Old 3rd January 2010, 19:19   #226
navan49's Avatar
Thanked: 73 Times
Ravi,Mithun,Siralec,
Mine is a WA 3002G4 UT Stardom WiFI modem. It is almost two year Old. So far no problem. It is working well. The question came because my son's 6 months old modem's adopter got spoiled and the BSNL people told that there is no warranty for adopters.
navan49 is offline
Old 3rd January 2010, 23:31   #227
Thanked: 727 Times
many adaptor will match. Check the specs written on the adaptor (volt and current. Its basically SMPS based adaptor. It will hardly cost rs.150. Just make sure its not a transformer based one.
Even if the plug doesn't match you can cut off and use the plug from your burned adaptor. Just make sure the plus and minus using a multimeter.
SirAlec is offline
Old 4th January 2010, 00:25   #228
navan49's Avatar
Thanked: 73 Times
Thanks for the tips. I will make a trip ti Electronic market and see. Any idea where we can get the Toshiba's laptop adopter.
navan49 is offline
Old 7th January 2010, 10:10   #229
Aiel's Avatar
Thanked: 598 Times
I also had the same issue, where my BSNL modem adapter got spoiled. The guys at BSNL told me that they can't give a new adapter, as they do not get spare adapters, along with the modems. I got a new one from a neighborhood electrical shop; they did not have it in stock, but got it by evening. I have been using this new adapter for the past one month.
Aiel is offline
Old 7th January 2010, 15:06   #230
IronH4WK's Avatar
Thanked: 4,152 Times
Originally Posted by sammyboy View Post
Also, can I use any personal WiFi router or does one need to give the MAC address of the router we want to use, to the bsnl guys before using it?
don't know if you've already resolved your query, but the answer to your question is YES. one can use a personal wifi router with a BSNL broadband connection. one doesn't need to provide the folks at BSNL withe MAC ID too. just need to know the vci/vpi; username/pwd; primary and secondary DNS (depending on the router). most probably would be using LCC (don't remember BSNL using g.dmt). if in doubt, use multimode.
when i had BSNL, i was using a Linksys WAG54G. due to their wonderful tech-support, i've now moved on to Airtel.
IronH4WK is offline
Old 9th January 2010, 00:53   #231
Ponmayilal's Avatar
Originally Posted by vaisakhr View Post
Yes, I understand your views and one of my option for you will be THIS
The BSNL datacard tariff you had given is no longer valid.
From 01 Nov 2009, BSNL has introduced new volume-based tariff for EVDO Datacard. Find it here .
For unlimited usage one has to pay Rs.999/- p.m. as fixed monthly charges (FMC).
Existing users who are paying Rs.550/- p.m. as FMC for unlimited usage will now pay Rs.650/- (Rs.550+Rs.100 for All India roaming facility - no option). These users will have to get their EVDO Datacards reconfigured by BSNL to the 10 digit WLL tel. numbers that will be assigned to them in-lieu of the old 8 digit numbers.
I had taken the EVDO card sometime in March 2009 on rental, happy with the service purchased it sometime in Sep/Oct 2009, and got it reconfigured to the new 10 digit number a fortnight back.
Like navan49, I had also converted my Broadband Home 500 to Home UL 750 plus plan two months ago. Prior to that I was using the Datacard during the daytime and Home 500 during evenings/nighttime so that I do not exceed the 2.5 GB cap on the Home 500.
Now since both are unlimited, I use 750 plus all the time with the EVDO Datacard serving as a backup but runs all the time on a second computer whenever I use it.
Those interested on my review on BSNL EVDO Datacard may see here . Of course the tariff for new users has changed as outlined above.
Ponmayilal is offline
Old 10th January 2010, 09:37   #232
navan49's Avatar
Thanked: 73 Times
My desk top usage is heavy.so I use 750plus. I don't use a data card, instead of data card I use my mobile GPRS on travel, which helps me to retrieve my mails. I had a tough time when my E75 was not configured with BSNL. Now everything is fine. Data card and BB is too expensive.
navan49 is offline
Old 10th January 2010, 21:17   #233
sammyboy's Avatar
Thanked: 526 Times
Thanks IronHAWK I got a net gear home router to use with the BSNL connection.They were useless in terms of any support but I knew enough to get it up and running.
Worked well. I am back to Bangalore now and it feels so nice to get back to the good ol Airtel 2Mbps
sammyboy is offline
Old 11th January 2010, 11:43   #234
IronH4WK's Avatar
amen to that!
PS: i tried the 8mbps option (i play multi-player games online), but didn't find it really different - pings were still high. so went back to 2mbps.
IronH4WK is offline
Old 13th January 2010, 06:49   #235
vaisakhr's Avatar
Thanked: 203 Times
I have a problem. I couldn't connect to the internet. The modem shows connection but the computer only have limited connectivity. Ipv4 in local connectivity.
Some time the it gets connected to internet but then only Ipv4 is connected not the Ipv6. Ipv6 remains in the limited connectivity.
vaisakhr is offline
Old 13th January 2010, 19:29   #236
sammyboy's Avatar
Thanked: 526 Times
^^ do you have Vista as the OS by any chance? I have faced similar issues with Vista quite a few times. I tried all sort of things but nothing but good ol restart solves the issue. Did you try to manually put the Ip Address and DNS settings? Try it and see if it works.
sammyboy is offline
Old 13th January 2010, 19:36   #237
vaisakhr's Avatar
Thanked: 203 Times
I have faced similar issues with Vista quite a few times. you try to manually put the Ip Address and DNS settings?
I tried on both Vista and 7, no scope. I also tried manual settings, but the problem still persists. Now I am getting Ipv4 = internet and ipv6 = limited
vaisakhr is offline
Old 13th January 2010, 19:47   #238
jav
Thanked: 66 Times
IPv6 will show limited because ipv4 is being used, ipv4 should show internet, if it shows limited connectivity or local there may be some problem with dhcp or dns, are you using a firewall?
jav is online now
Old 13th January 2010, 19:48   #239
IronH4WK's Avatar
i don't think you require the IPv6 for accessing internet. my IPv6 shows "No network access". in the settings for IPv6, you should set it to "Obtain an IPv6 address automatically" and "Obtain DNS sever address automatically" respectively.
if you're using DHCP on your modem/router, the IPv4 also should have a similar setting.
IronH4WK is offline
Old 14th January 2010, 20:36   #240
vasoo's Avatar
Thanked: 248 Times
Feels much better now! Have finally managed to get my BSNL Dataone connection disconnected without getting my phone also disconnected along with it! My apartment had some major problems with their broadband service as invariably the service will be down on most weekends and in addition a couple of hours every day.
Whenever we complain they used to blame on digging works in the road. Many times when I decide to stay back at home and work I was completely stuck due to their service not working. Finally took an Airtel connection and then started the arduous process of getting my BSNL Dataone disconnected. As you know it requires personal visit to their customer cell taking at least a half day off. I had to do this a couple of times as relevant staff was not available.
Most of my flat mates who tried to disconnect it also ended up with dead land phones even though they sepcifically asked not to do it. I made it very clear in my request letter and had calls with the commercial officer couple of times to make sure that only my broadband is disconnected. Feels much better with a 100% reliable Airtel connection.
vasoo is offline
