Old 29th December 2010, 12:03   #2701
tanwaramit's Avatar
Thanked: 513 Times
re: The iPhone Thread !!! Update: iOS 4.3.3 out !
@amogh
Happens to my machine a lot more often.
Its the connection of the cable, try shaking the cable and it should work.
Is the cable worn out at both ends ?
In my case too, it starts charging immediately when plugged in the electric socket, however when done using USB cable (with laptop) it doesnt picks up that easily.
tanwaramit is offline
Old 29th December 2010, 13:09   #2702
9thsphinx's Avatar
Thanked: 546 Times
Originally Posted by akshay4587 View Post
I just did it on my Iphone 3G(i:e 4.2.1 to IOS3 with baseband 6.15).
Its working without any issues.
though i am still looking for the GPS fix for 6.15 BB.
Thanks, I'll try it out. Although, I don't have any issues with the GPS after upgrading the BB to 6.15! I read it on some blog somewhere that the GPS problem is random. In that case, I am I consider myself lucky
Originally Posted by akhilesh View Post
You may. Do you have the SHSH blobs saved for 3.1.3?
Yes, I do have blobs for 3.1.3 all the way to 4.1. Guess the best FW that worked perfectly for the 3G was the 3.1.3.
9thsphinx is offline
Old 1st January 2011, 16:17   #2703
Ranga's Avatar
Thanked: 83 Times
Why jail break the iphone when its is avaialble unlock version in Canada . This is now available for around 600US$ and its worth buying it from Canada . For this u need to have a friend , relative in the East coast of US .......
Ranga is offline
Old 1st January 2011, 16:20   #2704
Jailbreaking is not the same as unlocking.
iPhone is the cheapest in Hong Kong, not Canada.
srikat is offline
Old 1st January 2011, 20:10   #2705
OHC VTEC's Avatar
Need help bhpians..I am facing wi-fi and battery drain issues on my jb n unlocked 3g running on version 3.1.2 n 05.11.07 baseband..can anyone of you help me sort out these problems..thanx
OHC VTEC is offline
Old 2nd January 2011, 02:03   #2706
rg_chn's Avatar
Guys, my iphone screen just went white, it has grey lines on it though. I didn't drop it. Was working fine about an hour back. Tried the reset/reboot and the restore. Googled, and it's called white screen of death, but none of the solutions work!
rg_chn is offline
Old 2nd January 2011, 11:16   #2707
rajismine's Avatar
Thanked: 281 Times
Hi Gautam,
white screen at times comes due to loose wiring inside...a repairman can tighten the flex cable inside and it should be fine,
However before doing all this, drain the battery completely and do this on switch off mode
Rajeev
rajismine is offline
Old 2nd January 2011, 11:27   #2708
akshay4587's Avatar
Thanked: 4,562 Times
What kind of issues with Wifi?
I have same configuration,but on a 3GS.
No such issues here.
akshay4587 is offline
Old 2nd January 2011, 11:54   #2709
OHC VTEC's Avatar
When i try to select Wi-Fi i cant select it..My Wi-Fi is greyed out..It says No Wi-Fi and i cant select it to switch my Wi-Fi on,even my battery lasts for half a day at the most..M facing these issues since i have JB and Unlocked it.I wasnt facing these problems earlier i.e before i Jb and Unlocked it..
OHC VTEC is offline
Old 2nd January 2011, 18:22   #2710
Jaggu's Avatar
Thanked: 16,947 Times
I assume your is a factory unlocked phone, why dont you restore it back to oe os? ^^^
Jaggu is offline
Old 3rd January 2011, 12:46   #2711
Monaro's Avatar
Thanked: 117 Times
Guys, I got my iPhone 4 - AT&T locked with F/W: 4.2.1 and BB: 03.10.01. Browsed for hours, even went to Ghaffar market (Delhi) for the unlock but to no avail.
Any hopes? :/
Monaro is offline
Old 3rd January 2011, 13:20   #2712
madhkris's Avatar
Thanked: 83 Times
Guys I have an iPhone4 which is on ios4. I could not use the alarm function on the 1st and 2nd Jan. It's working today. Did any of you face the problem? Will it recur?
madhkris is offline
Old 3rd January 2011, 13:44   #2713
OHCVtec's Avatar
Thanked: 36 Times
This is an iOS bug which will correct itself on the 3'rd Jan. For more info refer the link below:
iOS Alarm Bug to be Fixed January 3rd – iFans – iPad, iPhone, and iPod touch Fans
OHCVtec is offline
Old 3rd January 2011, 13:46   #2714
Neilguy's Avatar
Thanked: 54 Times
Don't worry, you were not alone. This was a documented fact. you can get more details here. Link
Neilguy is offline
Old 3rd January 2011, 22:47   #2715
Thanked: 341 Times
I did this for my friend. Upgrade iPhone 4 to iOS 4.2.1 without upgrading your baseband so that you can unlock using Ultrasn0w. Please note that this method works only for iPhone 4.
Upgrade iPhone 4 To iOS 4.2.1 Preserving Baseband 01.59.00 For Unlock | how2i.com
akhilesh is offline
