Old 27th May 2019, 13:27   #6256
Prowler's Avatar
Thanked: 1,403 Times
Re: The home / office air-conditioner thread
Meltdown, really? Do you have a picture of these metal jackets? I'm really curious. Even Google isn't of much help here.
I have had a few burnt sockets and plugs. Fortunately by the time the wires started smoking, I was around to stop. This happened even with my earlier 3 KVA UPS. Then I replaced every 15 A sockets with full metal jackets.
I am showing images sourced from the internet as I can't locate my own images.
The second image shows the metal wall socket.
The home / office air-conditioner thread-burntplugandsocket.jpg
Prowler is offline
Old 27th May 2019, 14:13   #6257
Thanked: 3,001 Times
The home / office air-conditioner thread-51izwyertl._sl1000_.jpg
I used this a lot in past
Aroy is offline
Old 27th May 2019, 14:17   #6258
Thanked: 12,175 Times
Infractions: 0/2 (11)
Thanks! Ah, this is what they use abroad, but in India, they take a lot of liberties. Do you suggest using this for all geysers (as well) right?
Sebring is offline
Old 27th May 2019, 15:03   #6259
Prowler's Avatar
There is a caveat here. The metal body needs to be securely grounded for this so that it doesn't electrocute the user in a bathroom with wet fingers. So use this to connect the water heater but use a standard 15 A switch at the user level to control the heater.
My intention here is not to scare any one. I am just pointing to the Murphy's Law:(simplified version) - If anything can go wrong, sooner or later it will go wrong.
Don't smoke from your bed - for the ashes falling down may be your own.
Prowler is offline
Old 27th May 2019, 15:46   #6260
Geo_Ipe's Avatar
Thanked: 3,657 Times
The AC fuse at home started tripping yesterday. I called my electrician who says the wiring, plug and main fuses are all intact. He has asked me to get the AC unit checked. What all are the possibilities I need to keep in mind when the technician turns up??
I have a 1.5T Blue Star window AC unit.
Geo_Ipe is online now
Old 28th May 2019, 00:16   #6261
diyguy's Avatar
Thanked: 588 Times
The tripping is usually due to a failed or leaked capacitor in the outdoor unit. Has happened to me twice on two different acs over the past 10 years or so. The trip was happening when the compressor was starting on both occasions.
diyguy is offline
Old 28th May 2019, 02:35   #6262
Thad E Ginathom's Avatar
Thanked: 29,939 Times
No, I don't think so. Thing is that the pug/socket combo being spoken of is rated at 20 (?) amp --- higher than the small or large 3-pin stuff in the rest of the house. In my relatively limited experience, these things are routinely used for AC units in India. It's not as if they are expensive even.
I hate them! They are sooo fiddly to wire up. And it just doesn't make sense to me that these plugs for highish-current devices should be made out of metal.
But they seem to be the thing for the job.
Thad E Ginathom is offline
Old 28th May 2019, 09:33   #6263
sgiitk's Avatar
Thanked: 4,808 Times
@ARoy; there are some plugs with solid brass pins where there is no problem. Also, Northwest has introduced a 25A plug (same matrix as 15A but longer pins). I think the main issue is the quality of pins in the plug.
sgiitk is offline
Old 28th May 2019, 09:42   #6264
Prowler's Avatar
The metal plug/socket is usually rated at 30 A. They have adequate space between terminals.
With conventional plu/socket - the heat builds up when there is poor connection (contact surface) between the plug and the socket. When it heats up the insulation in the wire melts and the plastic socket starts breaking down starting a chain of events.
With metal plug/socket - it doesn't happen because it is generously rated and have more brass/copper contact surface. The metal enclosure also acts as a heat sink in limited capacity.
Prowler is offline
Old 28th May 2019, 10:45   #6265
Thanked: 206 Times
Anyone knows of solar AC supplier or manufacturers? What would be the approximate cost for 1 tonne capacity?
_chikku is offline
Old 28th May 2019, 11:18   #6266
Instead of plastic, these sockets have porcelain which is another factor against burning.
Aroy is offline
Old 28th May 2019, 12:31   #6267
Prowler's Avatar
Yes Sir. I was looking to thank you but found that there is no Thanks button in this thread.
Prowler is offline
Old 28th May 2019, 15:27   #6268
samaspire's Avatar
Thanked: 5,428 Times
I have a problem. I installed a Godrej 1.5 ton 3-star inverter AC in my office about 3 months ago. Due some complaints from shops below us, I realised that my AC's water output is a lot more than normal. The water used to drip in front of these shops the entire day. I started collecting the water in a bucket and found that one and half bucket gets filled from 10:00 am to 9:00 pm.
I complained to the service center and they say its normal output for AC's with R-410-A gas. Is it normal? If it indeed is normal, then what do I do with the water. Piping it away is not an option. At present I'm dumping the water twice a day.
samaspire is offline
Old 28th May 2019, 16:04   #6269
Drying the air is a normal function of AC machines. I don't see what the gas has to do with that
Anything abnormal in your IDU? Like ice forming or dirty fins?
Old 28th May 2019, 16:09   #6270
ms001's Avatar
Thanked: 299 Times
It is very normal for any AC to expel this much water .
The only option is to have a proper piping to take the water down .
ms001 is offline
