Old 30th October 2018, 11:28   #1711
Thanked: 708 Times
Re: On Wi-Fi & Routers
Originally Posted by carboy View Post
I read somewhere that AC class routers have better range than the non-AC ones
By range, do you mean higher transfer rate or the distance away from router? If distance, then 2.4 ghz has longer range. If transfer rate, then it is 5 ghz.
Would it be possible for the router to transmit wifi in both ac & non ac modes at the same time?
All routers can transmit signals on n as well as ac, in parallel. So you can connect older as well as new devices.
shipnil is online now
Old 30th October 2018, 13:39   #1712
Thanked: 1,902 Times
I meant distance from router.
So you are saying that my older router will transmit more distance than this AC router?
Don't understand - are you saying I will need to connect 2 routers to get both ac and n?
carboy is offline
Old 30th October 2018, 14:06   #1713
the_joker's Avatar
Thanked: 220 Times
This translation doesn't hold I think, because you are most likely starting from 2 Mbps (lower-case b, for bits), and arriving at 7.2 GB/hour (upper-case B, for bytes). That is, you missed the factor of 8 that converts from bits to bytes. Your 2 Mbps connection's upper end is only 900 MB/hour.
But you never achieve that theoretical maximum of 900 MB/hour, because:
1. The network latency to the backends of these streaming video services (which are probably in the US) will be high; and
2. India has officially blessed contention ratios in the range of 50:1; and
3. There will be protocol overheads.
I agree with all of your points. Just one clarification - I haven't made a mistake in converting from bits to bytes. My connection is supposed to be 25 Mbps. It reaches that speed (25 Mbps/3.x MBps) very rarely. I do get a consistent 2 MBps. My verification is downloading a 5 GB torrent in approx 1.5 hrs.
the_joker is offline
Old 30th October 2018, 14:55   #1714
Thanked: 5,645 Times
You mean you get 2 MB/s (Mbps) on your 25 Mbps link? Sounds about par. But 5 GB in 1.5 hours is actually only about 7.5 Mbps.
Also refer to the numbered points in my quoted post.
Lastly, torrents can be used to measure real download speeds only if you have sufficient seeders; and even then, the result wouldn't be comparable. For purpose of comparison, it is best to use a service like speedtest.net. This number has to match what you are paying for or you need to take them to task.
binand is online now
Old 30th October 2018, 15:32   #1715
Thanked: 708 Times
All the routers have backward compatibility. So the AC router has previous standard N as well. But whether the new router transmits farther that the old one would depend on the transmission power of the antenna. Again I am assuming both are transmitting on standard N on 2.4 ghz band.
Regarding parallel transmission on 2.4 ghz and 5 ghz, the routers have dedicated antennas for two bands. So same new router would transmit signals on both bands. Not required to buy 2 routers.
Old 31st October 2018, 19:10   #1716
Thanked: 15 Times
About six months back, I upgraded from an old Digisol N300 router to Archer C20 (AC750) router due to similar requirements as yourself.
My 2 cents:
1. I do not see any benefit of having an AC router over N router. I am still using all my devices on 2.4ghz because it gives you better range around the house.
2. The range is definitely more than my old router (2 antennae) as this has 3 antennae but the difference would be about 10-15%.
Given a choice today, I would either go for this - https://www.amazon.in/TP-LINK-TL-WR940N-Wireless-N450-Router-Modem/dp/B003Y5RYNY?ref=pd_h0_t&smid=A14CZOWI0VEHLG&ref_=pe _3139801_330486821
or spend a good chunk of money on those 6-10k Netgears/Asus/D-link with 5-6 antennae, if money is not the criteria.
5hadow is offline
Old 31st October 2018, 20:10   #1717
Originally Posted by 5hadow View Post
Given a choice today, I would either go for this - https://www.amazon.in/TP-LINK-TL-WR9...9801_330486821
So this would have better range than my current one because of the 3rd antenna? 10-15% extra is all I want. Almost 90% of my home is covered by the existing one - just a few corners aren't.
carboy is offline
Old 31st October 2018, 20:42   #1718
I don't think N is "previous" to AC in the evolution sense. Wifi evolved along two parallel tracks:
5 GHz: 802.11a -> 802.11ac track, and
2.4 GHz: 802.11b -> 802.11g -> 802.11n track.
Of these, 802.11n supports 5 GHz as well.
