Old 21st November 2009, 00:14   #1
aaggoswami's Avatar
Thanked: 3,000 Times
How Intel CPU is made. From Sand to Silicon.
Here I am posting what I had earlier had read on net. Problem was I went in for the highest quality image and those images were upto 5-6 mb in JPEG format.
So now, after quite a bit of time, i.e. some months, I am posting the images and procedure how Core i7 45nm CPU is made.
@mods: If you feel so, split this post into 2-3 posts.
Images follows text.
1) Sand. Made up of 25 percent silicon, is, after oxygen, the second most abundant chemical element that's in the earth's crust. Sand, especially quartz, has high percentages of silicon in the form of silicon dioxide (SiO2) and is the base ingredient for semiconductor manufacturing.
2) After procuring raw sand and separating the silicon, the excess material is disposed of and the silicon is purified in multiple steps to finally reach semiconductor manufacturing quality which is called electronic grade silicon. The resulting purity is so great that electronic grade silicon may only have one alien atom for every one billion silicon atoms. After the purification process, the silicon enters the melting phase. In this picture you can see how one big crystal is grown from the purified silicon melt. The resulting mono-crystal is called an ingot.
3) A mono-crystal ingot is produced from electronic grade silicon. One ingot weighs approximately 100 kilograms (or 220 pounds) and has a silicon purity of 99.9999 percent.
4) The ingot is then moved onto the slicing phase where individual silicon discs, called wafers, are sliced thin. Some ingots can stand higher than five feet. Several different diameters of ingots exist depending on the required wafer size. Today, CPUs are commonly made on 300 mm wafers.
5) Once cut, the wafers are polished until they have flawless, mirror-smooth surfaces. Intel doesn't produce its own ingots and wafers, and instead purchases manufacturing-ready wafers from third-party companies. Intel’s advanced 45 nm High-K/Metal Gate process uses wafers with a diameter of 300 mm (or 12-inches). When Intel first began making chips, it printed circuits on 50 mm (2-inches) wafers. These days, Intel uses 300 mm wafers, resulting in decreased costs per chip.
6) The blue liquid, depicted below, is a photo resist finish similar to those used in film for photography. The wafer spins during this step to allow an evenly-distributed coating that's smooth and also very thin.
7) At this stage, the photo-resistant finish is exposed to ultra violet (UV) light. The chemical reaction triggered by the UV light is similar to what happens to film material in a camera the moment you press the shutter button.
Areas of the resist on the wafer that have been exposed to UV light will become soluble. The exposure is done using masks that act like stencils. When used with UV light, masks create the various circuit patterns. The building of a CPU essentially repeats this process over and over until multiple layers are stacked on top of each other.
A lens (middle) reduces the mask's image to a small focal point. The resulting "print" on the wafer is typically four times smaller, linearly, than the mask's pattern.
8) In the picture we have a representation of what a single transistor would appear like if we could see it with the naked eye. A transistor acts as a switch, controlling the flow of electrical current in a computer chip. Intel researchers have developed transistors so small that they claim roughly 30 million of them could fit on the head of a pin.
9) After being exposed to UV light, the exposed blue photo resist areas are completely dissolved by a solvent. This reveals a pattern of photo resist made by the mask. The beginnings of transistors, interconnects, and other electrical contacts begin to grow from this point.
10) The photo resist layer protects wafer material that should not be etched away. Areas that were exposed will be etched away with chemicals.
11) After the etching, the photo resist is removed and the desired shape becomes visible.
12) More photo resist (blue) is applied and then re-exposed to UV light. Exposed photo resist is then washed off again before the next step, which is called ion doping. This is the step where ion particles are exposed to the wafer, allowing the silicon to change its chemical properties in a way that allows the CPU to control the flow of electricity.
13) Through a process called ion implantation (one form of a process called doping) the exposed areas of the silicon wafer are bombarded with ions. Ions are implanted in the silicon wafer to alter the way silicon in these areas conduct electricity. Ions are propelled onto the surface of the wafer at very high velocities. An electrical field accelerates the ions to a speed of over 300,000 km/hour (roughly 185,000 mph)Through a process called ion implantation (one form of a process called doping) the exposed areas of the silicon wafer are bombarded with ions. Ions are implanted in the silicon wafer to alter the way silicon in these areas conduct electricity. Ions are propelled onto the surface of the wafer at very high velocities. An electrical field accelerates the ions to a speed of over 300,000 km/hour (roughly 185,000 mph)
14) After the ion implantation, the photo resist will be removed and the material that should have been doped (green) now has alien atoms implanted.
