Old 27th January 2011, 14:17   #3106
nishantgandhi's Avatar
Thanked: 156 Times
Re: Blackberry Phones and Services in India
Originally Posted by Godfather View Post
Guys, Need help here!!!
I have a BB 8830 world edition (dual sim) which I was using when I was in the US. the service provider was verizon wireless.
I had paid retail for this phone at that time (3 years now) and currently have not used the phone in India (over a year and half now).
The problem is that when i took out the phone from storage (BB Box) i had packed the battery seperately and now this is swollen.
I do know for a fact that the battery needs to be thrown away. I an unable to source any other battery for this phone now. The battery number is C-X2.
aould appreciate it if anyone can give me details as to where I can source this batter in Bangalore / Delhi.
Have you tried http://www.fommy.co.in/blackberry/RI...llow-P7407.htm
or
http://cgi.ebay.in/100-Original-Blac...item415646e257
nishantgandhi is offline
Old 27th January 2011, 16:14   #3107
straight6's Avatar
Thanked: 306 Times
Thanks guys but that vcard converter page doesn't exist anymore. I'm currently downloading the new OS. Already downloaded the desktop manager.
straight6 is offline
Old 27th January 2011, 16:42   #3108
Godfather's Avatar
Thanked: 71 Times
Originally Posted by nishantgandhi View Post
Have you tried
Thank you for the links. I wanted an immediate replacement battery since my current phone needs to go for screen change.
I will try the BB showroom on cunningham road today. If i do not get a battery there then will use your links.
Thanks again
Godfather is offline
Old 27th January 2011, 17:31   #3109
valhallen.282's Avatar
Thanked: 196 Times
@godfather here is a guys number who seems to have helped a few of my friends. i only know his brother's name is vikram. i dont know his name. +91-998 080 8222
sorry
@straight6 the vcard converter worked for my z550i when my BB backup refused to comply with restore.
valhallen.282 is offline
Old 27th January 2011, 18:45   #3110
straight6's Avatar
Thanked: 306 Times
How long back did you do it?
Old 27th January 2011, 23:39   #3111
straight6's Avatar
Thanked: 306 Times
Alright, so I finally transferred the contacts but I'm unable to update the OS after downloading it .
Old 28th January 2011, 14:23   #3112
nandishpal's Avatar
Thanked: 80 Times
hi guys!i see here there are alot of queries for blackberry,
i dont know if i should be sharing this here but i am an official blackberry retailer,
you can add me on your bbm & ask me your doubts,i will be happy to help,
will also be able to give you all the latest updates on the same,
my pin is 21D7CEBA ,i am also the tbhp bb group
nandishpal is offline
Old 28th January 2011, 22:34   #3113
normally_crazy's Avatar
Thanked: 543 Times
Reviews on the 8530 guys ?
normally_crazy is offline
Old 28th January 2011, 22:42   #3114
abhibh's Avatar
Thanked: 39 Times
8530 is CDMA version of entry level BB 8520. Its nice and gets the job done is what i can say.
abhibh is offline
Old 29th January 2011, 11:56   #3115
Thanked: 51 Times
Not only that. 8520 doesn't have GPS. 8530 has GPS. 8520 supports only GPRS/EDGE speeds. 8530 supports EVDO speeds up to 3.1mbps. My business partner uses the 8530 on TATA Indicom CDMA network and is very happy with it. Battery life is also not bad for his heavy usage.
deepakchan is offline
Old 30th January 2011, 00:38   #3116
Technocrat's Avatar
Thanked: 2,705 Times
I have/had the 8530, it has 3g + GPS over the 8520, rest everything same. Never hanged nor gave any issues. Battery life initially was poor but later on after a few cycles it was fine.
Technocrat is offline
Old 31st January 2011, 11:10   #3117
Thanked: 156 Times
Upcoming BB models lined up 2011
1. BlackBerry Monaco Touch - It looks a lot like the previously leaked images of the BB Storm 3. The phone runs BlackBerry OS 6.1 on a 1.2GHz Qualcomm processor and 768MB RAM. It has a 3.7" WVGA capacitive touchscreen (with 253DPI) and all this is packed in 11.5mm thickness.
BlackBerry Monaco Touch and a ponential version with physical, instead of capacitive keys. The Monaco Touch is primarily a CDMA phone with EV-DO data connectivity, but also offers quad-band EDGE and single-band UMTS, for roaming purposes most likely. Another interesting feature is the 5MP camera, which can record 720p video.
2. BlackBerry Bold Touch (a.k.a. Montana) - It too has GSM/EDGE/UMTS connectivity and a 1.2GHz CPU and 768MB RAM, 5MP camera with 720p video and it's even thinner - 10.5mm. The screen is 2.8" with VGA resolution for the impressive 287DPI.
3. BlackBerry Sedona and Curve Touch have similar specs, except that the Sedona is a QWERTY bar, while the Curve Touch is a touch phone. Both the BlackBerry Curve Touch and the Sedona are powered by 800MHz CPUs with 512MB RAM. The displays have the older HVGA resolution and the cameras are 5MP (the Curve Touch can record 720p video).
The Sedona would likely be known as BlackBerry Dakota in its GSM form, while the Curve Touch will be the BlackBerry Curve Apollo for its GSM version. On the other hand, it looks a lot like the Storm3 too.
(Source : BlackBerry roadmap leaks, touch screens, HD video and NFC ahead - GSMArena.com news)
Old 31st January 2011, 11:55   #3118
sgiitk's Avatar
Thanked: 4,808 Times
Reliance has started checking something called the AKey on CDMA handsets. Also, this makes MEID (CDMA equiv of IMEI) registration mandatory. This had been done in Karnataka & Andhra over the weekend. This makes cloned handsets non-functional. The most interesting part is that apparently most old (say 5 years+) phones do not support the AKey. So what happens to those. The timing sounds like someone wants to commit Harakiri. In the first month of MNP (Haryana) Reliance were the second worse sufferers (after BSNL).
The the positive side they are now permitting EVDO on registered handsets. The rates are also a lot cheaper than the others.
sgiitk is offline
Old 4th February 2011, 09:16   #3119
jkdas's Avatar
Thanked: 1,496 Times
Isnt this called 9300 Curve? I am thinking of getting this ( would be my first BB)
jkdas is offline
Old 4th February 2011, 09:49   #3120
deathwalkr's Avatar
Thanked: 5,049 Times
Dont know much about the 8530 but yes the 9300 does have 3G and GPS along with Wi-Fi and looks like a premium model as well.
A good model to buy!
deathwalkr is offline
