Audi has finally revealed the Audi A5 coupe internationally at a media presentation held at its Ingolstadt headquarters in Germany on Thursday,5th June 2016.
The car is set to go on sale later this year and has a two door body style.Some of the styling elements seem to have been borrowed from the outgoing model,while others are a lift from the new generation of Audis.
The car gets a new grille,similar to the current gen Audis and also gets the new Audi matrix LED headlamps,similar to the ones seen on the new A6.The wheel housing is now larger and the rear bumper has been tweaked along with the addition of sharper tail lamps.
Although the styling might look similar to the outgoing car,the A5 is based on the new MLB platform,which underpins the new A4.This means that the A5 has the same wheelbase as its four door sibling,the A4.The use of aluminium has helped to reduce kerb weight by around 60 Kg.
The interiors look very similar to what are offered on the newer A4.The layered dashboard and virtual cockpit,with its 12.3 inch High Definition instrument cluster are the standout elements in the cabin.The cabin quality and feel of the plastics is similar to that of the outgoing car.
These are the technical specifications for the car
Petrol-
2.0 litre EA888 producing 190 BHP or 251 BHP depending on the state of tune and mated to a six speed manual or seven speed DSG gearbox
Diesel-
2.0 Litre EA288 producing 190 BHP and mated to a six speed manual or seven speed DSG gearbox
3.0 Litre 6 cylinder producing 218 or 272 BHP depending on the state of tune.The 218 BHP variant is paired to the same six speed manual and seven speed DSG as the other 4 cylinders pots,while the 272 BHP version gets Audis quattro all wheel drive system as standard and comes mated to an eight speed automatic with paddle shifts.
Underpinning the new A5 Coupe and its S5 Coupe sibling is a newly developed chassis featuring optional damper control and a variable-ratio electromechanical steering system, as seen on the A4 sedan.
While Audi revealed the new A5 Coupe, the manufacturer has imported its four-door Sportback sibling to India with the model spotted testing. The new Sportback is expected to be revealed globally at a later stage. As of now, there is no news if the new A5 Coupe or its more powerful S5 sibling will head to India. Audi currently offers the A5 in India in the form of the fully imported S5 Sportback.
The A5 will be positioned above the A4 IMO but will cost less than the A6 and will also offer less space.Can I call it a performance A4?
![Big Grin](https://www.team-bhp.com/forum/images/smilies/biggrin.png)
Source-autocar India
