▲ Go to Top ▼ Bottom
Old 8th June 2020, 00:28   #7861
Thad E Ginathom's Avatar
Thanked: 29,972 Times
Re: The Home Appliance thread
Originally Posted by Amrik Singh View Post
... ... allowing AC to Hibernate during Winters.
I am having trouble understanding that last word.
<-- Location Chennai
Thad E Ginathom is offline   (6) Thanks
Old 8th June 2020, 11:37   #7862
Thanked: 3,001 Times
Anyone into baking (amateur, DIY, at home) please answer:
Is it worth getting a "stand mixer" and what are the options in India ? What's the ideal wattage one should look for in these machines ?
https://homezene.com/best-stand-mixers-india/
https://www.amazon.in/Stand-Mixers/b...ode=1380080031
For small batch - 1 to 2 kg flour, mixing by hand is best. Mixers require cleaning and for small batches it is not worth it. Further mixing by hand transfers the warmth from hands that makes the mixed dough slightly better.
I knead the dough twice, Once initially and a second time after it rises. I doubt any but large commercial mixer will do the second kneading properly. Anyway TV programs show the Artisan bakers knead the final stage by hand. It is fascinating to see one person manipulating a pile of 20kg dough.
The stand mixers that I saw in malls are prohibitively expensive ranging between 30K and 60k. In contrast I did search for and found a lot of commercial dough kneaders at a much more reasonable price. Just google and you will get a lot of links.
Aroy is offline   (2) Thanks
Old 9th June 2020, 02:01   #7863
Thanked: 3,721 Times
Re: The home / office air-conditioner thread
I am looking to purchase a decent surge protector. I managed to shortlist the below two options:
  1. Honeywell 6 socket platinum series https://www.amazon.in/dp/B01N2B99ZR/..._s3P3EbAB9QJTH Is this actually manufactured by Honeywell? The support email address seems to say Honeywellconnection and there is a comment that talks about how this is just a different company using the purchased Honeywell trademark.
  2. Belkin 8 socket : https://www.amazon.in/dp/B0083T23AA/..._f8P3EbG3VX2XA - I always thought that Belkin is a decent brand but it seems that quite a few people have complained about how the quality seems to have gone down.
Also, are any surge protectors in India actually UL certified and do any of them actually honour the compensation claim?
I am thinking if putting together a gaming desktop for which I will have to get a UPS. But I don't have a good surge protector at home right now and I am worried about the office laptop.
JithinR is offline
Old 9th June 2020, 11:51   #7864
diyguy's Avatar
Thanked: 588 Times
Originally Posted by JithinR View Post
Also, are any surge protectors in India actually UL certified and do any of them actually honour the compensation claim?.
Both are good and i have used Belkin a lot. For the past 3-4 years am using huntkey which claims to have a similar warranty. We also have a full house UPS that also protects from surges if i am not wrong.
diyguy is offline   (1) Thanks
Old 10th June 2020, 10:20   #7865
Prowler's Avatar
Thanked: 1,403 Times
It all depends on the type of UPS. The 'normal' domestic inverter under normal conditions just passes the AC mains supply to the output. It uses the inverter only when there is no mains power supply or the the mains voltage is too low. The double conversion online UPS, usually used for computers will output its own supply regardless of the AC mains input. This type of UPS may provide surge suppression to some extent. But it doesn't suppress transients induced into the line by lightening or rapid switching of inductive load.
We have tested this in our office set up for a long time. It is better to fix Surge Protective Devices (SPD) at the entry point of your house. They provide the best possible mains borne high voltage surges. And after that for sensitive electronics use a mov (metal oxide Varistor) at the socket which will provide protection against internal surges.
Prowler is offline   (3) Thanks
Old 10th June 2020, 13:17   #7866
archat68's Avatar
Thanked: 642 Times
I have Huntkey and I opened it, there is nothing inside it in terms of surge protection. It is a simple power extension strip.
archat68 is offline   (1) Thanks
Old 10th June 2020, 13:30   #7867
Thanked: 3,280 Times
+1. Its always better to provide SPD at the mains and at the extension point. The mains SPD have rating of the order of 10-12.5kA and the extension cord ones have around 1.2kA (@archat68 : One that really has)
srini1785 is offline   (1) Thanks
Old 10th June 2020, 13:49   #7868
diyguy's Avatar
Thanked: 588 Times
This is what the product states.
diyguy is offline
Old 10th June 2020, 14:35   #7869
archat68's Avatar
Thanked: 642 Times
Also gives Insurance upto 1Lakh IIRC . I'll check mine when I'm home and post a photo too.
archat68 is offline
Old 10th June 2020, 15:09   #7870
Vid6639's Avatar
Thanked: 44,135 Times
It will be a capacitor and inductor nothing else inside.
Vid6639 is offline
Old 10th June 2020, 15:45   #7871
archat68's Avatar
Thanked: 642 Times
I know. I have quite some knowledge about electronics about a hobbyist. There is nothing, the wire is directly connected to the sockets.
archat68 is offline
Old 10th June 2020, 16:38   #7872
Difference between a spike arrestor and surge protector.
Spike arrestor : Typically a LC filter circuit. When a spike occurs, the inductor opens and the capacitor discharges to GND.
Surge protector : Typically a Varistor ( Metal oxide ) with a GDT (Gas discharge tube) to the GND. When a surge occurs, the Varistor shorts and the GDT starts conducting the excess current to the GND.
My guess is that the chinese have got the name confused.
Old 10th June 2020, 17:06   #7873
Thanked: 758 Times
I noticed that the UPSes with built in batteries were wreaking havoc when they reach EOL. Then I started using Belkin between the UPS and the cabinet. Well, have suffered SMPS snafu after that. I'm speaking of a 20 year period. So have preferred to attribute power induced hard disk failures to bad karma, not power equipment.
BaCkSeAtDrIVeR is offline
Old 13th June 2020, 22:22   #7874
Thanked: 268 Times
Recently my 7 year old LG front loader stopped midway during washing. Called the LG support and they identified the issue to the corrosion of Rear Drum Assembly.
They've quoted Rs.6500 for the fixing which includes welding of a stainless steel shaft in lieu of original aluminum.
Problem:
The service guy told me that its a common problem with all front loaders.
Is it true or is it a daylight robbery?
mithun is offline
Old 13th June 2020, 22:46   #7875
Thanked: 61,456 Times
Throughout our entire married life we have had front loaders. Never had this problem though.
Jeroen is offline