15) This transistor is close to being finished. Three holes have been etched into the insulation layer (magenta color) above the transistor. These three holes will be filled with copper, which will make up the connections to other transistors.
16) The wafers are put into a copper sulphate solution at this stage. Copper ions are deposited onto the transistor through a process called electroplating. The copper ions travel from the positive terminal (anode) to the negative terminal (cathode) which is represented by the wafer.
17) The copper ions settle as a thin layer on the wafer surface.
18) The excess material is polished off leaving a very thin layer of copper.
19) Multiple metal layers are created to interconnects (think wires) in between the various transistors. How these connections have to be “wired” is determined by the architecture and design teams that develop the functionality of the respective processor (for example, Intel’s Core i7 processor). While computer chips look extremely flat, they may actually have over 20 layers to form complex circuitry. If you look at a magnified view of a chip, you will see an intricate network of circuit lines and transistors that look like a futuristic, multi-layered highway system.
20) This fraction of a ready wafer is being put through a first functionality test. In this stage test patterns are fed into every single chip and the response from the chip monitored and compared to "the right answer."
21) After tests determine that the wafer has a good yield of functioning processor units, the wafer is cut into pieces (called dies).
22) The dies that responded with the right answer to the test pattern will be put forward for the next step (packaging). Bad dies are discarded. Several years ago, Intel made key chains out of bad CPU dies.
23) This is an individual die, which has been cut out in the previous step (slicing). The die shown here is a die of an Intel Core i7 processor.
24) The substrate, the die, and the heatspreader are put together to form a completed processor. The green substrate builds the electrical and mechanical interface for the processor to interact with the rest of the PC system. The silver heatspreader is a thermal interface where a cooling solution will be applied. This will keep the processor cool during operation.
25) A microprocessor is the most complex manufactured product on earth. In fact, it takes hundreds of steps and only the most important ones have been visualized in this picture story. ( applicable for two images below )
26) During this final test the processors will be tested for their key characteristics (among the tested characteristics are power dissipation and maximum frequency).
27) Based on the test result of class testing processors with the same capabilities are put into the same transporting trays. This process is called "binning," a process with which many Tom's Hardware readers will be familiar. Binning determines the maximum operating frequency of a processor, and batches are divided and sold according to stable specifications.
28) The manufactured and tested processors (again Intel Core i7 processor is shown here) either go to system manufacturers in trays or into retail stores in a box.
aaggoswami is offline
Old 21st November 2009, 01:03   #2
BlackPearl's Avatar
Thanked: 17,375 Times
Thanks aaggoswami for the lovely insight into processor manufacturing.
BlackPearl is online now
Old 21st November 2009, 08:36   #3
swift8847's Avatar
Thanks for sharing this information. Very useful and informative. Do post some more of the similar kinds.
swift8847 is offline
Old 21st November 2009, 08:51   #4
Thanked: 77 Times
Brilliant post! I never knew manufacturing processors was this complex in nature. Thanks for sharing this information.
deepakhon is offline
Old 21st November 2009, 09:12   #5
Vid6639's Avatar
Thanked: 44,133 Times
Why do the CPU's have different speed classification?
If a processor fails during testing on the Automated Test Equipment(ATE) (Step26) at the highest frequency say for example 2.6GHz, it is retested on the ATE at say 2.2GHz. If it passes then it is considered as a lower version of the same die. That way they don't have to throw have dies failing at max speeds.
Another way to have several versions intentionally is to lock certain features on the chip by blowing electrically programmable fuses during testing.
Step number 22 and 26 are done on the ATE. If the device passes on 22 then only it goes to packaging to save packaging cost. On step 26 the chip needs to be tested again to ensure no device parameters have drifted due to the packaging process.
Vid6639 is offline
Old 21st November 2009, 09:16   #6
Thanked: 92 Times
Very informative post.
However the thread name should have been:- From sand to $$$$$$$
akj53 is offline
Old 21st November 2009, 09:17   #7
Thanked: 44 Times
Good Post, Thanks for sharing
StarVegabond is offline
Old 21st November 2009, 09:33   #8
bmw_m5_titus's Avatar
Aagoswami, great thread you have started. Very interesting read about the making of processors.
bmw_m5_titus is offline
Old 21st November 2009, 10:49   #9
Prithvi's Avatar
Thanked: 26 Times
fantastic post. worth reading it
Prithvi is offline
