Old 10th July 2013, 17:58   #31
Thanked: 85 Times
Worldtech Video Problem
I own a Worldtech Reverse Camera Camera + Sensor but am unsure on what video format works if I want to play with USB Pen drive? I have tried a couple of MP4 formats etc. but maybe the codec used is not the compatible one, so they do not play. Anyone can help?
In addition I would also like to know whether any specific software is needed to convert any video into that format? Eg: I have Total Video Converter and I also have Replay Converter installed on my comp.
Is there any guide available for the same?
Thanks,
Vikram
vikramv4u is offline
Old 15th July 2013, 19:41   #32
Thanked: 719 Times
Re: Worldtech Video Problem
It should be able to play the mp4 files from USB or SD card. However, most of these units have a sub-par processors & memory so can only play the lower profile mp4 files, the very reason why you're not able to play your existing files. You can use DVD-fab to convert your files, the profiles may be a zune or iphone or a similar mobile device.
nitinbose is offline   (1) Thanks
Old 15th July 2013, 21:44   #33
Thanked: 85 Times
Thank you very much for the reply. Let me try it out. In the meanwhile if anyone else owns this device or has any first hand experience, I would love to know what exactly works..
Thanks again!
Old 16th September 2013, 12:10   #34
condor's Avatar
Thanked: 16,862 Times
Re: Audio / Video Codecs, Converters & Decoders
Not sure if this is exactly a codec question.
I want to use my laptop as output device for playing audio files.
1. I cannot install any additional software on the laptop
2. I cannot use USB drives on the laptop
3. Laptop has Windows media player, and runs Win 7
Hence I am trying to play the tracks on a portable media player & connect the output of the mp3 player into the mic port of the laptop, using a 3.5mm connector cable.
but WMP doesnt sing .. what gives ?
condor is offline
Old 16th September 2013, 12:23   #35
Arch-Angel's Avatar
Thanked: 286 Times
The Mic in would take the input from a microphone only. You need to give the input to the line in of the laptop. This is something I recollect doing while converting old cassettes to audio files.
Edit: please look at this link as well.
http://windows.microsoft.com/en-in/w...-your-computer
Arch-Angel is offline
