Originally Posted by Dippy I was at the dealership during the launch and I got a 7 km test drive immediately after launch. Drove the petrol CVT. The rubber band effect of the CVT kills the performance and I still prefer the torque converter of my 2012 Civic any day. The interior though loaded with features is typical Honda. The hard plastics on the door pads really felt cheap and so did the door locks inside. Either Im nitpicking too much or Im spoilt by the quality and build of my GT TSI. |
I kind of get what you're feeling, my experience with automatics has been extensive over the past 2 years or so.. apart from the 6 speed torque converter I'm used to driving, I've driven DSG (Audi Q3 2.0 TDi), 8 speed torque converter (ZF BMW 2.0 520d), City (1.5 CVT), Corolla (1.8 CVT), DSG (1.2 Polo Tsi). If you look at this lot close enough, my right foot has plenty of experience given the combination of engine+fuel+gearbox which are completely unique to each other.
Of them, and this may come as no surprise, CVTs do come last in terms of feeling of movement.. I don't know which analogy comes close but lets say that we love the tactile feel of cranking the car window open manually, churning the handle one circle at a time, knowing how much the window goes up/down with each crank and we can push/pull faster to achieve quick results.. and then there is CVT which is like a power window, you push/pull the button and hold it as the window moves up/down linearly and efficiently.. this may be ever so slightly boring because it is too linear and any visceral feel is completely cut out due to the predictability.
In torque converters there is a sense of that visceral feel, if you want that quick overtake you pump and you double pump the pedal, watch as the car changes gears and achieves required effect and shoots the RPM up. DSGs like torque converters, have a small issue of grunting when changing from 1 to 2, a reluctance so to speak but all the other gears sync perfectly with the revs (almost) and leads to a sensation of quickness.
Its not always about 0-100 timings, or how efficient the performance is, we as human beings sometimes seek emotional responses from the car, an indication that the pistons and chambers are mating. Clearly from a performance stand of point, the Q3 with DSG and 2.0 engine (AWD) should 'feel' fast, but it doesn't.. the BMW 5 felt much quicker (RWD layout) despite almost all things similar. The torque converters shouldn't feel as fast as a DSG either but depending on the engine its mated to, and given a smooth, uninterrupted path even the TC will perform to the max. The only problem with TC is that it doesn't like constant shifting up/down and torque is lost in the process.. this is where DSG's shine.. where the double clutch synchros with every rev-point, matching it to the most ideal gear.. like a self-lubricating bearing. The only caveat to this is you should drive like yourself every time to have the perfect telepathic connection, meeting the car half-way as it is a learning unit.
The CVT is just that, a continuous variable transmission, where everything is smooth, non-jerky, predictable and linear. It needs constant input and zero expectations.. it just chugs on. That feeling of the unit dropping gears, revs falling, that sudden lunge at low speeds.. that will be missing. As I said the game going forth is no longer about massive speeds, reaching A-B in record breaking time or having rubber bands for tires. Feel is everything.
But I digress, the CVT in the City is mostly not enjoyable.. the Corolla was better because it has much better ride quality and gels with the CVT perfectly as its a cruiser. Big engines suit the CVT better though as the inherent power and torque should make it ever so slightly better than a small-engined CVT, so the Civic should definitely be better than the City, but for the few of us who want that viscerality, it is an absolute no go.
Better than expected pricing BTW, just as expected.. below the Europeans, above everything else.
