Originally Posted by electric_eel We might as well use the electricity directly to charge the batteries. (besides more important domestic uses). |
True. At around 50kWh/kg by conservative estimates, FCEVs would require 3x more energy to go same distance. Model S can go 600km on 100kWh. Mirai needs equivalent of 300kWh for this (6kg at 50kWh/kg).
The lesser talked about H2 ICE the better, with half the efficiency of fuel cell, H2 ICE is 6x more energy hungry than an EV to go same distance.
One of the biggest advantage that is touted for Hydrogen cars are that fueling is fast. But is it really?
In my 6 months 12,000 Kms ownership I have charged my Nexon EV only four times of roughly 30 min topups at a fast chargers
Hydrogen filling is NOT FAST if there is a queue like cng stations. Unlike EVs, being unable to “fill” at home only leaves filling stations as the option. The avg charger will have much less “utilisation” rate than the avg H2 station. With EVs, about 5-10% is public charging. With any other fuel, it’s 100% public.
Most proponents of Hydrogen tech don’t really understand the intricacies themselves. They usually see one of those clickbait yt vids which only show the “car” part of filling, not the “station” part (not like there are many stations to film to begin with)
Current CNG and LPG infra can work with almost zero downtime due to little to no temperature delta during depressurisation of the tank when dispensing fuel from tank to vehicle. Still, it’s slower than P/D.
The temperature delta is mostly due to much higher pressure of H2 storage compared to CNG/LPG and the properties of H2. PV = nRT dictates that there WILL be a temp/pressure delta when the volume of gas in the tank changes.
The repressurisation after each refill is easily 30min for hydrogen.
Once the vehicle has been refueled, the HRS storage pressure has decreased due to the exited mass. Simulating the refilling of the storage from the initial state, i.e., 48 MPa and 15 °C, back to its nominal conditions (50 MPa), the station takes 1648 s (around 30 min). The refilling time speed strictly depends on the compressor throughput, which is considered constant and equal to 0.0062 kg/s.
Instead, the compressor cooling demand is constant ed equal to 15 kW. The reason is that the operating temperatures of the intercooler are fixed, and the mass flow suctioned by the compressor is also constant.
via
ScienceDirect
The cryogenic storage, the pipelines, and dispenser are all cooled, needing electricity for this process. The net time for hydrogen refilling is about same (10min filling mentioned in this very article + 30min repressurisation process) as one would need for DCFC.
I can attest that 30-45min is the avg time I spent at highway DCFCs as well. And it’s probably around same considering the depressurisation requirements for hydrogen as well.
Only those who DON’T understand the tech intricacies, think that hydrogen is somehow advantageous on the filling speed front.
I solely blame the YouTubers who display H2 as some holy grail tech. Even seasoned YouTubers like RealEngineering and EngineeringExplained have not raised this point yet, in any of their hydrogen videos.
The components in an EV are relatively cheap and low tech (which is good) and have been invented/developed independent of their EV application
That’s quite an interesting point. Now that I think about it, at some point we will see the GaN chargers shipping with phones and laptops in DCFC market as well. Much more compact and less heat.
MOSFET SiC Inverters are already being used in grid for renewables (mostly solar PV) trickling down from EV industry. So it’s a 2 way exchange which is great for innovation.
HEVs like Mirai will remain an engineering marvel worth placing in a Technological museum. They might also be used for joy rides to the parliament by misinformed transport ministers but that is just about the only road trip they would see.
We didn’t really see anything about Gadkari’s Mirai. What happened to it? Where did he even get hydrogen filled? Is it some high school science kit to make h2 at home?
Might explain why it’s been a while since the last appearance, couldn’t make enough yet to fill the tank.
