Re: Maruti to introduce idling start/stop tech to increase fuel economy Quote:
Originally Posted by Motard_Blr This is similar to my Samsung fridge which has a blue substance in a container in the freezer that slowly absorbs heat and melts during a power failure. This helps keep foods frozen much longer than in a normal freezer. |
Have it in mine too. Saved the pack of sausages a few times! Quote:
Originally Posted by GTO Must say that eco-cool tech is pretty....well, cool. One of the two major disadvantages of a start/stop system is losing the air-conditioner when the engine switches off. Imagine sitting in the sweltering heat! | Quote:
Originally Posted by GTO Among the many cars that we've tested with the start / stop system is the 328i. BMW couldn't achieve a seamless experience, thus I'm wondering if Maruti could: |
I recently went on a round trip from Bangalore to Chennai, then Pondicherry before returning to Bangalore in a Zoom XUV500. This was a W6, and while there is quite a long list of things that were wrong with that car (I got it at 736kms, almost brand new), the one thing I did like was the Start/Stop feature.
I didn't need to save fuel, but generally thought it a waste to idle the vehicle unnecessarily. It is very useful in city, especially at traffic lights. I also found that there is some intelligence built in - apparently it has a delay between Start and Stop, so it doesn't shut down in stop-start traffic conditions (after an initial start, of course).
The AC did switch off along with the car though, so I deactivated the feature when driving around in Chennai
I read recently of a breakthrough where the simple alignment of some material via electric impulse can be used as the "condensor" or heat/exchange element, while consuming very little power. It is also significantly less complex, eliminates the compressor and hence removes a significant mechanical load from the engine.
Maruti's setup sounds to me like a very good, low cost alternative until newer technologies that do not rely on gas/compressors become more efficient and affordable. It will be less efficient when the engine is running as the AC will need to keep the gel cold along with the interiors. |
