Old 18th November 2015, 12:46   #1
Prowler's Avatar
Thanked: 1,395 Times
Ethernet Surge Protector
The Background: Chennai's woes are not over yet. The rains have stopped for now but we continue to suffer. 3 days back, a lightening killed my Wifi Router, ADSL modem and 2 NIC from 2 different computers.
Every few years, this sort of thing keeps happening and I keep changing them. I have ACT fiber optics connection as well as Airtel Broadband feeding a NAS server and a Wifi router. I was under the impression that fiber optics will be immune to lightening surges. But the last mile connectivity is through copper CAT 5 cable and that passes the surge to your connected Network Interface card.
There must be a better way to protect these components. Ethernet Surge protectors are available online - but they cost around 3k each. It is almost the same cost as a router and a NIC.
Anyone here has experience with these ethernet - RJ45 as well as modem line RJ11 surge protectors ?
Any ideas ?
Prowler is offline   (1) Thanks
Old 18th November 2015, 12:54   #2
praveen_v's Avatar
Thanked: 219 Times
Re: Ethernet Surge Protector
I am looking for options too. I had one 'N' wifi modem router acting purely as a modem and connected via ethernet to a second 'AC' router which was doing dual band wifi duty and Gigabit connectivity. Last week's lightning strike in chennai took out the ports on both ends of the connection between the AC-N router. Now my AC routers WAN port is fried while the N router has conked off one ethernet port.
praveen_v is offline
Old 18th November 2015, 13:17   #3
raghu.t.k's Avatar
Thanked: 208 Times
I am also looking for a cost effective solution for the telephone, ACT cable and Airtel dish.
Belkin does have this option on the 6 socket and 8 socket ones, but dont know how effective it is. I have purchased this, but still to be connected. I am looking for something which can be stand alone, like a ADSL splitter which can be connected inline.
These 2 have the ethernet and telephone options as well
http://www.belkin.com/in/IWCatProduc...uct_Id=481734#
http://www.belkin.com/in/IWCatProduc...uct_Id=481703#
raghu.t.k is offline   (1) Thanks
Old 18th November 2015, 14:14   #4
Prowler's Avatar
It looks like RJ11 ports which are for phone line and ADSL modem. Where did you buy the Belkin and how much did that cost you ?
RJ11 surge protectors are easily available at reasonable cost. But RJ45 surge protectors are expensive and not available in Indian online stores.
Old 18th November 2015, 15:11   #5
optimist's Avatar
Thanked: 84 Times
Try this.
http://www.apc.com/shop/in/en/produc...ines/P-PNET1GB
http://www.amazon.com/APC-PNET1GB-Pr.../dp/B000BKUSS8
optimist is offline   (1) Thanks
Old 18th November 2015, 17:25   #6
Prowler's Avatar
Thanks Optimist. With optimism (can't help the pun ) I tried the site but unfortunately can't locate one seller in India.
Old 19th November 2015, 00:19   #7
raghu.t.k's Avatar
Thanked: 208 Times
The one I have does have the RJ11 and RJ45. The mrp is around 3.9. Below is the product image.
Old 19th November 2015, 09:30   #8
AbhiJ's Avatar
Thanked: 1,236 Times
I used to have a couple of UPS's which had this feature inbuilt.
Wont that be cheaper / more useful?
AbhiJ is offline
Old 20th November 2015, 15:56   #9
Rehaan's Avatar
Thanked: 35,778 Times
The amazon link does ship to India. Their delivery is usually fast too:
Name:  amz Capture.PNG
Rehaan is offline
Old 20th November 2015, 17:55   #10
Prowler's Avatar
Attachment 1441641
Thanks Rehaan. I will check that out.
Yes. I have an old APC UPC with a surge protection facility for RJ11 too. But that used to cause attenuation of the signal so much that I discarded it.
Thanks Raghu. It will be adequate. It is not available readily in the online stores.
Old 20th November 2015, 18:01   #11
raghu.t.k's Avatar
Thanked: 208 Times
I got this from Mercy electronics, you could check with them. That said I am yet to use it, since I wanted to relocate the router and that has not happened till now!!
Old 20th November 2015, 18:06   #12
Prowler's Avatar
Thanks again. One surprising thing is both of us have around the same message count.
Prowler is offline
Old 20th November 2015, 19:56   #13
TheTeacher's Avatar
Thanked: 343 Times
Can you please provide the Belkin Model / Part #? Thanks.
TheTeacher is offline
Old 22nd November 2015, 19:06   #14
raghu.t.k's Avatar
Thanked: 208 Times
Interesting coincidence...
The earlier link was incorrect pls. find the link to the "ultimate series":
http://www.amazon.in/Belkin-F9G826vz...productDetails
Hope it helps.
Old 25th November 2015, 15:12   #15
TheTeacher's Avatar
Thanked: 343 Times
Thank you very much, Raghu. Strangely, Belkin does not list model/part #s on their website for their products; this is pretty stupid.
