Old 5th July 2022, 08:13   #6646
vsrivatsa's Avatar
Thanked: 4,052 Times
Re: The Laptop Thread: Configs, deals & questions
Originally Posted by sunbaj View Post
Getting a laptop with the below configuration for aprox. 800$ including taxes. Do suggest if this is a good buy. I do not play games nor am I interested in a 2-in-one laptop.
Brand: HP
Model15-eg2073cl
Color: Blue
Check this one - similar to the one that you had shortlisted but with Ryzen7: Walmart HP Ryzen7
RAM should be upgradeable I think - but do double check.
vsrivatsa is offline   (1) Thanks
Old 6th July 2022, 08:48   #6647
TheLxGuy69's Avatar
Thanked: 7 Times
Originally Posted by Guite View Post
#1 and #2 same processor, Ryzen 5, 6 cores 12 threads, 3.3 ghz. 45 watt TDP.
One thing to add here will be the battery life.
HP Victus has a 70Wh battery compared to the Pavilion's 52Wh i.e the Victus will last longer than the Pavilion on battery power.
And as the OP has specified they might need to use the laptop unplugged for hours in college,
this might be a point of consideration for them.
Not sure about the comparison of the graphic cards in both these laptops but if they somehow match, then definitely going for the Victus would be beneficial for OP.
Edit: The Victus also comes with a Gtx 1650 at a premium of 2-3k over the radeon variant.
Here's the product number 16-E0301Ax
consider buying that instead.
TheLxGuy69 is offline   (1) Thanks
Old 11th July 2022, 14:35   #6648
Thanked: 6,447 Times
Guys, my new laptop ASUS Vivobook. Is giving me only about 4-4.5 hours battery backup with zoom usage and normal office work (ppt, excel).
Can some please let me know if this is good, bad or very bad?
(P.S. My laptop is OLED screen and I use it at 70% brightness, 15.6 inch screen)
2000rpm is offline
Old 13th July 2022, 10:01   #6649
Thanked: 262 Times
Looking at buying a gaming laptop in the rate of Rs.70K to 80K. What brands / processors should i be looking at ?
bharanidharang is offline
Old 13th July 2022, 10:42   #6650
Thanked: 216 Times
Lenovo has a gaming laptop that I checked out recently, the Lenovo IdeaPad Gaming 3. It has a 11th generation Intel performance processor (11300H), 16 GB RAM, and also comes with a 4GB NVIDIA RTX graphics card. I almost purchased it but the battery life of 1-2 hrs does not cut it for me, so I went for the Lenovo IdeaPad Slim 5 laptop, which also has an NVIDIA graphics card but only the 2GB MX450 one.
If you're okay with the 1-2 hr battery life and weight of 2.2 kg, the IdeaPad Gaming 3 could be a good gaming laptop in the INR 70-80K budget. It appeared to be better built than the one I got. I tried out opening apps too, and it just flew.
prasi55 is online now   (1) Thanks
Old 14th July 2022, 12:15   #6651
Thanked: 35 Times
Bought the pavilion gaming instead.
Had visited Reliance digital on a weekday to have a hand's on comparison of the laptops. A totally empty store meant i could have a good conversation with the sales guys and after asking him on issues on these laptops he showed me the screen flickering issue of the Victus, so rejected it. Also Victus has more weight to it than the Pavilion.
MANE is offline
Old 15th July 2022, 16:27   #6652
Mr. Nobody's Avatar
Thanked: 636 Times
Get a 6 core processor minimum and graphics should be 3050 or 3050 TI. Ram can be 8 but upgrade it to 16/32 later. If you can spend 80k, id say spend 90k to get a 3060 variant laptop as the 4gb vram in 3050 does limit its performance in demanding AAA games.
Take a look at this one, its pretty loaded and within your budget - https://store.acer.com/en-in/acer-ni...isplay-2-5-kgs
Lenovo - https://www.amazon.in/Lenovo-Legion-...s%2C493&sr=8-9
The Dell G15 is also good but has a non-ips display.
You can also look at Asus Tuf series if you need a good battery life as it has a 90wh battery instead of the 50-65 range others have , every other gaming laptop has a small battery that usually doesn't last over 3 hours.
