Originally Posted by electric_eel
Cruise control drains battery
Naturally, if we are to maintain speed then it would be best to just use the cruise control. This is indeed correct if we were driving on a flat high way. On the other hand if the high way goes up and down, which is often the case due to fly overs, Cruise control behaves like an acceleration-deceleration cycle: The car does not gain any kinetic energy through out the drive but at the top of the incline it has gained potential energy (P = mgh). We can repeat the above calculation with P instead of K and would arrive at similar conclusion
I see these comments a lot on the internet. Similar for ICE cars where cruise control is claimed to be inefficient in hilly terrain. I am not convinced about that at all. It might be true, but only under specific circumstances, if at all.
What nobody seems to be taken into consideration is the fact that there is a hill on the road you are driving on. You need to get over it, no matter what. You have two options, you go across using cruise control, or not. So if you want to make any statements on the effectiveness of cruise control it should, my opinion, be a comparison between those two scenario’s. Hill up and down with cruise control on and hill up and down without cruise control.
Modern cruise controls are capable of controlling the cruising speed within a very narrow bandwidth. They have virtually no hystereses.
So when you drive up a hill, the speed is kept constant, which means you don’t loose any kinetic energy (no change in speed) and gain potential energy (height). You have used extra energy going up the hill compared to driving at the same constant speed on a flat road.
When you come down the hill, whether and how much regen takes place is, my opionion, dependent on how steep the decline is and how the regen logic on your car works.
So this is what needs to be looked at: How much extra energy is required going uphill at constant speed and how much of that extra energy can be captured going downhill. Next you need to compare that with a driver taking manual control.
My gut feeling is that in most case the cruise control scenario will be more efficient than the manual driving scenario. One of the reason is that almost anybody will slow down going from a flat road up on a hill. Which means you loose kinetic energy. And as the speed is squared (vČ) in the formula of kinetic energy dropping a few kilometers/hour means a lot of energy is lost.
On ICE cars the question whether cruise control makes (economic) sense in hilly terrain is identical in the sense, you need to compare the two scenario’s, with and without cruise control. Obviously an ICE cars does not have regen, so in most cases will be worse off than the EV with regen.
On many ICE cars, the cruise control controls the engine RPM and thus the speed. When the speed picks up going downhill the cruise control starts to close down the throttle to the point where the engine is idling or driving by the wheels/transmission and thus effectively engine braking. Not all cruise controls have the capability to also control the brakes. So the most braking power you can get is engine braking. Which means you end up going faster than the set speed on the cruise control, thus building up additional kinetic energy, or wasting it and braking manually.
In the end the efficiency of cruise control in any scenario, is comparing it to a scenario without cruise control. All else is irrelevant. That hill is in front of you and you need to get over it (literally and figuratively
And that is a very different way of looking things than most of what I see on the Internet.
Maintaining a steady constant speed does indeed mean no change in kinetic energy, but a reduction of speed be it a poor cruise control or your typical human twitchy right foot, means a tremendous loss of kinetic energy, much more than your typical gain in a bit of extra potential energy.
Look at it this way, if you drive an EV at constant speed up and down a hill, compared driving an EV up and down a hill on cruise control what is the difference? The only difference is precise your right foot is in maintaining the constant speed like the cruise control would. In these sort of case, man against machine, man almost always is less efficient! If your right foot is capable of mimicking the cruise control a hundred percent I don't think there would be any difference in regen either?
Jeroen
