Re: VW Vento: Fuel system clean-up. Dealer suggesting Rs. 2.5 lakh replacement Quote:
Originally Posted by Sutripta Neither can I! Never looked into a fuel tank with a borescope. (Which is what I think is being done here).
But if they are intelligent, would not put it past them to deliberately introduce some metal filings in the tank. It would be safe to clean it out. | Quote:
Originally Posted by Sankar Where is this diesel taken from?
If someone introduced metal filings this big in the tank it shouldn't come up past the screen at the fuel pump and definitely not after the diesel filter.
There are cases of hpfp failing on this motor which introduces metal filings like this. Especially on early models. |
Well, in this case, I really don't think they have introduced metal particles in the tank, I think it was only in the container they showed me. And the missing/jerking by air should have been sufficient for them to convince.
Especially saying this because, when bleeding I took the diesel from the tank (line to the filter) in a plastic cover and checked the filter too. No particles there. And Sankar, they have definitely not opened up the line after the HPFP before I touched it.
Also, the main point being, the car has run enough kilometres after the incident and gotten a tankful of diesel from a different pump and there is/was no problem with the way engine is running. Quote:
Originally Posted by mijnoirhammer67 Let me get this straight. You got to the VW garage and drained the system all by yourself in the VW garage? |
Yes, in the VW garage, I got hold of a foreman and me and him did it, clear instructions from me. Quote:
When you managed to do that, and hence removed the air as you said, and you went on for a drive and found out nothing was wrong. Then what happened? I am sure you told the service adviser and manager this? Do share with us how they weaseled out of that hole.
This is the part that surprised me. How they took it. As expected the person who told me the solution was nowhere to be found, and for the rest. They said, sir, we care for you. If you are stuck somewhere on the roadside with family then we are not responsible. Was soo convincing, that even after the whole repairing episode, I might have accepted their word just out of fear!
How these crooks inject fear into a logical mind is amazing! Also, I suspect this doing is from the top level management and just a service advisor cannot pull this feat all the time. I wonder what will be the plight of new car owner who doesn't have the time for all this nonsense.
Ah.. and one more point worth mentioning is - Maybe because of this when my work was over at 4, I was made to wait till 8 in the night to finish the billing. For a simple gate pass, I was made to wait.. wait.. and wait even after the bill was paid in full.. |
