Re: The Home Appliance thread Thanks a heap to all those who have responded. Quote:
Originally Posted by deep_bang We just got a panasonic and it is quite nice. The build quality is top class. our 10 year old "national" still runs well except that the jar is damaged. The new one has options like the motor doesn't not run till you close the lid, and such safety features. Also, I got this online for about 3800 when the normal price outside was about 4500. |
Ten years and more ago, they used to make things that last longer. Even Maharaja mixers used to be pretty good around then, going by what people said. But the one we bought 1.5 years ago is of abysmal quality, to say the least. Quote:
Originally Posted by saket77 We are using an IFB Dishwasher for the last 6 months. Before buying it, I was little confused that how practical is a dishwasher for home use...like cleaning abilities after our typical Indian food is made, electricity consumption, its own consumables like salt, rinse aids and detergents.
But after getting it, never for a second I had doubts about any of the above. It cleans thoroughly, is very very hygienic as it heats up the water as high as 70 degrees. In fact if you open the dishwasher while its running, you would see good amount of steam coming out and the hot water. In short, its pretty hygienic. This could alone be the reason to get one!
Consumables are not that expensive. Rinse aid is the one component that needs to be topped up every 25-30 days. The DW is also equipped with 3in1 detergent option. Its a mixture of all 3 in 1, but this is probably not available as of now. In case they become available, you can do away with all the salts, rinse aids & detergents! Also has 1/2 load economy mode in case you want to run it with lesser utensils. At last, it steam dries all utensils, so what you get is completely dry dishes which can be stored right away.
Very good product indeed. We are using an IFB fully automatic front loader since last 15-16 years and it still works flawlessly. I have also heard about IFBs poor service but fortunately the service in our city is pretty good.
Should you have more queries, will be glad to help.
Saket |
Well, our IFB dishwasher just stopped washing effectively after couple of months. Though after spending considerable time and effort, the company did replace it. Though they didn't do that until they made umpteen efforts to fix it... but I don't think they could find the fault themselves. I have mentioned details in this thread earlier. Quote:
Originally Posted by ece2k2 you could also check the ELGI mixer with 1000W motor. I bought it a month back and seems to be built well - though it is a little bit pricey, but comes with a 5 years warranty for the complete unit | Quote:
Originally Posted by sagarpadaki We have been using a Sujata Dynamix as a replacement for Sumeet and we are happy about it. Build quality and excellent and the jars are easy to clean. Also easy available spares too. Good powerful motor , though it does not make a racket! |
Not heard of these brands. Not seen in shops either. Anybody else has used them? Quote:
Originally Posted by DerAlte 6 years, and no problems with a Philips mixie yet. Of course the jars keep giving way - specifically the brass nut they use at the bottom to fix the coupler with the blade. That keeps dissolving with acidic mixes (tamarind!) and breaks apart in pieces after some time. Can't they think of using a nut made of an appropriate strong plastic there?
The saving grace is the availability of new after-market jars (local, not Philips). Have changed 4 in the past 6 years. The motor unit is still going strong - no electrical problems. |
Thats really, really bad! That means that you have been eating brass nuts along with your food.
Any idea about the cost of these aftermarket jars? How do they compare with the original Philips jars?
Our Philips (motor) conked out after some 3 years of fairly lightweight use. Jars also had a couple of issues like gaskets needing change, etc. Build quality also leaves a lot to be desired, though it is definitely better than the Maharaja and the like. Though mom says its grinding efficiency was MUCH better even though the motor was lower powered than Maharaja. Quote:
Originally Posted by Pallavi I have been using Panasonic mixers for 10 yrs and no problems with the machine till date. Had to change 2 jars but our usage is heavy. Idly/dosa batter + chutney atleast 4 days a week.
Go for Panasonic. It is worth the extra price. |
Original jars? Any idea about cost? Pana build quality is definitely better than any other brand that I compared with. Also, motor has 5 years warranty and body is 2 years. Hope they have maintained their durability like before. Hope so, as nobody else seems to be giving a 5 year warranty currently. So I'm more inclined to Pana. Hope the significantly higher price is worth it.
However, their 3 jar variant has a motor of 500 W. Store assistant said it may be an issue so better go for other brand which has 750 W motor. I don't really trust these numbers, but does anybody feel the 500W Pana motor is bit underpowered for certain uses?
