Old 13th October 2015, 14:36   #4486
ashwin.terminat's Avatar
Thanked: 2,218 Times
Re: THE Laptop Thread: Configs, deals and questions
Originally Posted by tbppjpr View Post
Point is these type of things can be fixed.
That is reassuring.
One last thing, I want to know how exactly this happened.
I put in the new hard drive with the frame, but didn't fasten the screws that secure and hold the hard drive in place.
Did the load of the sagging HDD cause the SATA port to malfunction?
ashwin.terminat is offline
Old 13th October 2015, 15:13   #4487
tbppjpr's Avatar
Thanked: 1,604 Times
Originally Posted by ashwin.terminat View Post
That is reassuring.
I don't think so. If that was the case then how the previous HDD threw errors, that must have been secured with screws. Also check the status of previous hard disk by connecting onto your computer. If you have any Linux system around then that will be much more helpful in pin pointing the hard disk related issues.
tbppjpr is offline
Old 13th October 2015, 15:22   #4488
The previous HDD was probably ruined by a drop the laptop had from about 2 feet. I am not entirely sure though.
What bothers me is why the HDD was working fine initially only to stop working later on
Yes, I have an Ubuntu DVD at home. Will try booting with that once I get home. The surprise will be if the Live CD is able to access the HDD.
Another anomaly I remember about this laptop. The processor fan cannot be modulated. It runs almost always on top speed; close to 5200RPM. This is because I can see a wire that seemingly provides power supply from elsewhere on the motherboard and it seems to come from a terminal near the HDD port and the CD/DVD drive port.
Old 13th October 2015, 15:58   #4489
tbppjpr's Avatar
There must be some OEM utility whuch controls the fan speed according to temprature. Check the Dell website for drivers and utilty download.
About accessing HDD while computer is booted from DVD, yes it can see the hard disk.
tbppjpr is offline
Old 14th October 2015, 07:47   #4490
Soumyajit9's Avatar
Thanked: 1,801 Times
Is the SATA Cable from the motherboard detachable, or soldered ?
Normally on desktops, a SATA cable is detachable from both motherboard and hdd.
If detachable, use another SATA cable and check.
Soumyajit9 is offline
Old 14th October 2015, 11:19   #4491
There must be some OEM utility whuch controls the fan speed according to temperature. Check the Dell website for drivers and utilty download.
The SATA port is soldered onto the laptop's motherboard. How I wish it was a cable.
The laptop has two RAM sticks. 1GBx1 and 4GBx1 for a total of 5GB.
I tested the 1GB stick with Memtest and no errors were reported even after 7 passes. I then tried booting the laptop with only the 1GB stick installed, but again was greeted to the same error.
I also tried booting with the 4GB RAM stick alone. But again, same error. The 4GB RAM stick is currently undergoing Memtest and I will know the results once I get home. Will update the same here later.
I did try installing Ubuntu 12.10 as well. Oddly enough, it did install without any problems. But when it tried to boot, I got a "Read Error".
If the SATA port alone is indeed not replaceable, I think I can use a ODD Caddy and use the new HDD there as the primary HDD. Much more cost effective compared to changing the motherboard or buying a new laptop.
Old 14th October 2015, 15:06   #4492
amansanc's Avatar
Thanked: 707 Times
Originally Posted by hellmet View Post
Lightweight is a MUST as I will be traveling quite a bit with my tablet, phone, and this future laptop. It will hopefully not exceed 1.5KG in weight.
Check out Dell Inspiron 3148 with i3 processor. Fits your budget perfectly. Has a 11.6" IPS touchscreen which is brilliant. The screen rotates 360 degrees to make it into a tablet. The weight is just 1.4 kgs which makes it easy to carry around. I am using one since an year now and absolutely love it. Only one small drawback, the body of it is a scratch-magnet!
Try to get additional warranty along with it. I picked up during Dell Diwali offer last year and got an amazing deal (34.5k) on Flipkart. You should wait for it too if possible.
amansanc is offline
Old 14th October 2015, 23:10   #4493
The 4GB RAM also showed no errors in Memtest.
Any other ideas to narrow down to the problem?
Old 18th October 2015, 17:14   #4494
So, I went down to SP Road yesterday to get the SATA port fixed.
