▲ Go to Top ▼ Bottom
Old 16th July 2018, 09:13   #1051
hserus's Avatar
Thanked: 9,319 Times
Re: 2014 Ford Fiesta Facelift : A Close Look
Originally Posted by VKS View Post
Anyone got the Fiesta battery replaced ? All the battery in the market seems to be 242*175*190 for 60AH, while the battery bay in fiesta is for 242*175*175
This is what I have in my fiesta - a din 65 battery and it seems to fit just fine.
http://www.batterybhai.com/car-batte...90/40/2/1/65/1
2014 Ford Fiesta Facelift : A Close Look-1image.jpg
hserus is offline   (1) Thanks
Old 16th July 2018, 11:26   #1052
VKS
Thanked: 26 Times
Thank you very much, will more AH battery create any issues for other electronics ( alternator and all) , Fiesta seems to be loaded with electronics.
VKS is offline
Old 16th July 2018, 13:44   #1053
hserus's Avatar
No issues with a higher ampere-hour battery. Go ahead.
hserus is offline
Old 17th July 2018, 15:47   #1054
Thanked: 386 Times
EGR cleaning every 30k km? That is some Maruti dealer’s idea of a scam. Injector / EGR issues usually crop up well after 80k.
Just checked with some informed guys in FORD, EGR valve doesn't require cleaning in Ford diesel vehicles.
vaasscit is online now
Old 17th July 2018, 18:01   #1055
tharian's Avatar
Thanked: 8,628 Times
Well, they would need to be cleaned at some point, just that it wouldn't be every 30k kms.
tharian is online now
Old 18th July 2018, 08:05   #1056
Thanked: 386 Times
That "some point" is exactly what i was trying to find out. But Fiesta's service manual doesn't mention EGR cleaning anywhere till 1,60,000kms service recommendations.
2014 Ford Fiesta Facelift : A Close Look-fiesta_servicemanual_snapshot.jpg
Old 18th July 2018, 08:17   #1057
tharian's Avatar
Since it is not mentioned in manual, I would suggest going by the cars mileage. (kms run)
Usually, EGR cleaning happens nearing a lakh kms.
Old 19th July 2018, 23:41   #1058
VKS
Thanked: 26 Times
Thank you, I got the Amaron battery today. It is the 65 AH Amaron Flo series.
VKS is offline
Old 10th August 2018, 09:49   #1059
Thanked: 386 Times
Folks,
Has anyone installed arm rest in your fiesta ? I'm traveling a lot off late during weekends and the missing arm rest is taking a toll on the shoulders.
Looking to buy one in a local shop in Coimbatore. Any advice/suggestions would be most welcome.
Old 10th August 2018, 09:52   #1060
hserus's Avatar
Folks,
What I got is a broad memory foam neck pillow. It supports the shoulders very well indeed. And note that the seatbelt is height adjustable. Getting a third party armrest would very likely interfere in your changing gears so don't use that.
hserus is offline
Old 10th August 2018, 10:42   #1061
Thanked: 386 Times
Thank you. I'll then drop the idea.
Old 10th August 2018, 11:48   #1062
ank.nsit's Avatar
Thanked: 326 Times
What I got is a broad memory foam neck pillow. It supports the shoulders very well indeed ...
Something like this -
https://www.amazon.in/dp/B01BMCF7ES/..._K2sBBbC4542E4 ?
ank.nsit is offline
Old 10th August 2018, 12:00   #1063
hserus's Avatar
Originally Posted by ank.nsit View Post
This one
http://s.aliexpress.com/qMVfm6ru
And a similar piece on Amazon
Gigi (G-1603) Gigi Memory Foam Car Neck Pillow Car Headrest,Head Pillow,Rest Pillow,Protect Neck (Black) https://www.amazon.in/dp/B07D3269PF/..._UdtBBb0A20734
Old 8th September 2018, 21:28   #1064
itsashishsharma's Avatar
Thanked: 983 Times
Guys my Fiesta has a vibration since I crashed into a speed-breaker at high speeds. The car didn't just jump over it, it literally crashed. It was horrible. I am guessing some engine mount might got broken. Service centre says vibration is a common issue in new/global Fiesta. They have been unable to assess the root cause. What do you guys suggest?
itsashishsharma is offline
Old 9th September 2018, 05:46   #1065
hserus's Avatar
Just to start with get the tyres rotated, aligned and balanced at some good tyre shop - and while it's raised up for these checks examine the car underbody thoroughly - including whether brake pads / discs are touching the wheel at some angle. Then try to suspect engine mounts and suspension after that.
Vibration isn't all that common in the global Fiesta I am not sure why your SA said that.
hserus is offline
