Hello, it is I.
Allow me to elaborate on your predicament.
5.1 Audio cannot be transmitted through 2 jacks. it can either be transmitted digitally (using wither an optical or coaxial cable) or through 6 different audio cables.
In your case, the combination of products is correct. You have an Altec Lansing 5.1 channel system, with no digital decoders onboard and to compensate that - you have a DVD player with an onboard decoder.
Now let us consider your photos.
Unfortunately picture number 4 has flash glare so I cannot read which inout is what on the Altec. However I will assume that the 3 EP inputs (EP stands for earphone size) are stereo each, thus allowing 6 sepearate inputs. A rather stupid input module, if I may add, but one that works.
Logic tells me, one pin is for left and right front, another for left and right surround and the 3rd for Centre and Subwoofer. (Most probably the black one)
Under ordinary conditions, the 3 stereo EP jacks would be connected to a 5.1 out sound card, which also has Stereo EP outputs.
However in the case you wish to connect it to a regular DVD, AL has provided these Stereo Female EP to 2 RCA connectors.
Now, assuming you are not completely confused, let me tell you that picture number 6 is correct. Connect another RCA connector exactly on top of it, to the 2 rear out.
The 3rd connector will go to sub out, couple with centre, thus making it 90 degrees to the other 2.
Now connect the 3 male sterep EPs to these 3 connectors.
It may still be that only stereo works. In this case:
Insert a Dolby Digital (or DTS) DVD into the player and switch your TV on. Go to the setup of the player (not the menu of the movie, but the setup of the player) and you will see an option for Audio - Stereo or 5.1. Choose the 5.1 option.
By default your samsung probably assumes you do not have a 5.1 system and will connect the stereo output of the DVD to the stereo inout of your telly. It therefore downmixes the audio into stereo and passes it out, just like stool. (I was actually checking to see if you are still reading)
You must inform the player (using its setup menu) that you now desire for the 5.1 analog outputs to be active.
Good Night.
Sam. |
