Old 5th April 2012, 16:11   #451
Thanked: 306 Times
Re: Inverter Batteries
Anyone here used NorthStar batteries ???
They have three series. Red, Silver and Blue. Red for stable grid conditions, Silver for Stable to semi stable conditions and Blue for unstable conditions.
Any pointers or some one using them ???
low_bass_makker is offline
Old 7th April 2012, 14:01   #452
Thanked: 1,911 Times
I have a Microtek 800 VA sine wave inverter (Model 800EB) with Exide IN1500 150A battery. Both are around 4 years old. I bought it when I was in Pune. I think the battery is on it's last legs and I would need to replace it soon. Now in Bombay, power cuts are not frequent, so I want to go for a lesser capacity battery - what's the lowest I can go for (typically I want to run 2 fan, 2 tubes and a 155 W TV) - I think a 80 AH battery should be good enough for a 2 hour backup. Are batteries available in 80 AH capacity & what do they cost?
If I was under proper Bombay electrical supply, I would junked the inverter. But Mulund is under MSEDCL (maharashtra electric supply rather than Bombay), so the occasional power cuts do happen.
The inverter consumes quite a lot of power, most of it at stand by, that is when there is power and the battery is full, but the inverter keeps the battery at a slow charge.
. Normal over all efficiency of an inverter is 80%, so you are loosing 20% power.
. The standby current in an 800VA unit can be as high as 0.5A, so you are loosing 1/8 (KW)*24(Hours)*30(days) = 720/8 ~ 70 units per month
Does the power consumed because of the inverter depend only on the inverter rating or also the battery capacity connected to it?
Also, let's say you are going on vacation - what do you do to switch off the charging. There is an on/off switch on the inverter & there is also a on/off switch on the wall (fixed by the installer) - which is the one to switch off?
carboy is offline
Old 7th April 2012, 19:14   #453
Thanked: 3,001 Times
There are threeo parts to it.
1. The power consumed by the Inverter under no load. This is the power required to run its controller. Can be as low as 50W and as high as 150W.
2. The efficiency of the Inverter under low load. The efficiency approaches 80%+ at full charging load, but tapers off to low 20's under low load.
3. The self discharge of the battery. The higher it is, the more charge it will loose and hence more the inverter has to charge it to top up.
So in effect if you are not going to use the Inverter for some time, you are using up between 50W and 200W for just keeping it on stand by. Best to
. Switch the inverter off.
. Disconnect it from mains.
. Ideally you should also disconnect the battery terminals, so that no current leaks from the battery into the Inverter circuits.
Regarding the minimum battery size. The smallest I have seen in an 800VA Inverter is 80AH. But remember that 80AH capacity is for 20 hours discharge rate. for a 1 hour discharge rate the capacity is derated to about 30AH. What this means is that
. for 20 hours you can have 4A discharge = 4 x 20 x 12 = 1200VA
. for 1 hour you can have 30A discharge = 30 * 1 * 12 = 360VA
Aroy is offline
Old 7th April 2012, 20:35   #454
Does this happen normally? And what are the repurcussions?
I really didn't understand this at all!! Can you explain this again for a layman?
carboy is offline
Old 7th April 2012, 21:00   #455
1. Whenever any circuit is connected to a power source (battery here), the circuit consumes power. So if the battery is connected, the inverter will consume some power (how ever little), draining the battery over time. This can avoided by isolating the battery - switch or disconnect the terminals.
2. When you have a capacity rating of a battery, that capacity is in Ampere-Hour : current x time. The rating is either at 20 hour, 10 hour, 5 hour or 1 hour discharge rate. The capacity reduces as the total discharge time reduces. For example :
. 80AH capacity is for 20 hours discharge, that is 4A/hour for 20 hours
. 30AH capacity is for 1 hour discharge, that is 30A/hour for 1 hour.
The ratio of 30AH and 80AH is the derating factor, which in this example is 30/80 = 0.375 or 37.5%. Depending on battery design the derating factor for 1 hour duty, can vary from 50% to 5% of the full theoretical hour capacity.
I hope I have been able to explain this properly.