Mr. Nobody is offline   (1) Thanks
Old 17th July 2022, 05:53   #6653
Thanked: 333 Times
the Lenovo IdeaPad Gaming 3 82K201ULIN Laptop (Ryzen 5 5600H/ 16GB/ 512GB SSD/ Win11 Home/ 4GB Graph), Asus TUF Gaming A17 FA706IC-HX003T Laptop (Ryzen 7 4800H/ 16GB/ 512GB SSD/ Win10 Home/ 4GB Graph)
and MSI Katana GF66 11UC-477IN Gaming Laptop (11th Gen Core i7/ 8GB/ 512GB SSD/ Win10 Home/ 4GB Graph) are also options worth considering.
itsmeparvathy9 is offline   (1) Thanks
Old 17th July 2022, 17:23   #6654
itwasntme's Avatar
Thanked: 14,144 Times
Guys, need to buy a 'home laptop' which can be used by wifey and me instead of our office machines.
^^Intent is to generally surf the Net, email and streaming media.
^^Huge storage not a pre-requisite as we are on some kind of cloud most of the times.
^^No gaming of any kind envisaged.
^^Budget ideally less than 25K, max 30K.
Any suggestions will be highly appreciated.
itwasntme is online now
Old 17th July 2022, 19:45   #6655
Thanked: 327 Times
Request you to please post a quick user review of this laptop if possible, i am looking at getting a Vivobook Ryzen 5500u (non-OLED) during an upcoming sale.
The other option i am looking at is HP Pavilion 5625u laptop.
kochup is offline
Old 18th July 2022, 06:26   #6656
Thanked: 333 Times
I Will list out a few you could choose from according to your need:
1. Asus X415JA-BV302WS (90NB0ST1-M005Y0) Core i3 10th Gen Windows 11 Home Laptop (8GB RAM, 1TB HDD, Intel UHD Graphics, MS Office, 35.56cm)
Buy from Croma: https://www.croma.com/asus-x415ja-bv...lver-/p/255331
Suggestion: Buy online you get same day delivery in most metro cities, and if you like to buy from the store, it may also be available in your nearest Croma store as well.
However, if you order online, you get Croma Card Discount HDFC/AXIS/ICICI/BOB/SBI/YES bank etc depending on which day of the week it is up to 10% of order amount and for service and warranty you can approach nearest Croma Store as well.
2. HP 255 G8 Laptop 62Y22PA (AMD Ryzen 3-3250U/ 8GB Ram/ 1TB HDD/ 39.62 cm (15.6 inch) HD/Windows 11/AMD Radeon Vega 8 Graphics/ 1.74Kg)
Buy from Amazon: https://www.amazon.in/HP-62Y22PA-3-3.../dp/B09SWDVQSM
or Alternatively (the first one is better though): https://www.amazon.in/HP-3-3250U-Gra.../dp/B09RMQXSZT
Suggestion:If you are buying from Amazon, wait for Prime Day sale on 23rd July, you might get credit/debit card offers and discounts.
3. Infinix X1 Slim Series Core i3 10th Gen - (8 GB/256 GB SSD/Windows 11 Home) XL21 Thin and Light Laptop (14 inch, 1.24 kg)
Buy from Flipkart: / https://www.flipkart.com/infinix-x1-...e5084e965d928?
Suggestion:If you are buying from Flipkart, Use Axis Bank/SBI Cards during Electronics Sale ending 18th July 2022.
Conclusion:
1. Go for Asus Laptop if you prefer a full HD and 14-inch display.
2. Go for HP Laptop if you are OK with Ryzen Processor and want reputed brand.
3. Go for Infinix if you don't care about brand and want a 14-inch full HD Display and an SSD. This will be the fastest among the lot due to SSD.
itsmeparvathy9 is offline   (2) Thanks
Old 18th July 2022, 12:23   #6657
Mr. Nobody's Avatar
Thanked: 636 Times
Get a laptop with SSD only. Else it will be a laggy experience even on a i7 processor. You can look at some options below:
https://www.amazon.in/Acer-Ryzen-Win...dp/B0B42QJMJP/
https://www.lenovo.com/in/en/laptops...l/p/81WB018XIN
https://www.amazon.in/Dell-Inspiron-...dp/B09TNWYR3Q/
Buy during upcoming amazon prime day sales this month, you should get a good deal!
Mr. Nobody is offline   (2) Thanks
Old 19th July 2022, 10:11   #6658
Thanked: 701 Times
Your requirement has Chromebook written all over it. Unless you need any Windows-specific application to run, in this budget a Chromebook will provide better performance and battery backup.
For example, something like this
7000plusrpm is offline   (1) Thanks
Old 19th July 2022, 19:48   #6659
Its 3.5 out of 5.0 I guess. I prefer ultrabooks, this is slightly large for me.
2000rpm is offline   (1) Thanks
Old 19th July 2022, 21:18   #6660
Thanked: 15 Times
How about Dell xps or Windows surface, if you are on tight budget, Surface has different versions, that you may look into.
~Zombie~ is offline
