re: Why is Hyundai stubbornly not launching the Elite i20 Automatic? EDIT: Launched at 9.01 lakhs! Quote:
Originally Posted by himanshugoswami This engine GB combo was present in the Gen 1 i20 as well and it was pathetic to say the least- neither was it efficient, not fast. hence it died a well deserved death. | Quote:
Originally Posted by blackasta The Gen 1 i20 1.4L engine was non VTVT if I seem to recall correctly.
Not that it makes much of a difference though.
A car like i20 deserves a better GB than the old 4 speed one coupled with 1.4 L VTVT engine that seems to be on offer. |
No, my friends, this engine-gearbox combo was NOT available on the earlier generation i20! Don't get mislead by the 1.4 litre capacity and 100 PS figure. The two engines are completely different!
The previous generation i20 AT had the 1396cc Gamma VTVT engine. This current i20 will get the newer, all-aluminium 1368cc Kappa Dual VTVT engine. As I've said it before many times, the horsepower and torque figures may be about the same, but the two engines are different. Period!
I expect the 1368cc Kappa to be more refined (especially at higher rpms) and also a bit more fuel efficient than the earlier 1396cc Gamma motor.
A 1.4 petrol motor coupled to a 4-speed AT may not be that fuel-efficient. Agreed. But slow? Ha! Let's see what GTO had to say in his review of the earlier generation i20 AT (1396cc Gamma): Quote:
Originally Posted by GTO The 1.4L Automatic
The i20 Automatic gets a 1.4L petrol engine with 99 BHP (@ 5,500 rpm) and 136 Nm of torque (@ 4,200 rpm).
Start the engine & the supremely refined idle is immediately apparent. Shift the gear position into D and your left arm / leg can relax away to glory. Throttle response from 0 kph is excellent, thanks to the conventional torque converter gearbox. Piloting the i20 AT within the city is an effortless exercise, and engine noise is barely audible under a regular driving style. The 1.4L engine overall feels far peppier than the 1.2L MT, even with the automatic gearbox. For the times that you want to suddenly close that gap in traffic, the gearbox does take a moment to respond, yet it’s nowhere as lethargic as the Vento AT (as an example). This is definitely not a gearbox I would call lazy, with the kickdown response time being reasonably good. Spend a couple of kms driving the i20 AT and you’ll get completely accustomed to the engine & gearbox characteristics. You'll even learn how to press the accelerator just that much to invite a downshift. The light steering adds to the manoeuvrability factor...you can dart in & out of traffic with ease. I found the otherwise chaotic Mumbai evening traffic a breeze to tackle with the i20 AT. The engine upshifts early, at anywhere between the 1,750 – 2,000 rpm mark within the city. At 50 kph, the 1.4 is spinning over at a mere 1,500 rpm in 4th gear. With a light foot, the experience is very seamless, smooth and stress-free for the driver as well as passengers.
100 kph cruising speed has the rpm needle hovering at 2,600 rpm. With 99 BHP on tap and a fairly competent autobox, you can make fast progress on the expressway. In a pedal to the metal driving style, the gearbox will upshift at 5,800 – 5,900 rpm. The i20 has noticeably more muscle than its 1.2L sibling and can reach high speeds effortlessly, still having grunt for more. Yep, the i20 AT will pleasantly surprise you on the expressway. In L, 2 and O/D off modes, the engine will revv to a max rpm of 6,500 in the 1st, 2nd and 3rd gears (respectively). No issue with the brakes as the i20 AT gets disc brakes on all 4 wheels. This is a welcome move, more so in an automatic car.
As the rpm needle rises however, the 1.4L engine feels a generation too old compared to the 1.2L Kappa2 / VTVT series. It sounds quite unpleasant at 4,000 rpm, while the motor throws out an annoyingly boomy sound over 5,000 rpm. Noise aside, the 1.4L throws out no vibrations, even at 6,000 rpm. |
I expect the newer, all-aluminium 1368cc Kappa motor to be much more refined at higher rpms than the earlier 1396cc Gamma. So the noise factor mentioned above shouldn't be an issue on the new i20 AT.
The Polo GT TSI with its 105 PS 1.2 litre turbo-petrol & 7-speed dual clutch transmission may be in a different league altogether, but I'll choose a 100 PS 1.4 litre motor coupled with a 4-speed torque converter over the two 80 ~ 90 PS 1.2 litre engines mated to screaming, whiny, noisy, rubber-bandy CVTs any day!!!