What is important to note is that when you calculate the time your inverter can give you power, you have to incorporate
1. Efficiency of the inverter, converting DC to AC, where you can safely assume 80%.
2. Derating factor for the time the inverter will deliver power. For normal home use where power is required for maximum 5 hours, a derating of 50% suffices. For large installations, without generator back up you design for 10 hours of backup, so derating will be 80%. For computer UPS where 1/2 hour time suffices, a derating of 70% may be required.
Also note the maximum battery life for lead acid batteries is at the rated 20 hour discharge rate. The higher discharge rate the shorter the battery life.
Aroy is offline
Old 17th April 2012, 14:14   #456
cooljai's Avatar
Thanked: 28 Times
Checked with a couple of dealers in Bangalore and none of them are supplying Exide IT500's. They say its in short supply as the stocks are getting diverted to Chennai/TN.
Is there someone here who knows a reliable supplier in Bangalore (Near Kammanahalli) who can give a good price for the battery as well as the inverter (Preferably APC)?
cooljai is offline
Old 17th April 2012, 14:36   #457
anujmishra's Avatar
Thanked: 529 Times
APC is worst inverter in my terms and way expensive. Till recently they were selling Square Wave inverter for the price more than Sukam Sine Wave inverter.
Why are you so inclined towards APC? There are other very good brands like Sukam, Microtek, TruePower, VGuard etc.
Regarding battery, I would not advice you to go to Exide. These Exides are prone to early failure. You can find Amaron, Amco, Sukam battery etc. for longer and trouble free life. My 2 cents. Decision is in your hand.
anujmishra is offline
Old 17th April 2012, 15:35   #458
gopikb's Avatar
Thanked: 405 Times
I can second that. I have been using a sukam 800VA inverter since the last 7 years and it has been serving us well. For battery i have exide inva tubular battery which comes with 5 year warranty. Been ok since the last 3 years
gopikb is offline
Old 17th April 2012, 16:39   #459
esteem_lover's Avatar
Thanked: 513 Times
Guys, I have been quoted the following, please let me know
APC 850VA - Rs.7,500
AMCO 180 Ah - Rs.14,500 (2 years replacement warranty + 1 year service warranty)
Total, after a small discount - Rs. 21.5k. Is this a fair deal ? We have 10-12 hour power cuts everyday.
esteem_lover is offline
Old 17th April 2012, 17:53   #460
cooljai's Avatar
Thanked: 28 Times
@esteem_lover
If its APC BI850Sine, your quote seems to be on the higher side.
I had quotes starting from 5800 to 6500.
cooljai is offline
Old 18th April 2012, 13:19   #461
geeash's Avatar
Thanked: 146 Times
Guys what's the difference between exide Invatubular and invared battery. It500 is out of stock in chennai. My dealer is suggesting invared 150ah saying only difference is warranty my batteries died out I want to get one as soon as possible. Can someone help me
geeash is offline
Old 18th April 2012, 16:03   #462
aks_karthik's Avatar
Thanked: 342 Times
Yesterday I have installed Inverter in my house.
Inverter : Sukam Falcon 800VA/12V(2 Years Warranty) - Home Solutions | UPS - Pure Sine Wave | Falcon
Battery : Base Tuff Tubular BT 15000 (2+2 Years Warranty) - http://basebatteries.com/Product-Des...Tuff (Tubular)
I have bought it from my friend who is the dealer, So i got the whole things for 17K including Transport and Electrician.
aks_karthik is offline
Old 20th April 2012, 10:53   #463
racer_m's Avatar
Thanked: 147 Times
I got a quote of 14K all inclusive with fitting for
Sukam Shiny 650VA/12V(2 yrs warranty)
Sukam Conquerer 1500BT Tubular (150AH) battery (48 months Warranty)
Want to know if Sukam Batteries are good or should I choose Exide, Base or Amaron?
racer_m is offline
Old 20th April 2012, 11:30   #464
Thanked: 342 Times
I don't think, there's a big difference with Battery provided some extra care and service monthly.
BUt heard Exide is good for Inverters but too costly compare to other brands.
Old 20th April 2012, 16:41   #465
moralfibre's Avatar
Thanked: 14,427 Times
Has anyone here used Autobat batteries? I have never heard of this Made in Pune brand. All inverter dealers I called so far are swearing by it. They have a 2 year free replacement warranty and a +3 year prorata replacement warranty with the battery.
I am happy with brands like Exide / Amaron, etc.
moralfibre is offline
