Old 2nd May 2018, 02:43   #5761
sandeepmohan's Avatar
Thanked: 6,043 Times
re: The home / office air-conditioner thread
Originally Posted by nik0502 View Post
I know on paper Blue Star looks like a great deal. .
It is. I would put my money on a product that extends the warranty well beyond the usual compressor. It is another indicator that they are supporting the product long term as well as a hint that things should ideally not go wrong. Confidence in the product too.
Blue Star service isn't in the league of LG for sure. They are okay and the service network is huge.
The focus of their business is indeed commercial. They have not ignored the home sector though. In fact, I think the have expanded more into the home sector. Compare their product listing from 10 years ago. It was probably limited to 3 models each in Window and Split. Today, the product list is huge for Window and Small Capacity Splits for home and office.
sandeepmohan is offline
Old 2nd May 2018, 17:51   #5762
Thad E Ginathom's Avatar
Thanked: 29,938 Times
The focus of their business is indeed commercial. They have not ignored the home sector though. ... ... ...
Thanks for the update. Their products do look interesting.
Our hall second-hand mix'n'match failed again last week. I was actually dreaming new AC! and could even afford one just now, but our local man (who supplied it) reported that some refridgerant filter was clogged and fixed it in a few minutes. Well... the longer it lasts the better. Looking forward to increased reliability and longer warranties on inverter machines in a year (or even two)! Although it is going to be hard to convince wife to let me buy inverter!
Thad E Ginathom is offline
Old 2nd May 2018, 20:02   #5763
Geo_Ipe's Avatar
Thanked: 3,657 Times
...But what I want to know is how does Blue Star as a brand fair against the likes of Daikin & Hitachi?
I've been using a Blue Star 1.5T window unit for the past year without any issues.
I've called for service only once - routine filter cleaning - and their response was very prompt.
Geo_Ipe is offline
Old 2nd May 2018, 20:23   #5764
Thanked: 34 Times
I too own a 2017 bluestar split AC, which is five star rated and use R32 gas. It's provide good cooling and pretty satisfied with blue star support. I do have Panasonic, LG and Samsung and have to say cooling wise bluestar exceeds where in Panasonic do have more features. Bluestar do have an mobile application though which you can raise a service request . In cochin their support team is really good not sure about other locations.
speedgun is offline
Old 2nd May 2018, 20:53   #5765
Thanked: 697 Times
Thanks for the inputs guys. So Blue Star it is. Will buy it on the weekend.
While going through the specifications I realised that it's supposed to be better when it comes to cooling than the Daikin I just bought since the cooling capacity of Daikin is 5200 while the same for Blue Star is 5400. Also this one is a 5 star model as compared to Daikin which is a 3 Star. Also Daikin has one year warranty as compared to 5 on Blue Star and Blue Star also has a temperature Display which is missing in Daikin. Overall very good package. Now I am feeling I should have looked for it before and should have got Blue Star instead of Daikin which I just bought.
nik0502 is offline
Old 3rd May 2018, 08:27   #5766
adimicra's Avatar
Thanked: 2,496 Times
Can you share the bluestar model and price please?
I was reading about inverter ACs and it seems they can offer a faster cooling compared to similar capacity non-inverter ACs as they can work at higher capacity than the rated capacity. For example - Carrier 1.5 ton inverter ACs have cooling capacity from 2500W to 5900W (rated capacity 5300W). Carrier 2 ton NON-inverter AC have cooling capacity of 6200W. Is that true? If yes, then I might go for 2 1.5 TON inverter ACs for the hall rather than 1 1.5 and 1 2 ton AC. Hall size is approx 400 sft.
Also, what is the feedback on carrier and bluestar ACs? Are those preferred over brands like LG? I am also looking at LLoyd AC - good specifications and value for money. Voltas ACs seem to be cheaper but I am not hearing good feedback.
adimicra is offline
Old 3rd May 2018, 10:46   #5767
sgiitk's Avatar
Thanked: 4,808 Times
As far as I am concerned the unit must support the latest refrigerants ie R410a. Most Splits need topping up in four to five years, so R22 is a big no. The 'best' are reputed to be General and Daikin. I understand that Panasonic are also quite close.
sgiitk is offline
Old 3rd May 2018, 14:27   #5768
Thanked: 311 Times
SG, you've been saying this for years! May I inform you that this is India and R22 is freely available! LG's own technicians will do the job for you (just as an example)!
anupmathur is offline
Old 3rd May 2018, 15:00   #5769
sgiitk's Avatar
@anupmathur; R22 is being banned I think two years down the line. So I wish you luck. Now I am told even window units have started doing away with R22.
sgiitk is offline
Old 3rd May 2018, 18:25   #5770
Thanked: 34 Times
As far as I know R32 is superior to R410a. But most inverter ac uses 410a where's as 5 star rated non inverter uses R32. Blue star non inverter I purchased comes with R32.
speedgun is offline
Old 3rd May 2018, 18:36   #5771
skchettry's Avatar
Thanked: 198 Times
I far I know R32 is superior to R410a. But most inverter ac uses 410a where's as 5 star rated non inverter uses R32. Blue star non inverter I purchased comes with R32.
Indeed my understanding is also the same. R32 and R410a both have the same Ozone Depletion Potential (Zero), but the global warming potential of the later is higher. Companies are moving from the later to the former.
skchettry is offline
Old 3rd May 2018, 20:32   #5772
Thanked: 697 Times
Which home/office AC (air conditioner) to buy ?
Please find the details attached. From my limited knowledge General is supposed to be the best of the lot followed by Daikin. It's mentioned in the previous posts as well however General is very pricy and Daikin is very boring. I just bought one 2 weeks back. Like Daikin Blue Star also deals in commercial units. So supposed to be better than generic brands like whirlpool etc.
The home / office air-conditioner thread-imageuploadedbyteambhp1525359657.414272.jpg
nik0502 is offline
Old 3rd May 2018, 22:36   #5773
So YES the more electronics, the more chances of a large bill. Recently a few manufacturers have started including Electronics in their extended warranties. I hope that this trend will increase till all manufacturers include the Electronic components in a 3 to 7 year extended warranty.
So. Shall buy extended warranty for my Samsung Inverter AC from Flipkart subsidiary Jeeves ?
They are offer 2 year additional extended warranty on the manufacturer warranty, so will get 3 years in total.
Or shall buy a good Voltas stabilizer instead ?
Which good idea ?
raddy is offline
Old 4th May 2018, 00:12   #5774
adimicra's Avatar
Sorry, I am unable to read the details regarding the model number from the pic above.
However, as I see in this thread, bluestar is having pretty good feedback. Anyone has experience with their service?
AS I am checking the prices, bluestar seems to be pretty expensive and at par with Daikin. In that case, doesn't it make sense to go for Daikin instead? I have a 1.8 TON Daikin AC in the hall of my current house and the cooling is fantastic and noise levels are very low.
Any feedback about Carrier? Seems to be in the same price range as LG.
adimicra is offline
Old 4th May 2018, 00:18   #5775
F150's Avatar
Thanked: 926 Times
I would pick Daikin any day, over all the other brands you mentioned in your post.
F150 is offline