The number of antennae don't affect range directly, as far as I can tell. In 3-antennae configurations, one would dedicated for trasmission and the other two would be for reception.
Edit: Came across this article: https://meraki.cisco.com/blog/2011/0...tennas-matter/
[multiple antennas] can also have the secondary effect of increasing the usable range between the transmitter and receiver by requiring less repetition of data
Have you considered a repeater?
Old 31st October 2018, 21:22   #1719
Thanked: 15 Times
From TP Link's website, your current router:
https://www.tp-link.com/us/products/...specifications
The router I suggested:
Check - Reception Sensitivity for both and you should get some answers. The difference is worth at 54m. At other distances, its your call. If you think this is not worth then AC750 would be the same in terms of range.
5hadow is offline
Old 21st November 2018, 13:47   #1720
I got a new Dell Inspiron 5370 3 months back. It's good in every way, but I think the Qualcomm Wifi Adaptor in it is not that good as that of my earlier laptop. In the room where my router is setup, the laptop's wifi works fine, but if I go to the other room, the connection breaks all the time. I originally thought it's a problem with the router but now I think it's because of the new laptop.
I was thinking of buying an extender to solve the problem - is this is a good one - https://www.amazon.in/Netgear-WN3000...dp/B004XACSV2/
Is there anything cheaper I can try which is as good?
It looks like I can directly plug it into an electrical point, right?
carboy is offline
Old 23rd November 2018, 11:33   #1721
diyguy's Avatar
Thanked: 581 Times
The extender works well in my cousins home. Yes it is just plug into a power socket. The extender is a quick and easy solution.
If you want to try cheaper you can use an older router at home and use it as an access point by wiring it to your main router and this router would provide a different ssid in the distant portions of your house.
This is how I have wired my house. Earlier I was using wireless connectivity between routers but this would drop occasionally due to the beam rotations and hence moved to wired connections between my routers.
diyguy is offline
Old 23rd November 2018, 11:43   #1722
paragsachania's Avatar
Thanked: 27,159 Times
I am using a TP Link Range extender since a year now. Definitely happy with it to say the least. It is a viable solution for weak signal issues in a large house.
I am on 100 Mbps connection. While I get the promised speeds in the Hall when connected to the main router, The same connection would earlier drop when I walked to my room where I my working desk was located.
With the extender, I connect to the SSID related to it and get speeds around 40-60 Mbps but with 100% signal strength.
All in all, the extender is doing a great job and its simple plug and play, compact and easy to configure. I have also configured it to stop emitting the LEDs on it between 20:00 and 06:00 as they are quite bright and an irritant when faced directly at night.
paragsachania is offline
Old 23rd November 2018, 12:17   #1723
When a laptop or a phone has access to two SSIDs (the main router & the extender) would it automatically connected to the stronger one - i.e. depending on the room, I want it connect to either the main one or the extended.
carboy is offline
Old 23rd November 2018, 12:44   #1724
Typically the device upon sensing very weak signal and finding another stronger one would automatically disconnect from the current SSID and connect to the one linked to the extender.
I have configured the extender with a different SSID. I mostly do my office work and stream online on TV using this extended network only. So all the devices in this room automatically connect to the extended Network.
However, when I walk into the main room where the router is, the extender shows good signals that I rarely have to connect to the parent SSID. But let us way that I enter my home through the main door, it connects to the Router's SSID than the extenders.
You can always have same SSIDs for both the main and the extended network but the drop out and connection would not be seamless from what I have learnt because the device still has to disconnect from one and connect to the other.
Old 23rd November 2018, 12:47   #1725
Is the extender's signal stronger than the main one in the main room or equivalent? That's the scenario, I am asking about?
In my other room, the signal is not always weak enough to not work. It would work 90% of the time, but if I can my position mildly it will drop.
carboy is offline
