Old 25th May 2012, 11:50   #601
DerAlte's Avatar
Thanked: 2,920 Times
Re: The DATA Card and USB Modem discussion thread (Reliance/Airtel/Tata)
Originally Posted by ajman28 View Post
... Prithvisolutions UE 100 ...
Easlink UE 100! Prithvi is just a bulk importer for BSNL - usual modus operandi.
Maybe this helps? [ubuntu] BSNL EVDO UE 100 Linux installation - Ubuntu Forums
DerAlte is offline
Old 27th May 2012, 23:09   #602
amtak's Avatar
Thanked: 1,107 Times
I am getting miserable speed on my IDEA 3G net setter card. Any suggestions to improve this? When I call the customer care, they ask me to dial 12345XXXX from an Idea phone! How weird! No solutions from their side.
amtak is offline
Old 28th May 2012, 04:26   #603
ghpk's Avatar
Thanked: 212 Times
Are you sure u are using wcdma mode in your dailer?
If not ho to settings and under network mode select wcdma
Normally a USB modem should give blue flashing lights when in 3G mode.
If connection shows edge then you are on 2G network.
ghpk is offline
Old 28th May 2012, 20:23   #604
ajman28's Avatar
Thanked: 24 Times
Thanks, unfortunately still not working.
I am not able to unpack wvdial itself. I couldn't find the drivers on the net either (Easlink does not give many results).
Any other way to detect the usb modem? I am on Ubuntu 11.10
ajman28 is offline
Old 29th May 2012, 10:37   #605
DerAlte's Avatar
Assuming that most of such low-cost 3G dongles are made from the same chipset as a more famous one (ab initio creation of a 3G modem is not a trivial job), you can perhaps try out the hackers' method: patiently try with drivers for other such dongles. One of them will definitely work. As a start, try drivers of older Huawei models.
DerAlte is offline
Old 29th May 2012, 23:53   #606
amtak's Avatar
I am on WCDMA Mode. My blue light is stable and it shows that I am on 2G network. I had an MTS dongle and I used to get fantastic speeds on that; somehow I am not happy with Idea. I guess it was a bad Idea to purchase this one.
Worst of all, they want me to connect to their call center using IDEA number!
amtak is offline
Old 30th May 2012, 02:02   #607
ghpk's Avatar
Thanked: 212 Times
Bluelight means you are getting 3G, what makes you say you are on 2G network ?
if it was a 2G network, your modem would flash green Light and it would show GPRS/EDGE as network name, and it won't connect on wcdma mode.
for mumbai you can call IDEA on
Contact No - 91 9702012345
Fax - 91 95940 04999
you need to select 3G on IVRS and then explain the problem to the executive.
Idea has good 3G speeds, don't know what exactly your problem may be.
ghpk is offline
Old 30th May 2012, 10:56   #608
amtak's Avatar
I have already logged a complaint with the Idea guys. A normal site like yahoo shows "loading". I am saying I am on 2G as the network preferences, it is showing IDEA 2G. The network strenght is good (it shows HSPA Idea) but net speed is between 2-120 KBPS at the max.
It is reminding me of old internet days!
amtak is offline
Old 30th May 2012, 11:28   #609
Thanked: 463 Times
Slow speeds are also possible if you have exceeded your download limits and are now on the free to use plan at lower speeds, a lot of providers use this method.
dadu is offline
Old 30th May 2012, 12:51   #610
ghpk's Avatar
Thanked: 212 Times
Very strange experience !!!
If you are on 3G plans, it should no where show 2G.
try changing the network mode to "wcdma only"
Speeds you have mentioned is of 2G network for sure, it doesn't show any signs of 3G.
Did you recharged with a 3G plan ?
Is it a prepaid or postpaid connection ?
If this is a prepaid conn. Have you sent sms to activate 3G.
ghpk is offline
Old 30th May 2012, 13:17   #611
lurker's Avatar
Thanked: 1,478 Times
If you have not recharged with a 3G amount then the connection automatically downgrades to 2G. I had once recharged with 999 unlimited 3 months and they downgraded me to 2G.
lurker is offline
Old 30th May 2012, 14:40   #612
amtak's Avatar
I agree. However, I have just refilled it.
It is a pre-paid plan. No one has informed me about sending an sms to activate 3G? I guess the mobile store guy who did must have done something?
What is the minimum recharge for 3G? I am thinking of moving back to MTS if the 3G issue is not resolved.
amtak is offline
Old 30th May 2012, 14:47   #613
lurker's Avatar
It's 104 for 300 MB as per latest tariff plan. But if you still do not manage to remove the downgrade to 2G just call the idea guys and they will upgrade your id within 12 hours. They seem to be pretty responsive.
lurker is offline
Old 30th May 2012, 14:58   #614
ghpk's Avatar
Thanked: 212 Times
If you have not activated 3G you need to send sms as "ACT3G" to 12345
if you wish you can contact customer care and seek help.
you can take the sim out and put it in mobile and call if needed, that would be one time requirement.
I've better experience with Idea 3G and that's what pushing me to resolves your too :-)
Edit: I and happy with Voda and Idea 3G along with Reliance netconnect +, for airtel, Yeah that's lots of internet...
I don't know why its 3G puts me on roaming when on hometown/home-network, once I get signals from other provider
they put me away from making and receiving many calls, the number does not exists makes me look shady to callers
ghpk is offline
Old 30th May 2012, 15:25   #615
amtak's Avatar
300 MB is quite less? what if my usage is more? I usually consume about 2GB a month. I guess my last recharge was for 350 Rs.
I find them weird. Atleast in Mumbai circle. They always tell me to call on 12345 from any phone! I have a Voda connection and if I dial 12345, i'll be connected to Voda Live and not Idea!
amtak is offline
