Closed Thread
Old 12th January 2008, 15:11   #1
Thanked: 151 Times
Help in configs - Gift Laptop
Dear bhpians
I have gone thru the search of Laptop config threads and have collected a lot of info but now I am unable to make a proper buy.
1) the user will be using the machine atleast 8 to 10 hrs a day
2) config of system noted HDs of 120 @ 5400 and 120 @ 7200 -
3) 1.66 too 2.5mhz -- 1 gb ram suggest what would be best
4) graphic card needed should be dedicated one and what will be a good memory at either 32 or 64bit
5) dvd r/rw
6) ports needed atleast 2 usb, rj45, rj11, firewire, media out, built in cam mics, in & output portssound, blue tooth, wifi any additions from bhpians
7) battery usage would be there which cells - read something like litium ion 9 cell
8) brands HP Dell or Toshiba only
9) any of your valued inputs suggestions
will be used for some moderate gaming, pdf viewing, videos of speed simulations,
the above is a layman collected data. will appreciate if you could suggest me the model number based on brands HP Dell Toshiba
thanks
Jr Godzilla is offline
Old 13th January 2008, 01:54   #2
revvedup's Avatar
Thanked: 24 Times
A dell inspiron 1520 with the nvidia 8600 graphic card and 2gb ram and with would set you back by 55 grand and should make a good deal.Also check out the dell XPS series if you have a higher budget and want more performance.
revvedup is offline
Old 13th January 2008, 04:52   #3
khanak's Avatar
Thanked: 269 Times
Why start a new thread when we have
http://www.team-bhp.com/forum/gadget...questions.html
khanak is offline
Old 13th January 2008, 11:20   #4
Thanked: 151 Times
mods close thread pls.
i had gone through the above entire thread and gathered the info but with different views and suggestions of teambhpians could not make a proper short list of models/ brands.
Thanks anyways. Will be going in for a Toshiba and check out what best config I can get.
MODS pls close this thread.
Closed Thread
