Old 22nd June 2016, 09:50   #4696
Thanked: 1,902 Times
Re: The Laptop Thread: Configs, deals & questions
What do you guys use to clean dirt from a laptop - especially that stuck behind the keys.
I have a Thinkpad.
carboy is offline
Old 22nd June 2016, 11:16   #4697
sgiitk's Avatar
Thanked: 4,791 Times
I have a Thinkpad.
Same here. I find a 2" soft bristled paintbrush the best. I have been using it for over five years, esp on keyboards.
sgiitk is offline
Old 22nd June 2016, 12:23   #4698
Thanked: 2,794 Times
I have a Thinkpad.
. Take the keyboard out, it can be detached by unscrewing a few screws
. Detach the key tops.
. Use a brush to clean loose dirt.
. Use a wet cloth to clean up most of the surface.
. Use an earbud for hard to reach places.
. Wash the key tops with soap water and cloth to clean up the accumulated muck.
. Dry every thing thoroughly.
. Assemble the key tops.
. Screw the keyboard back.
. Check the functioning of the keyboard.
For desktop only the first point is skipped.
Aroy is offline
Old 22nd June 2016, 12:33   #4699
Thank you - any idea about using compressed air for cleaning the keyboard?
:-) Well, I am terrible with DIY. Even if I am able to take it apart, I won't be able to put it back.
carboy is offline
Old 22nd June 2016, 15:28   #4700
sgiitk's Avatar
@carboy; The risk with compressed air is that you may blow some muck deeper. Otherwise compressed air is used.
sgiitk is offline
Old 25th June 2016, 17:34   #4701
Thank you. Where can I buy Isopropyl alcohol?
carboy is offline
Old 26th June 2016, 08:37   #4702
sgiitk's Avatar
It is widely available as Medical Spirit. Now IPA is used in place of Denatured Ethanol in the past. I will be carrying a small amount of blue dye. Try any chemist.
sgiitk is offline
Old 27th June 2016, 10:04   #4703
Thanked: 252 Times
You can buy IPA from School/College Laboratory Reagent sellers (scientific goods shops). Its available in two grades - Analytical (more pure) and Reagent. The one available with chemists (blue liquid) is IPA mixed with water.
DwarkaDelhiWala is offline
Old 30th June 2016, 20:40   #4704
JMaruru's Avatar
Thanked: 375 Times
Re: Optical Drive on Dell XPS?
The optical drive of my dell XPS(L502X) is NOT detecting DVDs.
But, some CDs are getting detected.
I called a friend/technician and he suggested to run lens cleaner CDz.
Would this help? What could be wrong here? Please advise.
JMaruru is offline
Old 30th June 2016, 23:08   #4705
Thanked: 252 Times
Re: THE Laptop Thread: Configs, deals and questions
Originally Posted by micrographics View Post
Finally opted for Dell Inspiron 15 7559 Model with 16 Gb, 4G Graphics, 128Gb SSD + 1 TB HDD, 4K Display.
I'm looking at this laptop as well. Can you please give some feedback as to how its performing? is the keyboard back-lit?
Old 1st July 2016, 15:06   #4706
If the drive has not been used for some time then the lens may be covered in dust. Try blowing hard into the drive. If you have a blower direct an air blast into the drive, it may blow the dust off.
Aroy is offline
Old 2nd July 2016, 07:32   #4707
JMaruru's Avatar
Thanked: 375 Times
Thanks! Will do that. Also, can i use some spirit and micro fiber to clean the lens?
Any recommendations for DVD burner software?
JMaruru is offline
Old 2nd July 2016, 09:51   #4708
sgiitk's Avatar
I was once advised by the expert technician to always leave a CD/DVD in the carrier.
It seems this prevents or reduces the entry of dust/grit.
sgiitk is offline
Old 2nd July 2016, 10:56   #4709
Plastic of the lens may cloud/melt with spirit, so avoid it. A bit of moisure on a microfiber cloth is enough.
Aroy is offline
Old 2nd July 2016, 22:47   #4710
JMaruru's Avatar
Thanked: 375 Times
Will follow this advise. Thank you!
All right! Thank you!
JMaruru is offline
