Old 21st November 2005, 10:02   #16
Originally Posted by Samurai
Actually I will moving near to the coast along NH17, driving will be fun. Of course, if you drive all the way to to my place, unlimited beer and snacks will be free.
hey, i'll repay u by throwing in all my audio expertise to set up your HT system in your new home. btw, did you get my thoughts on thx in your other thread on home theatre?
cream is offline
Old 21st November 2005, 10:22   #17
okay - the dope on projectors...
the nec ht1100 for around 1.6L available at nec solutions @ 9820579407
or for the same price but a shade better
the optoma h57 available with soundsmiths @ 9820949395.
u can take the call of availability and service in your area after speaking to them...
cheers
cream is offline
Old 21st November 2005, 10:26   #18
btw, the screenplay 4805 is not great - also it costs less than a lakh. and have no bones about this - if you want to enjoy a movie on a projector, a dark room is the only way. super bright projectors are not really meant to give you daylight viewing - they are actually meant for giving high dynamic contrasts whenever the need arises. but as usual, don't go by the specs except for choosing the basic aspects like resolution etc.
cream is offline
Old 21st November 2005, 10:29   #19
Thanked: 2,752 Times
Thanks for the Samurai, and yes I infest NH17 quite regularly so keep that beer chilled!
Steeroid is offline
Old 21st November 2005, 10:34   #20
Samurai's Avatar
Thanked: 46,676 Times
No problem. The place is just 5Km off NH17, after April you are welcome to drop in anytime.
Samurai is offline
Old 21st November 2005, 10:38   #21
Samurai's Avatar
Man, you are breaking my heart. Only dark room viewing? How about low light viewing? I was hoping with higher lumens, I can at least get low light viewing.
Samurai is offline
Old 21st November 2005, 15:07   #22
Samurai's Avatar
I am suddenly warming up towards DLP projection television. Samsung has some very good models.
Samurai is offline
Old 21st November 2005, 15:27   #23
tsk1979's Avatar
Thanked: 22,975 Times
DLP projector will give you similar results, but you will have the flexibility of putting it anywhere. Infact the background may not be completely smooth, any wall, even with dimples will do.
Moreover you do not have to be in a dark room. They work perfectly in well lit rooms, as they automatically adjust image.
tsk1979 is offline
Old 21st November 2005, 15:36   #24
Samurai's Avatar
Are you saying DLP projectors work in well lit rooms? I don't think so. Are you confusing DLP projectors with DLP televisions?
Samurai is offline
Old 21st November 2005, 15:40   #25
tsk1979's Avatar
Not all DLP projectors, but many of the models work well in well lit rooms. DLP technology gives high contrast capibility. So a manufacturer can choose wether to make a projector which works in well lit rooms. the lower end ones do not do so well, because the main aim is to cut costs, but high end ones will work in rooms with the most projector unfriendly.
I am not saying this after seeing reviews, but based on personal expirience with many models(I used to work for the company which invented the technology).
tsk1979 is offline
Old 21st November 2005, 15:47   #26
Samurai's Avatar
Correct me if I am wrong. It is my understanding that higher contrast ratio only helps in getting sharper images. Higher Lumens make for brigher images, to view the projector output in a well lit room, you need excess of 2000 effective lumens.
Samurai is offline
Old 21st November 2005, 16:09   #27
tsk1979's Avatar
Yes thats true, but the problem with having more lumes is that you also jack up the noise. So your image starts to appear fuzzy. The DLP chip allows the manufacturer to crank up the lumens, but earlier projectors had this limitation. With DLP you have a high "range"
Now a manufacturer may or may not choose to give a high power bulb, but with DLP he has the option to give it.
tsk1979 is offline
Old 21st November 2005, 21:41   #28
btw, the dlp projectors and the rear projection tvs are more or less based on the same principle - so forget about getting any great quality from any projector - front or rear - in lit conditions
cream is offline
Old 21st November 2005, 22:46   #29
Samurai's Avatar
I have to respectfully disagee. I don't know about the principle, but the effect is something else. In the fall of 2003 I ventured into Circuit city and was shocked to see a Samsung projection TV whose quality was mind blowing, it was like plasma, only bigger and brighter. That was my first encounter with a DLP projection TV. It was in a normally lit showroom floor, not even close to low light. BTW, I have never cared for projection TVs before that, because of their dull interlaced image. With DLP and progressive scan, the projection TVs now can compete with plasma and lcd televisions.
Samurai is offline
Old 21st November 2005, 23:00   #30
tsk1979's Avatar
@Samurai, if you are really interested in knowing how DLP manages such quality which was earlier not possible, read this up, http://www.dlp.com/Default.asp?DCMP=...e_p_dlp&bhcp=1
This has intro about how DLP works. If you are interested in even more technical stuff dig up the spec sheets etc.,
tsk1979 is offline
