Old 10th March 2025, 09:11   #7771
sandeepmohan's Avatar
Thanked: 6,045 Times
Re: The home / office air-conditioner thread
Originally Posted by IshaanIan View Post
Yes it will be a commercial setup. Any pointers on what kind of HVAC commercial system would be applicable? I have zero experience outside of the ACs that we normally use at home.
You need to start with a proper heat extraction system. Fans or exhausts positioned properly to take the heat out of the space. You need get rid of the heat source first. Once you have this sorted, then you can introduce Air conditioning into the space. Consider air conditioning as something supplemental to the heat extraction system. Both need to be present.
There are air conditioning systems tailored for commercial kitchens. They have the same oil extraction filters, like you do for a traditional kitchen extractor. The outer casing is also built to withstand oil and smoke.
As another FM said, consult a professional in the space.
Old 10th March 2025, 11:00   #7772
Thanked: 3,001 Times
None, I'm afraid. Our member Aroy might post something useful. Kitchens is not only commercial, but a specialist area of commercial.
Thad thanks for your confidence.
Actually installing Air Conditioning in a commercial kitchen involves a lot of calculations.
. Heat load of the cooking stoves
. Heat load of the workers
. Heat loss due to chimneys and exhaust fans
. Heat loss due to constant traffic to and from the kitchen
All the above points are considered when sizing AC for commercial use. It is best done by the manufacturer's HVAC experts.
Aroy is offline   (2) Thanks
Old 10th March 2025, 12:11   #7773
sagarpadaki's Avatar
Thanked: 6,792 Times
Thanks this confirms my initial suspicions on the topic of having an AC installed in a kitchen. Is regular filter cleaning not enough to remedy the issue? Or will the added grease and oil buildup affect other parts that are inaccessible in terms of maintenance? Thing is the kitchen is not a home setup and will be running hot for long durations. Are there any alternatives to cooling the place down other than a desert cooler? I am looking for ultra effective yet silent fans at the very least. Hyderabad summers are terrible so hot and dry and if the kitchen runs even hotter you can get a heatstroke within 30 minutes which is something I want to tackle asap before this month becomes as hot as it is predicted to be.
I think you will need multiple units in the kitchen with a fan to circulate the cool air across the kitchen area. I remember seeing a kitchen in one of the restaurants which had three 2-ton split AC placed some distance apart and a few rotating stand fans to circulate the cool air around. The kitchen was in rectangle shape and the AC's were placed on the opposite wall where the hobs, stoves and chimneys were present. The distance between the walls was around 15 feet so I assume the oil and grease from the other area may not travel 15 feet backwards to clog up the AC. But yes, the filters may need cleaning very frequently
sagarpadaki is online now
Old 10th March 2025, 13:18   #7774
Thanked: 470 Times
Originally Posted by revintup View Post
2025 Feb : The AC is only drawing in 250-350 watts. LG guys are called again, they dismantle the IDU and pressure wash both the IDU and ODU. They check gas levels and says its normal. But even after the wash, its only working at <600 watts. I report the issue again and they are clueless and insists there is nothing wrong with the sensors.
UPDATE
LG dismantled the AC again, and took both the IDU & ODU to their service centre. They said they will clean it more thoroughly using some chemicals and a washer which works at a higher pressure. They kept the AC for 2 days and reinstalled it on Saturday. The cooling is back to normal. Its working at almost 900 watts (in turbo mode) now. So yes, am happy with the results.
I have to say LG attitude was very good throughout. The initial water wash cost Rs 885/-. The second time, they did not charge me anything at all.
In the end I think that the LG AC is highly sensitive to dust clogging, this could be due to some inherent design issues. Am planning to water wash the AC every 6 months from now on.
I have ordered an 'Airth' external air filter on Amazon in the hope that it will reduce the dust getting into the AC. This is mounted on top of the AC. Yes, this might 'choke' the AC, reduce the airflow and cooling but I would rather have reduced cooling due to restricted airflow than clogged interiors which would mandate dismantling every year.
revintup is offline   (5) Thanks
Old 12th March 2025, 07:54   #7775
Interesting product. Let us know how it performs.
