio diesel or B7, just that it needs diesel with cetane 48 or higher.
Strykar is offline
Old 19th June 2023, 19:19   #173
Sahil's Avatar
Thanked: 7,999 Times
What’s the difference between XtraGreen and Turbojet in terms of cetane level?
I have found a bit better performance from turbojet compared to XtraGreen.
Sahil is offline
Old 19th June 2023, 22:53   #174
ike
ike's Avatar
Thanked: 1,992 Times
I used 2 tankfuls of xtragreen in my BS6 Harrier, the engine definitely runs smoother compared to regular diesel. Did not find much of a difference in throttle response/economy. I will use it again however it's not available widely in my hometown(where I'm currently) so the monthly Chennai trips will see the car getting Xtragreen.
ike is online now   (1) Thanks
Old 20th June 2023, 01:14   #175
ant_vas's Avatar
Thanked: 785 Times
Any specific reason for following this practice?
ant_vas is offline
Old 20th June 2023, 06:50   #176
mtnrajdeep's Avatar
Thanked: 403 Times
I was using XtraGreen in both XUV and Elantra. In both the cars, increased engine noise was observed after 4-5 months. This noise gradually subsided once we switched back to normal diesel. So, now, I use Addon diesel additive with normal diesel instead of XtraGreen.
mtnrajdeep is offline
Old 20th June 2023, 07:36   #177
scorpian's Avatar
Yes i find the engine becoming coarser with continued use of extra green.
So i switch back to normal diesel in between.
I am using extra green just to keep all items like injectors clean and less carbon build up.
Just saved me the headache of measuring addon d and adding it every tank ful,sometimes it's just not possible.
scorpian is offline   (1) Thanks
Old 20th June 2023, 11:00   #178
ant_vas's Avatar
Thanked: 785 Times
Thanks, guess I will also try normal diesel next couple of times as my Carens feels noisy off late and probably I got used to the improved pickup, so can't feel the difference now
ant_vas is offline
Old 20th June 2023, 11:04   #179
Thanked: 93 Times
I stopped using XtraGreen in my Carens. The pickup did increase but the car was jerking a lot.
ImranHyd is online now   (2) Thanks
Old 21st June 2023, 23:41   #180
Thanked: 162 Times
Based on inputs I went with xtragreen for my recent trip between Pune Bangalore. Indian Oil app helped to identify outlets with xtragreen diesel. Had 2 tankfuls and following is observation:
1. No significant increase in mileage, got approx 16kmpl
2. Throttle response better than normal diesel and at par with Jio diesel
3. Not much difference in engine noise, but my car is hardly run 14k so kind of still new
Currently Jio diesel is priced at par with normal diesel so still first preference will be Jio diesel, but xtragreen is definitely better option than normal diesel.
