Closed Thread
Old 14th February 2022, 11:28   #196
Thanked: 260 Times
re: 2022 Maruti-Suzuki Baleno, now launched at Rs. 6.35 lakh
2022 Maruti-Suzuki Baleno, now launched at Rs. 6.35 lakh-2022marutibalenowhitetvcshootnew1.jpg
Looks like Top end model, but there is no sunroof?.
r-a-s is offline   (2) Thanks
Old 14th February 2022, 11:51   #197
Leoshashi's Avatar
Thanked: 43,468 Times
Yes Baleno won't get Sunroof as far as I know. Brezza will.
Leoshashi is offline   (1) Thanks
Old 14th February 2022, 12:09   #198
Thanked: 5,458 Times
Fake image. Compare that to the actual spy image side by side. Reflector is of different size, extension of tail lamp into the rear door looks different on both sides! A cheap paint job.
romeomidhun is offline   (5) Thanks
Old 14th February 2022, 12:28   #199
CEF_Beasts's Avatar
Thanked: 20,101 Times
Is it possible that the white car with the camouflage is the updated Glanza?
The lower part of the bumper which houses the fog lights and lower air dam is different than what was seen on the Baleno spotted earlier.
Even the main grill looks different, seems like it has a grill similar to the Camry, the distinct shape under the camouflage.
And a 360 deg camera also gets confirmed with these spy shots.
2022 Maruti-Suzuki Baleno, now launched at Rs. 6.35 lakh-7626bc68742443dd8e5f65219fdaa1fb.jpeg
CEF_Beasts is offline   (9) Thanks
Old 14th February 2022, 12:42   #200
Thanked: 78,243 Times
2022 Maruti Baleno 360 view camera teased
2022 Maruti-Suzuki Baleno, now launched at Rs. 6.35 lakh-273928349_10158560135277727_1291908940199253512_n.jpg
2022 Maruti-Suzuki Baleno, now launched at Rs. 6.35 lakh-273996625_10158560135272727_6827522087294671100_n.jpg
Link
volkman10 is offline   (9) Thanks
Old 14th February 2022, 13:13   #201
Thanked: 260 Times
Yes, I too doubt that. Alloy wheel design also different compared with previous spy shots.
2022 Maruti-Suzuki Baleno, now launched at Rs. 6.35 lakh-imgonlinecomuatwotoonehighlzdzdqslbm-1.jpg
r-a-s is offline   (7) Thanks
Old 14th February 2022, 13:49   #202
With two photoshoots going in parallel, the white car is likely the Toyota Glanza while the Red could be the Baleno.
volkman10 is offline   (6) Thanks
Old 14th February 2022, 18:19   #203
Agarwal_Aayush's Avatar
Thanked: 258 Times
Both have the same alloy design, so either its the same cars photoshoot happening or could Maruti be giving a different front bumper and alloy design for rumored 1.5L version just like RS had different bumper and color of the alloys?
Agarwal_Aayush is offline
Old 14th February 2022, 18:28   #204
NiInJa's Avatar
Thanked: 4,628 Times
The LED DRL in this masked picture is a L shaped line whereas official teaser images show 3 square blocks of LED. I wonder if this is a different version or the Toyota Glanza.
NiInJa is offline   (1) Thanks
Old 14th February 2022, 18:59   #205
Attachment 2272543
Anyway, using such kind of camouflages, they clearly agree that only front and rear have changed, and not much in other areas.
Old 14th February 2022, 19:25   #206
Leoshashi's Avatar
Spied undisguisedName:  IMG20220214WA0027.jpg
Leoshashi is offline   (49) Thanks
Old 14th February 2022, 19:39   #207
WR-V-type rear lamps.
Seems like the curvy surfaces on the side is replaced with straight lines. Also, the doors now are extending into the panel above.
romeomidhun is offline   (17) Thanks
Old 14th February 2022, 21:46   #208
The New Age Baleno with 360 View Camera:
volkman10 is offline   (14) Thanks
Old 15th February 2022, 07:39   #209
Variant spread of the updated Baleno:
The new 2022 Baleno will only be offered with one version – the one with mild hybrid tech. It will be powered by 1.2L K12N petrol Dualjet with 12 V mild hybrid technology.
Power output is rated at 66 kW or about 89 PS at 6,000 rpm. Gross Vehicle Wt (GVW) of new Baleno is 1,410 kgs. Wheelbase is 2520 mm, Width is 1745 mm, length is 3,990 mm and height is 1,500 mm.
2022 Maruti Suzuki Baleno will continue to be offered in the same four trims of Sigma, Delta, Zeta and Alpha. These will be further divided into 11 variants – 6 in manual and 5 in AMT automatic.
2022 Maruti-Suzuki Baleno, now launched at Rs. 6.35 lakh-2022marutibalenovariantsspecsengineleak3.jpg
Link
volkman10 is offline   (12) Thanks
Old 15th February 2022, 07:40   #210
Dr.Naren's Avatar
Thanked: 17,276 Times
Gross vehicle weight is 1410 kg. It was 1340 kg before. Maruti did improve the build and 70 kg is substantial
Dr.Naren is online now   (21) Thanks
Closed Thread
