Re: Tesla could build Powerwall battery storage systems in India Quote:
Originally Posted by rsidd kW is the power. kWh is the storage capacity. Both Powerwalls have 13.5 kWh storage capacity. Their maximum power output is different.
You could even use your microwave or iron or geyser or grill without exceeding that 5.8kW. If you use those for a long time, you'll make a dent in the total backup time. | Quote:
Originally Posted by ferrarirules Please reread my statement, I said powerwall type setups. There is nothing stopping us from creating a bigger battery backup setups ourseleves. My colleague and I have been doing research on how to replace DG setups in their society after the NGT order to retrofit them with gas. It is possible. The cost is a bit high today that is due to demand supply problem and lack of local production. |
I am talking about output of the system, which is 9kw for the higher model.
It is way too less for a society or a small factory, where backup is provided by DGs of, say, 150kW (conservatively speaking). Converting these existing systems to run on PNG is a one time expense, while piped gas is anyway ubiquitous nowadays and is cheaper to operate on than diesel.
The case for domestic use in more interesting. Here, it is going to be hamstrung by cost. I have a 10kW solar rooftop from Tata Solar (grid tied with net metering), which cost me around 5L back in 2021. No batteries, just the panels and the associated paraphernalia. Now, I can get a brand new CPCB compaint DG of twice that capacity, or a PNG fueled genset + gas connection of twice the capacity for much less than 5L. DGs under 19kW are anyway exempt from CPCB norms, and domestic usage is generally light and infrequent. Second hand DGs of 15kW capacity (very popular in standalone houses) can be had for as little as 1.5-2L, complete with automation panel.
Net net, I do not see any scenario in which a Powerwall type system can be cost effective and viable in the Indian context. In the cost of just the solar equipment that is supposed to power it, you can get conventional backup of much more capacity at a far cheaper price.
For what it is worth, my own house is backed up by a 4kW 48V HKVA inverter, and it runs everything except ACs and geysers (water pump, pressure pump, washing machine, microwave, dishwasher + the usual lights, fans, TV, fridge etc). Entire setup cost was about 60k, IIRC. Solar+Li ion battery type systems just cant compete.
