Originally Posted by TROOPER Finally! Took delivery of our Hexa XT 4X2 June 2019 Make last evening.
Dealer is Inderjit Cars, Mira Bhayandar.... |
So we've been having quite a roller coaster of an ownership for the past two weeks.
Grab your popcorn, it's going to be long.
Delivery evening: Had told the SA during PDI to iron out some issues. As expected he didn't bother. These were minor stuff only Bhpians would notice. So I didn't make a scene for that.
Later on D Day: Was excited. So went for a drive alone around 10.30 pm. Air con off and no music. Windows rolled down. Everything is great. Hit a patch of rough road and I hear some squeaks from the dashboard! You have to roll up the windows to hear it. I try to ignore. Thinking its a figment of my imagination. But no, it's there. Even on undulating roads, not just bad roads.
Day 3: Spray WD 40 on door handles and they smoothen out. On hinges too. They're smoother now.
Day 4: Go for a 70 km drive. Notice a heartbeat feeling while depressing the clutch. (Rogue flywheel?)
Day 5: Have a chat with the GM of Inderjit TASS. He asks to come over. Prepare to leave for TASS to fix the squeaking issue. Start the car and the drive mode selector lights up like a christmas tree. Check engine light is on! Drive over to TASS. No issues with the power delivery on the way. The GM says we just need to reflash the ECU. And it works. Then they check the suspension and find the right suspension bush to be rubbing against the chassis. That was the squeaking! They realign it. Squeaking gone. There's a rubber stopper on the concealed portion of the wiper cowl. The left one was missing. I pointed out the same and they had it in stock! I asked to update the ICE. It was Jan 2019 version. And the GM point blank says that's the latest. I wonder how's that possible considering the 7 inch ICE was introduced in March 2019. Have a chat with SA about the clutch and he says everything's fine. The service was 8/10. God knows where these guys were during PDI. Well, either no PDI was done (obviously) or the management and technicians changed overnight.
Day 8: We leave for Mangalore. Have planned a halt at Honnavar. Everything is fine till we reach Khambatki (Satara) Ghat. I start hearing a faint rattle. Now the problem is, the cabin is so silent, you could hear a dog fart from outside the car if the engine is running below 1700 rpm. So I try to ignore it. We stop for refreshments and I restart the car. Android auto is malfunctioning. I 'flick' the wiper stalk and only water jets come out and no wiper movement. Go ahead for a Km. Restart the car. NO. Wipers won't budge. Same with the rear wiper. They do move when you flick the stalk in the single swipe mode. The rattle is irritating in the meantime. I stop, get out and it sounds scary. Turn off the car. Wait for a couple of minutes. Restart, rattle gone. Now we drive another 500 kms without any sounds. Just some slight sound from the front right suspension. But you'd have to work your ears hard to hear it.
Day 9: Start off at around 6.20 am. Fill up the tank. Distance covered is 840 kms. Mileage is 15.4. We're content and impressed. Not bad for a 2.2 ton truck. Start the car post filling gas. And there's a faint screeching sound on start up. The rattle is back! Go a couple of metres ahead. Turn off the car. Wait for a minute. Start the car. No drama during or after cranking. We move on. Attend a function. Turn the ignition and nothing. I pray to the Gods. A couple of relatives are seated. Wait for a minute. Crank again, it starts without drama. We move on.
Day 10: Go to Kateel temple. Get pooja done. Move on to Tass here in Mangalore. Tell them about the wiper issue. And the SA pulls on the wiper and the wipers are in action! So I was flicking the stalk for a second or two and letting it go (like I used to in the Dzire). So the wipers wouldn't budge. Apparently you have to pull on the stalks for over 3 seconds and then the wipers spring in action. They update the ICE to the latest version. Nothing special. March 2019 version. Experience 10/10.
Day 11: Leave for our native village from Mangalore. Couple of relatives in tow. Halt at a spot to pick up a relative. Turn off the car. Relative comes after couple of minutes. Try starting the car. Won't budge! Starts in the 4th attempt. Uneventful day post that. Just relatives raving about the build and ride. Little did they or I know about the impending issue.
Day 12: Relatives are gone. We stay back at our ancestral home. I start discussing the starting issue with my dad. Our plan was to leave for Mumbai within 3 days from our native village. We try starting the car, hoping to hear that cameoing screech. Screech is heard and car doesn't start. Car finally starts in the 4th attempt. We decide to take the car back to Mangalore TASS the next day. Call them up and SA tells to have a chat with RSA. We call up RSA and 2 chaps turn up within 45 mins! They try starting the car. Their boss is on the phone. They immediately deduce that the starter motor has conked off.
![Shockked](https://www.team-bhp.com/forum/images/smilies/Shockked.png)
They also say there's a chance of the flywheel being a collateral damage. RSA service 10/10
Day 13: I pray while cranking and the engine fires up on first attempt. We go to Mangalore. Drop the car at TASS. SA tells the same. Starter motor has conked off. Gives us a heads up that don't expect the car for the next 5-6 days
parts need to come from Pune.
Day 14: We revisit TASS. SA tells there's slight damage to the flywheel. Both would be replaced and they're awaiting approval from TATA.
So two weeks and the car has almost spent 2 full days at TASS. Will be there for the entirety of 3rd week too I guess.
It's just irritating. How can a starter motor fail so early? Or is it the flywheel which was rogue leading the starter motor to conk off? I don't know what the guys in the factory are upto. Our car is a June 2019 make and there's none of those speed limit chimes and indicators. As much as I don't want them, makes me wonder what else is missing. Our SA told he'll update the ECU to the latest version before delivery.
The whole experience has been a mixed ball. For all the flack TASS gets, its TASS and RSA that have stood out (until now) and the product (factory finish) which has faltered. For now, I would rate the factory work, QC & PDI a -10 and TASS & RSA a +8.
Product issues:
Suspension squeak : Resolved
Faint unknown noise from front right side of suspension on bad roads : Unresolved
Fitment issues - Instrument cowl, panel beneath steering rack, HMSL cover panel : Unresloved
Starter motor & Flywheel replacement : Underway
Product Pros:
Efficient highway cruiser
Solid build
Presence
Comfort
Ride quality (subject to tire pressure on extremely bad roads) You could discredit the Hexa's ride quality as overrated. Even I am guilty of that. But that is only till you notice how much other vehicles slow down over bad patches and you are flying over.
Would like to thank bhpian ram87pune, and the THOR groups in helping to hold on to my sanity in this roller coaster of an ownership period.
