Old 28th October 2016, 22:53   #9541
khoj's Avatar
Thanked: 1,287 Times
Re: The iPhone Thread
My iphone6+ won't ring anymore. Upon receiving a call it will vibrate but not ring. Have tried what I could under settings>sounds and also upgraded to the latest OS 10.1 but nothing.
No respite from the silent treatment
Can anyone help in restoring the ring(s)
khoj is offline
Old 28th October 2016, 22:59   #9542
hserus's Avatar
Thanked: 9,185 Times
There is a small hardware switch to turn off and on the dialer - to the left of your phone just above the volume controls.
If it is pushed down and a red mark shows, then push it back up.
You may have accidentally pushed this switch when for example you removed the case on your iPhone.
hserus is offline
Old 28th October 2016, 23:44   #9543
heydj's Avatar
Thanked: 735 Times
Has anyone used Sandisk Connect Wireless Stick with iPhone? Read the reviews, all good.
Was wondering if its possible to upload music directly from stick to iPhone and play too?
Some reviews suggest yes but not very clear. If its true then it would be like mid air refueling and great solution.
http://www.amazon.in/SanDisk-Connect...A26F2RYKU2S0F3
heydj is offline
Old 29th October 2016, 00:48   #9544
diyguy's Avatar
Thanked: 581 Times
i have heard about malfunction of the physical silence mode switch on the left that causes this. Try fiddling with that a bit to see if it clicks back to a normal mode of operation.
diyguy is offline
Old 29th October 2016, 06:51   #9545
getsurya's Avatar
Thanked: 1,946 Times
I have that Sandisk for iPhone and it has been an useless product. Doesn't sync up well and takes ages for transfer of data/pics.
getsurya is online now
Old 29th October 2016, 06:54   #9546
hserus's Avatar
Of course will take ages to sync. Only supports 802.11n according to the spec I saw at Amazon so the transfer rate will be like 15 to 30 Mbps over wifi (for a N150 or N300 depending on what is being used).
That might be an older generation of the product of course - if there's one that supports 802.11ac that'd be something to see. Of course you need a wifi access point that supports ac as well - which you'd be encouraged to buy if you have one of those 70 Mbps, 100 Mbps etc type internet connections.
hserus is offline
Old 29th October 2016, 09:08   #9547
Sheel's Avatar
Thanked: 14,678 Times
I am sure, he must have tried that. Why not reset the phone? Should help IMO
Sheel is offline
Old 29th October 2016, 09:34   #9548
hserus's Avatar
The question is, did he? That's bitten me more than once before when I had no intention of using the switch, but had just taken the case off to clean some dust out of it etc.
hserus is offline
Old 29th October 2016, 10:26   #9549
Sheel's Avatar
Yes, I know a couple of people have been caught off guard by this physical switch.
But whatever little I know khoj, it might not have been that red mark button for the cause of silence
Lets see.
Sheel is offline
Old 29th October 2016, 12:02   #9550
IronH4WK's Avatar
Thanked: 4,148 Times
Two days back while I was waiting in traffic I felt my 6S getting warm. I took it out of the case and indeed it was getting warmer! 4G was on and so was Bluetooth and not charging. First thing I did was to switch to 3D and switch off the Bluetooth. It stopped getting warmer. Kept it near the a/c vent and cooled it for couple of minutes and the phone returned to normal operating temperature. Switched on Bluetooth and connected the charger, but the phone didn't get warm.
My phone was running 10.0.4 beta.
What gives!
IronH4WK is offline
Old 29th October 2016, 13:54   #9551
hserus's Avatar
Settings > General > Usage > Battery Usage
See if there's anything there that's using an extremely high amount of battery / CPU
Close or uninstall that app if so
The other thing - update iOS
hserus is offline
Old 29th October 2016, 18:30   #9552
motorworks's Avatar
Thanked: 4,140 Times
Additionally, what is very likely to happen is that you're going to get a stream of phish emails that say "your phone was found at [some location], click here to locate it" that will try to steal your Apple ID / password.
Erase your device ASAP besides marking it lost.
https://support.apple.com/en-in/HT201472
I had an earlier posted that my iPhone 6s got lost during my trip to China earlier this month. I had enabled the lost mode and since it had 6 digit pin and finger print authentication it's safe to say the new "owner" hasn't been able to unlock the phone. Weirdly I have started receiving daily calendar requests to my new phone and all the "family" devices in some Chinese. While I suspect this is some sort of an attempt at retrieving my Apple ID and details, I have declined the meeting requests all along. Now how do I turn this off forever? My lost phone is still in "lost mode". Do I "erase phone" to disable such spamming? If I erase the phone then does the person get to reset the phone and use it?
motorworks is offline
Old 29th October 2016, 18:35   #9553
hserus's Avatar
Erase the iPhone - the finder won't be able to use it - an erase will "brick" it.
Don't respond to any of the phishes. You can report them to Apple for action.
hserus is offline
Old 29th October 2016, 21:59   #9554
khoj's Avatar
Thanks hserus, diyguy & Sheel
It was the physical button that was turned off. Switched on & ringing away now.
BTW I did reset the phone yesterday but no joy hence the post here
khoj is offline
Old 30th October 2016, 10:03   #9555
bhp_maniac's Avatar
Thanked: 258 Times
☺ Same thing happened to me a couple of times as well. They should've given a small icon on top of the screen to notify silent mode. Normally the red mark on the physical button go unnoticed.
bhp_maniac is offline
