Team-BHP > Team-BHP Reviews > Indian Car Dealerships
Old 25th August 2013, 19:23   #166
Thanked: 37 Times
Re: Maruti Swift Servicing at 20,000 KM
Originally Posted by Grr7 View Post
Okay, so I wish to share whatever information I could decipher from M.A.S.S guys:
This is the first time I have been charged for Oil drain. Coolant they have definitely undercharged. I had told them not to do any wheel balancing or alignment as I have done it couple of months back. For other charges I think its ok. I need to ask them why they changed Cons and charged for Oil drain.
Thanks for the information.
Naturalist is offline
Old 18th May 2014, 12:38   #167
lone_driver's Avatar
Thanked: 135 Times
My Swift Zdi went in for the 20k service a couple of weeks back .
I am posting the bill Breakup for the advantage of fellow BHPians.
Gear Oil - 901.18
5W40-MGO Engine oil - 2228.09
coolant - 234.99
Brake Fluid - 75
Service kit - 1810
brake callipers - 430.02
labor charges :
Paid Service - 735
total - 6414 + taxes
lone_driver is offline   (1) Thanks
Old 18th May 2014, 16:51   #168
Captain Slow's Avatar
Thanked: 2,047 Times
Gear Oil - 901.18
coolant - 234.99
Brake Fluid - 75
Service kit - 1810
labor charges :
Paid Service - 735
What is the Service Kit at R- 1810 ?
Captain Slow is online now
Old 18th May 2014, 17:55   #169
Thanked: 135 Times
Service kit includes all the filters .
Air filter
Diesel filter
Oil filter
Sent from my iPhone using Team-BHP
Old 18th May 2014, 19:31   #170
Thanked: 1,902 Times
How many litres? This seems very high.
carboy is offline
Old 18th May 2014, 19:40   #171
Thanked: 135 Times
3.3L
Even I thought so .. But they showed me the me oil can .. And this is the printed MRP .
The Service centres that use Big oil drums to fill oil in d car do it at a cheaper rate . Around Rs. 1860
Old 18th May 2014, 19:51   #172
Thanked: 21,423 Times
MGO 5W40 @ 2300 bucks is cheap IMO or am I missing something.
The Swift engine oil capacity is 3.1 litres so going by the grade it seems to synthetic oil. I had done my 10K service recently if my Swift ZDi where I was charged Rs 1008.67/litre so it us approximately Rs 3026 for 3.1 litres.
Anurag.
a4anurag is offline
Old 18th May 2014, 20:02   #173
Thanked: 135 Times
Anurag.
You may have been charged for the 0W40 oil
Old 18th May 2014, 20:08   #174
Anurag.
Ok - I didn't realize it's synthetic. The regular MGO costs around 300-400 per litre.
carboy is offline
Old 18th May 2014, 20:15   #175
No Sir, the oil was indeed 5W40. Attaching the screen shot of the bill for your reference (See the part number on that = 'SI5W40') which means 5W40 oil was used.
1) The 300-400 per litre is mineral oil;
2) The 600-700 per litre is semi-synthetic oil;
3) The 900-1000 per litre is fully synthetic oil.
Prices mentioned above are approximate ones.
Anurag.
Old 18th May 2014, 20:19   #176
Thanked: 135 Times
The MGO 5W40 oil can of 3.3ltr capacity has an MRP of Rs. 2228.09 .
I don't know if u were over charged or I got a better deal .. But do check when you go in for your 20k service .
Old 10th October 2014, 12:18   #177
Thanked: 406 Times
Hi BHPians, my ZDi is due for 4th service tomorrow (198xx km). Am planning on getting only these done. (Helpful list, thanks lone_driver)
Gear Oil - 901.18
coolant - 234.99
Brake Fluid - 75
Service kit - 1810
labor charges :
Paid Service - 735
Issues with my car:
1. CD cannot be inserted in the system. I tried just 3 months back, not sure if I tried it earlier. Will they replace the entire system under warranty?
2. Gearshifts - N->1 and 2->3 have become slightly hard, not all the time but sometimes.
3. Clutch has become slightly hard (not as soft as a new car).
4. I got the MGA reverse sensors installed before taking delivery but that have installed silver color sensors (on my white car). Am asking them to paint them white.
Any suggestions?
blue_pulsar is offline
Old 10th October 2014, 12:58   #178
Add the transmission oil to the list too even though MASS will change it is at 40K kms as per recent change in servicing.
Issues with my car:
Replying to your questions in the same points:
1. Has the problem been reported to MASS during the earlier services? What exactly happens when you try putting the CD at the slot? If there is an issue they'll repair the HU (pertaining to the CD infeed / outfeed motor) and not replace it.
2 & 3. Get the clutch bled and also I feel you'll need to change the transmission oil to see if there is any difference. Even after the oil is changed, the shifting is hard then it could be the gear shifter linkages or synchronizer rings.
4. I'd suggest leave it like that, I know it looks out of the place. I am not sure if it is correct to paint these sensors as it may affect its functionality.
Anurag.
Old 10th October 2014, 17:08   #179
Thanked: 406 Times
How much will this cost?
Anurag.
1. No, I haven't reported it earlier. I'm not sure of their competency to repair the internals of an electronic equipment. I hope they replace it.
4. From what I've heard, you can actually paint the sensors. May be I'll verify.
Also, can I ask MASS to use mineral oil? Or semi synthetic? I do not want my service bill to bloat up right now.
Thanks Anurag!
Old 10th October 2014, 17:17   #180
dass's Avatar
Thanked: 857 Times
Thanks Anurag!
1. If this is the company fitted music system, I guess they are of Nippon make. MASS would not repair it, you will have to take it to Nippon service center in your city and they would take care of it.
The choice of engine oil is completely left to the user, so you are well with in your rights to tell them to chose the oil you want. Just make sure you explicitly tell them about the oil when the job card is being prepared.
dass is offline   (2) Thanks