I came out of the shop just being confused further.
When the person tried installing Windows on the new HDD, it froze at the formatting screen or the Copying Windows Files bit did not cross 0%. This is the same HDD that works flawlessly on my desktop PC.
But when he slotted another HDD into the laptop, Windows installed perfectly!
I got back home and ran a Drive Fitness Test using a utility from HGST(The HDD manufacturer) it showed no errors.
Any help would be appreciated.
Old 18th October 2015, 18:14   #4495
diyguy's Avatar
Thanked: 581 Times
I have a feeling that the laptop motherboard is incompatible with the newer generation HDD. Try slip streaming the drivers with the OS installation like we used to do for XP and SATA. Also have you tried Ubuntu or other flavors of Linux? Start with DOS. If you have he older HDD try with that once after marking its bad sectors. The HDD that the shop guy installed, was it a new gen drive? Also are there any jumper settings on the done HDD. Just sharing some thoughts and if you have tried, please ignore
diyguy is offline
Old 18th October 2015, 19:15   #4496
Thanked: 2,794 Times
Even I think that it is SATA compatibility problem. If so then there is not much you can do, except hope that newer drivers will solve the problem. Other wise you may have to get an older generation drive - preferably the same one the person in the shop used.
OT, but I have a similar problem with my Graphics Card/Monitor/OS. I have two 4-5 year old 1920x1200 displays. On XP they worked perfectly. On Win 7 with initial installation and also with graphics card (ATI) manufacturer's drivers, one monitor would have the display shifted left, so there is a space at the right and display missing on the left. I have two ATI cards, and no amount of combinations can get rid of this. Win 7 update solved this. Now when I installed Win 10, the same thing happened and after trying all sorts of drivers, I had to revert back to Win 7 after spending over 7 hours downloading and installing Win 10, as I could not find a method of getting a specified update. So at times driver incompatibility can really drive you bonkers.
Aroy is offline
Old 18th October 2015, 20:00   #4497
diyguy's Avatar
Thanked: 581 Times
Check the speed of the HDD and if it is backward compatible with 1.5Gbps. I think the newer ones are 6Gbps while the earlier ones were 1.5 I guess. Check for the bios update for the laptop too.
diyguy is offline
Old 19th October 2015, 15:23   #4498
I tried Ubuntu. I got the same error just worded differently.
I do have the older HDD. It does have a jumper. But I do not see any pins that it can connect to. The newer HDD does not have this jumper, though. This laptop was bought in 2012. The new HGST is a 6.0Gbps drive. But it does say it is 3.0Gbps and 1.5Gbps backward compatible as well.
Marking the bad sectors on the old HDD is done through chkdsk?
I have sold the new HDD on Quikr either way. But I would like to know why this issue probably came about. What drivers are you referring to? SATA drivers for the motherboard to be slipstreamed(interesting to hear a non-aerodynamic slipstream reference on T-BHP ) on the Win 7 installation disk?
I guess we'll never know. I sold the new HDD on Quikr. :(
This BIOS update is one thing I could not try. Sadly.
Dell only offers an EXE mode of flashing the BIOS. And DOS didn't allow this EXE to run. And I could not get Windows on the laptop to execute the EXE in a Windows environment.
Old 19th October 2015, 22:43   #4499
diyguy's Avatar
Thanked: 581 Times
SATA drivers for the motherboard to be slipstreamed(interesting to hear a non-aerodynamic slipstream reference on T-BHP ) on the Win 7 installation disk?.
Yes chkdsk or any other scan and mark utility.
I recently tried installing xp on a new laptop and even though I created a slipstreamed disk with the right drivers it would just hang on the installing Windows...
I tried the same disk on an older pc and it worked fine. That's why I am pretty sure it is a sata incompatibility issue... It sure is frustrating when we cannot overcome some of these technical issues in these times... I was extremely frustrated after three days and nights on the XP thing... Finally gave up and installed win 7
diyguy is offline
Old 20th October 2015, 00:26   #4500
The new HDD was SATA III. Do you mean to say that the motherboard does not support SATA III or that the drivers installed do not?
Because when I enter the service tag, I cannot find any SATA drivers at all on the Dell website.
