Old 21st February 2016, 16:09   #3496
JMaruru's Avatar
Thanked: 426 Times
Re: Nuvi 55LM india maps?
By NA I hope you mean North America?
For India
- You can buy the Map My India maps which come in an SD card.
- For free maps; look at OSM maps (Open Street Maps).
Having made the points above, MMI are the best maps for India. (As far as my experience goes).
How do we install OSM maps on the garmin device?
I see many a folders under the root on the device. Earlier, if i remember right we used to copy the map image into the root>garmin folder.
JMaruru is offline
Old 21st February 2016, 16:29   #3497
ampere's Avatar
Thanked: 13,599 Times
- Install Basecamp on Windows/Mac. This is the S/W which helps installing/transferring maps/waypoints/tracks etc to/from your Garmin device.
- Then you need to install the maps on this base s/w. After this you use this s/w to transfer the map to the device.
- Goto : http://garmin.openstreetmap.nl/
- Select Garmin Routable.
- Download OSM maps by select the tiles that you need (India) and then the site compiles the map and sends you a link, once done. (Choose the platform Windows/Mac).
- One it gives you the source; download and install the map on the S/W
- Once done, you can transfer the map to the device from Basecamp.
Hope that helps. Please note OSM are free maps.
ampere is offline
Old 21st February 2016, 16:38   #3498
JMaruru's Avatar
Thanked: 426 Times
- Install Basecamp on Windows/Mac. Please note OSM are free maps.
I am not able to install basecamp on my windows 7 machine, as it is asking for windows media player v11 or newer. It prompts me to open a link which takes me to microsoft site, where there is no option provided to download media player for windows 7.
So either I need to get this media player on my machine, or need to find a way to move maps into the device without basecamp.
JMaruru is offline
Old 21st February 2016, 16:46   #3499
ampere's Avatar
Basecamp is a Garmin S/W which ideally should not depend on media player. No idea. You some how need to get it installed. Thats the cleanest way to install maps/waypoints on device. I was able to do on my Win-7 machine quite some back. Should work.
Is there where you are downloading it from?
https://www8.garmin.com/support/down...ls.jsp?id=4435
I have been using it on both Mac and windows for the last 4-5 years now.
Please Note: Dont know if others too realise this;
- Basecamp (Earlier Roadtrip for Mac and Mapsource for Windows) is a brilliant way to consolidate all your travel data into one place.
- You can keep all your data logs of drives, way points, route plans etc on this software
- You can also export that data on to GPX/GDB formats and keep a back-up on cloud.
ampere is offline
Old 21st February 2016, 16:57   #3500
JMaruru's Avatar
Thanked: 426 Times
Yep! I have downloaded the same. But when try to install, it is looking for media player. I don't how media player was NOT installed along with the pre-installed windows 7 OS on my dell XPS m/c.
JMaruru is offline
Old 22nd February 2016, 21:59   #3501
DerAlte's Avatar
Thanked: 2,920 Times
Re: The GPS/Maps Discussion Thread (Dedicated Satnav, Smartphones, Tablets, etc)
Alas, my Garmin 260W has stopped recognizing the SD Card! :( The unit is working fine otherwise, recognizing satellites and recording the route traveled (GPX). I had the India map in the SD card (the built-in map was North America, and I had Europe and India in the SD card).
It is a problem in the unit I guess, since the SD card doesn't show up in the Storage Device connection mode - neither on Mac nor on PC. Need to open the unit and check, but feeling too lazy.
DerAlte is offline
Old 22nd February 2016, 23:33   #3502
ampere's Avatar
@DA You should still be able to install the maps on the device's internal memory via basecamp. See if that works for you?
ampere is offline
Old 27th February 2016, 08:12   #3503
JMaruru's Avatar
Thanked: 426 Times
What is the difference between 'OSM Base Map' and 'Topographic' downloads? Which download would give me a garmin compatible map images?
I just want to copy the map image to the external card on the garmin device.
Please advise.
JMaruru is offline
Old 27th February 2016, 10:02   #3504
ampere's Avatar
Topographical typically also includes terrain data. But where is that its being asked on the site? Chose generic routable and select India. On Selecting India, the site will select all India specific tiles. It will then create the image and will mail you the download link.
You should be able to copy that image to the SD card and when you select maps it should show up. The reason, I suggested basecamp option is because, its then easy manage your way points through that approach.
ampere is offline
Old 27th February 2016, 10:19   #3505
JMaruru's Avatar
Thanked: 426 Times
http://mapas.alternativaslibres.es/downloads.php
JMaruru is offline
Old 28th February 2016, 08:10   #3506
Thanked: 255 Times
....... But the device will not recognise the route, when transferred. Transfer all the waypoints to the device. They will show-up under "favourites".
Create a route in Basecamp by using waypoints just to get a feel. And then in the device, feed these waypoints, one by one to cover to the next point.
I have recently bought nuvi 65LM. Initially i could transfer the routes from BaseCamp to the device but now the device does not show any imported routes.
Following link explains how to show routes imported on a Garmin 60 series but inspite of following the instructions no transfer route from BaseCamp shows up on device. Its so much better to plan a route in BaseCamp and transfer to nuvi, instead of transferring just the waypoints. But sadly, none of this works. Any ideas will be appreciated.
Transferring a route .gpx file to nuvi also doesn't work.
https://support.garmin.com/support/searchSupport/case.faces?caseId={f2cf7300-77af-11e2-65d0-000000000000}
https://support.garmin.com/support/searchSupport/case.faces?caseId={65814150-50b3-11dc-4ec8-000000000000}#Camper
DwarkaDelhiWala is offline
Old 28th February 2016, 10:00   #3507
ampere's Avatar
On the Garmin site, I see the 65LM specs and it says, trip planner being supported
In such a case:
- You should create a route in Basecamp using the trip planning utility.
- Then transfer the way points and the route.
- In the device, open the trip planner utility. You should see the imported route.
ampere is offline
Old 3rd March 2016, 09:58   #3508
ampere's Avatar
All, Please note: Map My India has stopped supporting Garmin devices. I just got a confirmation from their support.
So there is no choice but Garmin's own maps or Open Street Maps.
ampere is offline
Old 3rd March 2016, 13:27   #3509
Thad E Ginathom's Avatar
Thanked: 29,942 Times
So far, I have not installed Sygic on my new phone,, although I own a whole-world licence. I decided to try Google Maps when I need nav. I needed it the other day. It was fine, because I got all the turn instructions and, obviously, could see the map on the screen. What was not fine was Google maps displaying some street/place names in Tamil script. As far as I know, there is no locale/language setting anywhere on my phone suggesting that any app should use any other language but English.
If Google thinks it is clever, doing this, then it ought to auto-detect whether my wife is in the car or not. . Even if she had been, she might not have been able to easily see the screen.
Thad E Ginathom is offline
Old 3rd March 2016, 18:30   #3510
sgiitk's Avatar
Thanked: 4,808 Times
@ampere; Most OE navigation systems use MMI, so they maye be getting enough business, also as the quality of maps converges Garmin were getting too close for comfort, so not much demand for MMI on Garmin. See given the converging quality Garmin with LM is a far better deal/VFM.
sgiitk is offline
