Old 8th January 2014, 17:41   #1816
Rehaan's Avatar
Thanked: 35,237 Times
Re: Photoshop/Digital Art thread
Originally Posted by girimajiananth View Post
...resize an image from 1024 X 768 to 7200 X 5400... ... ...it looked like the same old dull image. Can anyone tell me what is wrong ?
Increasing the resolution of an existing image is not going to make it any sharper.
It's virtually the same as 'zooming' into that image within your image viewer.
What size poster are you trying to print?
cya
R
Rehaan is offline
Old 8th January 2014, 17:54   #1817
Thanked: 174 Times
Wow! That's really good - and even more impressive that you did it in Flash!
cya
R
That artwork has been created by a designer who goes by the name of "dangeruss" and contributes on deviantart. It's actually a Vexel graphic created entirely in photoshop (except the wheels that were made in 3d studio max). There was no Flash involved. Not sure why he is claiming that he made it. Here are the links to the original artworks-
http://dangeruss.deviantart.com/art/...Vinyl-27351860
http://dangeruss.deviantart.com/art/...Clean-27351653
Astleviz is offline
Old 8th January 2014, 22:27   #1818
Thanked: 679 Times
cya
R
Trying to print a 2 1/2 ft X 4 Ft poster. Need a really sharp image. Basically its a graphical report (pie chart , line graph etc) generated from an application. Will I be able to get a better screen shot if I use a display of higher resolution ? Say a HD monitor?
girimajiananth is offline
Old 9th January 2014, 11:37   #1819
Rehaan's Avatar
If you're taking a screenshot, then yes, settings your display resolution as high as it can go (it will be higher if using a higher resolution monitor) will give you a better resolution image.
Alternately, the software application should have an "Export" option. (Or if not, try "Save as") and see if you can export to a PNG format (its sharper than JPG).
In the export options, set the 'DPI' high. Try 900 dpi and see if that gives you a large enough image.
cya
R
Rehaan is offline
Old 2nd February 2014, 13:39   #1820
Torqueguru's Avatar
Thanked: 165 Times
Hey guys,
I have been working on the video game, Forza Motorsport 5, which is the launch title for Microsoft's next gen console, Xbox One. I was a cinematographer for the game's cinematic sequences. Below are some of my virtual cinematography & Direction of Photography work from this game. All these renders are real time renders, from the Xbox one console. Nothing is pre-rendered in any 3d software. Hope you enjoy these.
Photoshop/Digital Art thread-3.jpg
Photoshop/Digital Art thread-6.jpg
Photoshop/Digital Art thread-13.jpg
Photoshop/Digital Art thread-24.jpg
Photoshop/Digital Art thread-22.jpg
Photoshop/Digital Art thread-18.jpg
Photoshop/Digital Art thread-7.jpg
TG.
Torqueguru is offline
Old 3rd February 2014, 14:15   #1821
Guite's Avatar
Thanked: 635 Times
I used paint.net to resize an image from 1024 X 768 to 7200 X 5400 . (I know , but I need this image for a big poster.) When I open the new image , I do not see any significant difference . I was expecting to see a really sharp image , instead it looked like the same old dull image. Can anyone tell me what is wrong ?
The original post is about one month old, so the OP probably does not have use of my response anymore but in the hope that others may benefit from it below is my work flow in similar circumstances.
Print to pdf using CutePdf Writer and import the resultant pdf into Photoshop at desired dpi or total pixel resolution. Crisp lines almost always guaranteed. Everybody may not have access to Photoshop, so there are options of printing directly to images file. The following links came up on Google search (I have not tried any of the linked software):
http://code-industry.net/print-to-jpg.php
http://sourceforge.net/projects/imageprinter/
Guite is offline
Old 30th March 2014, 11:39   #1822
aashishbc's Avatar
Thanked: 67 Times
hey guys ... sharing a few of my digital works. cheers.
Photoshop/Digital Art thread-abc_2.jpg
Photoshop/Digital Art thread-386834_10151053558261523_264247676_n.jpg
Photoshop/Digital Art thread-74230_456237366522_663762_n.jpg
aashishbc is offline
Old 1st April 2014, 18:27   #1823
rohit choudhary's Avatar
Thanked: 266 Times
stunning work sir
adding something from my side as well
Photoshop/Digital Art thread-slide6.jpg
Photoshop/Digital Art thread-slide29.jpg
Photoshop/Digital Art thread-slide30.jpg
Photoshop/Digital Art thread-9327571056_0385751bc2_o.jpg
rohit choudhary is offline
Old 8th April 2014, 03:04   #1824
kraft.wagen's Avatar
Thanked: 330 Times
I'm looking to custom paint my bike, I have some ideas but no clue how to do it on a photoshop, can someone help me add couple of options. I don't need anything to fancy to be Photoshopped, just want to see how it looks before I start working on the paint job. Or if there is some easy steps on how to do it in photoshop(or any other tool) will be helpful
Mods: Do delete if this is not appropriate on this thread.
kraft.wagen is offline
Old 8th April 2014, 12:45   #1825
Rehaan's Avatar
Hey guys,
Awesome!!
Nice stuff guys!!
Not sure if you want "graphics" or you are just looking at a different colour.
If it's the latter, using a the "Replace Color" options should work well.
More info: http://planetphotoshop.com/replace-color.html
cya
R
Rehaan is offline
Old 8th April 2014, 21:40   #1826
Thanked: 330 Times
Awesome!!
cya
R
I was looking to add a new custom theme, not adding graphics.
Thanks for the link
Something like below
Photoshop/Digital Art thread-erikbuellracingebr1190rsamericanflagpaint23.jpg
Source
Old 9th April 2014, 12:21   #1827
Rehaan's Avatar
That's kinda what i meant by graphics (ie. printed graphics on the paintwork).
Why don't you post some nice and high-res pictures of your bike here.
Also, if you post flat images of the custom theme you want, someone might take up the challenge and composite the two for you.
cya
R
Rehaan is offline
Old 9th April 2014, 21:12   #1828
Thanked: 330 Times
cya
R
thats how much I know bout graphics and painting
This is not my bike, but its same model don't have access to my bike pics now.
I want to have Indian Flag colors on this, nothing too complex as I will be hopefully doing it myself.
Option 1) To have flag colors all over the bike similar to Force India F1 car
Option 2) Have Indian flag color on the under hood alone like on the aprilla below
Photoshop/Digital Art thread-2009_cbr600rr_2000x1275_redblack_42515b_original.jpg
Photoshop/Digital Art thread-2009hondacbr600rrc.jpg
Sample
Photoshop/Digital Art thread-image.jpeg
Photoshop/Digital Art thread-img_3643.jpeg
Old 10th April 2014, 20:26   #1829
Rehaan's Avatar
Was just messing around and ended up with this (wasn't exactly reading your instructions - sorry). Will give it another proper shot after a week or so. Really busy at the moment.
cya
R
Rehaan is offline
Old 10th April 2014, 21:55   #1830
Thanked: 330 Times
Attachment 1228714
cya
R
Thanks Rehaan, Sure do send me some sample.
