Old 8th October 2014, 23:47   #2851
NetfreakBombay's Avatar
Thanked: 1,073 Times
re: The Desktop Computer & Configuration Thread
Originally Posted by Geo_Ipe View Post
My question - can I build a PC with a ~24" monitor which can double up as a TV?? If so, can someone suggest brands/models??
Since now almost TV is digital (via satellite / cable set top box), all you need is a set top box that has HDMI out.
All LED monitors would have DVI port that can be connected to hdmi post of Set top box. You can get a pair of desktop speakers for sound.
Quite a few monitors have hdmi port + speakers, so they will do the job of TV too.
NetfreakBombay is offline
Old 9th October 2014, 10:35   #2852
Geo_Ipe's Avatar
Thanked: 3,390 Times
Do TATA Sky boxes have an HDMI out??
Plus, what is a TV tuner card?
Geo_Ipe is offline
Old 9th October 2014, 10:43   #2853
IronH4WK's Avatar
Thanked: 4,149 Times
The HD and HD+ have HDMI out.
IronH4WK is offline
Old 9th October 2014, 11:52   #2854
Thanked: 271 Times
TV tuner card is a piece of technology that has become quite redundant in this age of digital TV.
It's a hardware add on in PC where input could be received from the cable TV and watched on a pc monitor. With set top box an hdmi connection to monitor is much easier and cheaper.
Sunny
Autodoc is offline
Old 10th October 2014, 07:17   #2855
Thanked: 1,019 Times
Two wifi related mysteries I have never been able to understand
1. Why do most entry level / average motherboards not come with built-in wifi? The components themselves are tiny and cost very little. Given how ubiquitous wifi is, it's a shame that a USB adapter / PCI card has to be bought separately. [In 2007 I bought a budget ASUS motherboard with built in wifi - albeit with an external antenna, but this time when I went shopping I found nothing in the budget range]
2. Why do the internal wifi adaptor cards not come in antenna-less flavours. There's not a single one in the market which is baffling as laptops do just fine with the non-antennae ones. It's inconvenient to have an antennae at the back of the cabinet where there's a mesh of crisscrossing wires. The USB dongles are also problematic as they block a port and also occupy a lot of volume on the outside.
Kumar R is offline
Old 10th October 2014, 14:15   #2856
Thad E Ginathom's Avatar
Thanked: 28,170 Times
And now for a really, really stupid question <Blush>
Thing is, I have built my own for the last couple of PCs, and before that, every PC or laptop I bought for work (dozens) or home had an MS Windows OS loaded on it.
Now I am looking at laptops, and I see "DOS" listed as the operating system for some of them. For instance. So... I turn it on and get a "C\: >" prompt that I knew and hated a few decades ago? And then load separately-sourced Windows or Linux?
Thad E Ginathom is online now
Old 10th October 2014, 14:26   #2857
IronH4WK's Avatar
what you get with such deals is a OSless (almost) system, which basically means you get to find out if your system works, but if you wanna do amazing things with it, install an OS
IronH4WK is offline
Old 10th October 2014, 14:26   #2858
reignofchaos's Avatar
Thanked: 2,494 Times
Yep they come preloaded with some version of freedos i.e. no OS basically.
reignofchaos is offline
Old 10th October 2014, 15:23   #2859
Rehaan's Avatar
Thanked: 35,254 Times
My guess: Radio interference and perhaps additional FCC certification costs?
A wifi antenna close to other components would cause/receive a lot of interference. Laptops manage it because they are designed knowing exactly where each component is. Same for some readymade PCs. The INTERNAL antenna is placed in a location (typically with a plastic (not metal) cover) so it can get maximum range - and it's shielded from the internal components.
For desktops however, there's no knowing what components you'd use, and where they'd be located in the box, and the resultant interference caused. An internal antenna would be enclosed within a metal box, and that's not good either. External antennas are the logical solution here. In fact, given a choice between internal and external, I'd choose external!
That is correct. Basically sellers are using this for 2 reasons:
1) Why pay for windows licenses when the user might want to install linux instead.
2) A Rs. 18,000 machine would cost perhaps Rs. 21,000-23,000 if it came with windows. By leaving the OS out, they are making it sound so much cheaper.
cya
R
Rehaan is offline
Old 11th October 2014, 00:12   #2860
That makes sense to me. If I get one I'll have to seek out a copy of W7, as I really don't want 8 in the house!
Thanks to all who answered
Here's another one, to do with screen formats. I hate this super-wide-screen format, which is good only for manufacturers (less area for the same diagonal) and spreadsheet addicts. I don't seem to see any of the less narrow format, though. Is it really a thing of the past for laptops?
(yes, I know... the old 3*4 CRT shape is long gone!)
Old 11th October 2014, 08:29   #2861
IronH4WK's Avatar
They're still around although people now go for the widescreen (16:9) format. Dell has the Ultrasharp series which are 4:3 format, but a tad bit expensive.
IronH4WK is offline
Old 11th October 2014, 13:02   #2862
I have my eye on one of these (Dell U2412 24 in at Flipcart) but my existing Samsung 22", although it flickers occasionally, shows no sign of dying.
But that's monitors: At the moment I am thinking laptops.
Old 11th October 2014, 13:12   #2863
Do you have a specific reason for choosing Dell? To the best of my knowledge Dell is not a LCD panel manufacturer, it just rebrands wholesale, unlike LG, Toshiba, NEC, Samsung who make their own stuff. Also, this model seems expensive. There's a 27 inch Samsung model available for Rs 11,000.
Kumar R is offline
Old 11th October 2014, 13:18   #2864
Dell uses LG panels in all ultrasharp displays. In fact pretty much any quality monitor would use lg ah-ips panels. Nec that you mentioned also uses lg panels on most of their good displays. The monitor is manufactured by dell itself. They are really good value for money. You get close to NEC/eizo quality without spending an arm and a leg. They are great for color critical work and come calibrated from factory. I am using dell displays for over 10 years now and have no complaints.
Old 11th October 2014, 13:38   #2865
Thanks, I did not know that NEC also uses LG panels. My suggestion was that it makes more sense to buy a product from a company which itself makes most or all of the critical components and has the technological knowhow - if that option exists and assuming pricing is not a problem.
Kumar R is offline
