Re: Canon G15 or S110 or anyother Quote:
Originally Posted by flycatcher Hi All,
Off late my wife and bro have developed some interest in photography. But at the same time they don't want to lug around a bulky DSLR. So I am looking to buy a high end P&S. They would be shooting mostly landscapes and portraits. I came across these 2 models from Canon - G15 and S110. The problem is even Canon store in Bangalore doesn't have a display piece to touch and feel the cameras. They say none of the stores in Bangalore have them. So I have to rely on internet reviews/ user feed back to decide on this.
My question is which of the 2 is better? Or any other camera model you suggest.
PS: We already have a DSLR at home which is in my hand most of the times, thats another reason they want a new camera.  |
1. Go to http://camerasize.com/ and compare the size.
2. If pocketability is the most important criteria - you MUST check out the thickness. Max 1.5" thickness/depth is what your pockets can tolerate. Height and width come later.
3. The high ISO noise of "high end" P&S is not really far away from the normal P&S. The only advantage of "high end" P&S is the PASM modes and the bright lens that gives you about 2 stops advantage compared to normal P&S. That means staying at low ISO most of the times. (Thus better picture quality).
Except Sony rx100 - which has a really bigger sensor and is thus usable at higher ISOs
3. Bright lens and pocket-ability is an oxymoron. Therefore the pocket-able bright lens like Canon s110 (f/2 - f/5.9) and Nikon p310 (f/1.8 - f/4.9) and Sony rx100 (f/1.8 - f/4.9) are bright only at wide end, the stops drop off dramatically as you zoom above 50 mm (in terms of 35 mm format).
So landscapes - cheers, portraits - boo
4. So what is it then? You need to decide what comes first for you - low light ability? manual modes? better looking JPEGs? money? zoom/reach? wide angle? really small size? fixed lens (compared to a MILC)? Quote:
Originally Posted by navin The G15 is not pocketable. In my book Sony's RX100 is not pocketable either. The S110 just about makes it.
If there was one feature I would have asked for in this class of camera is the ability to drop the Megapixel output to say 4M while lowering pixel density and thereby improving light capture in low light conditions. One wierd thing though, when I push Aperture to say f/8 the viewfinder still shows the image like the Aperture if wide open. I wish the viewfinder showed the correct DOF as per Aperture- this seems to be the case of all pocket cameras. |
1. I think there is some night mode usually tucked in all Canon pocket cams. I am not sure if it does pixel binning, but the resolution is much lower than other modes.
2. But you do get the actual exposure and DOF view while in full Manual mode. The display (LCD/TFT/OLED) on the back shows exactly* how the pic will "develop".
*Not exactly actually because then I would need to specify the viewing angle, and also the brigthness+contrast+gamma levels of the screen Quote:
Originally Posted by aim120 Sony has recently dropped the price of the NEX 3 to just 14990 it comes with a APS-C size sensor ,so just grab that before its sold out .Already reports are that it has been sold out in most places.NEX5 is available for 19990 it has a magnesium alloy body and takes 1080p videos. |
The picture qualities of Sony NEX 3 and 5 is comparable to micro 4/3 Panasonic and Olympus.
The m4/3 have more lenses. And they are more compact too. And faster auto focus. Why would you buy a Sony then?
Only because of Less price.