If its going to choke the AC resulting in reduced cooling, thats not so useful is it? Thats only going to lead to higher energy consumption which then defeats the purpose of a high efficiency Inverter Aircon.
The better approach is to shorten the service intervals. Clean the filters more frequently, vacuum the IDU coils.
Old 13th March 2025, 17:22   #7776
NPV
NPV's Avatar
Thanked: 11,168 Times
Planning to get an AC for a study room of about 100 sq. ft. area.
Any feedback on Daikin’s FTKL35U 1 Ton AC (R32 refrigerant)?
It’s a 3 star appliance and costs about 39k plus installation.
NPV is offline
Old 13th March 2025, 17:40   #7777
Thanked: 3,686 Times
Infractions: 0/2 (19)
If you are considering Daikin 1 Ton, then please don't go for this model,
https://www.croma.com/daikin-premium...v16w-/p/248175
The above option is much better as it is 5-star and similarly priced.
bijims is offline   (2) Thanks
Old 13th March 2025, 17:52   #7778
UPDATE
I would not suggest any external filter. I suggest cleaning the inbuilt filters more frequently - Like once every month.
The external filter can impede air flow.
sagarpadaki is online now   (2) Thanks
Old 13th March 2025, 18:24   #7779
LG design is basically for low dust areas. The inlet is on the top, definitely a dust magnet. I clean the filter every week normally and twice a week when there is a lot of dust in the air. In spite of that the fine dust particles (not trapped by the filter) accumulate and within three months (coupled with moisture) choke the IDU heat exchanger. The ODU also accumulates a lot of dust but some how it is less prone to chocking compared to IDU.
At one time I thought of installing HEPA filter in place of the normal filter, but have not done so as yet. HEPA filters especially Industrial Types are a high thruput low resistance filters, so would not create much resistance. At the same time the filter intercepts much finer particles. The only hitch is the cost as they are single use and cannot be cleaned.
Aroy is offline   (3) Thanks
Old 14th March 2025, 09:16   #7780
I have not come across an aircon off late where the inlet isn't at the top. Those were the really old aircons that had them up front. I think manufacturers switched to a top intake for better air draw and for aesthetic reasons.
You definitely qualify for using a HEPA filter. If you won't be spending the money here, you most certainly will at the Doctors. Respiratory issues are not worth it.
Alternatively use a good air purifier for times when the aircon isn't running. For a high dust environment, your options are limited.
sandeepmohan is offline   (1) Thanks
Old 14th March 2025, 11:53   #7781
Thanked: 406 Times
I have just booked a voltas 5-star inverter 1 ton for 42 odd with 4 year comprehensive extended warranty from brand itself. I already have one and have been very pleased with its performance, especially with the Mumbai heat and dust.
jomyboy is offline   (1) Thanks
Old 14th March 2025, 13:49   #7782
Thad E Ginathom's Avatar
Thanked: 29,944 Times
We use one in our main hall even when the AC is running. AC filters only block fairly large particles compared to a proper purifier.
My guess on AC inlet design is that being on top draws in hotter air and being above the outlet draught means not drawing cooler air straight back in.
Thad E Ginathom is offline   (1) Thanks
Old 15th March 2025, 16:21   #7783
NPV
NPV's Avatar
If I buy the product online from Croma or other sites, what are the options to get the installation done ? Are there any recommended online options for installers as well?
NPV is offline
Old 15th March 2025, 18:32   #7784
Thanked: 789 Times
Urbanclap offers installation services. I haven't used then for installation but I have used then for gas refill. They were good with 6 month warranty. In fact I availed warranty and they came back to recharge gas again.
shipnil is online now   (2) Thanks
Old 15th March 2025, 18:58   #7785
Normally, at least in Metros, you have option of either getting installation by the manufacturer, or by the seller (Chroma, Vijay Sales etc.).
I have always got installation by manufacturer whether bought online or in retail store. In fact many times there are schemes for zero or low cost installation by the manufacturer tied to some e-retailer or store. That is how I got free installation for my Slit AC once, at half price once when buying from Paytm (6 years ago) and online.
Other appliances - refrigerators, microwaves and ovens come with free installation by manufacturer, immaterial where you buy it from.
Aroy is offline   (1) Thanks
