Now let’s move on to the most important aspect, the drivetrain. The car has Two Electric Motors, one powers the front wheels, while the other powers the rear wheels, making it an
All Wheel Drive (AWD) vehicle. The front motor produces 175hp and 220Nm of torque while the rear one produces 268hp and 400Nm of torque. Combined, the vehicle has a little over
440hp and 620Nm of torque. It accelerates from
0-100 in 5.3 Seconds which is a very quick time for a vehicle of this size and capacity. The top speed is limited to 180km as per the Chinese standards.
The motors are powered by
44.5kWh Ternary Lithium Ion Batteries out of which, 39.5kWh is available for powering the wheels and the remaining is reserved for powering the onboard electronic equipment. It takes about
30 minutes to charge the battery from
20% to 80% when using a fast DC Charger. DC Chargers can be found all over China, from shopping mall parking spots to dedicated charging stations, they are quite standard now. If you are charging the vehicle with the provided AC Charger, it takes about
6.5 hours to a 100% charge.
The battery offers a 215km range with the car driven solely on the battery, under CLTC working conditions. While this may not be a lot, the car comes with a Range Extender, which is a
1.5l Turbocharged 4-cylinder Petrol Engine. The engine does not power the wheels, it serves as an onboard electricity generator that charges the batteries and provides electrical energy to the motors on the go as well. Its connected to a 65L fuel tank and with a full tank and a fully charged battery, the company claims the range of the vehicle to be
1315km in total, driven under CLTC working conditions, which is actually quite a lot, considering that a similar sized vehicle, which is powered only by an internal combustion engine would fetch a lot less range in 65 liters of fuel.
Moving on to the interior of the vehicle. The first thing that you notice when you sit inside the car is the steering wheel. It is a heated steering wheel, clad in Nappa Leather, which is connected to an Electronic Powered Steering (EPS) mechanism. In the center, you will see a screen that shows all the vital information like range, gear position, battery level and other similar parameters. This is a touch screen and you can cycle through the information and set the display depending on your preference.
Towards the center, you will see two
15.7 inch AMOLED screens, with the left one being the main screen where all the functions of the car can be controlled from, and the right one being the passenger screen, which itself has a wide array of functions. From the center screen, you can control the Air Conditioning, Massage Seats, Navigation, Play Multimedia, and these are just the tip of the iceberg, it has a wide range of options which include but are not limited to
Voice Activated Commands as well. Yes, you heard that right, voice activated commands! All you have to do is say Li Xiang Tongshue and tell the car what you want it to do and it will do it for you. Like opening the windows, turning on the air-conditioning, putting on music or a movie.
The car receives the voice command through 06 microphones in the car, 02 installed in each row of seats. Each microphone can be individually enabled or disabled if you want to prevent children in the backseat from using these commands. This feature is currently operated using the Chinese language, but Li Auto says that in all vehicles manufactured for the global market, there will be English and other languages as well.
As if voice commands were not enough, the car also has
Gesture Control. You can tell the car what to do just by doing hand movements and the car recognizes the movement using multiple cameras and proximity sensors and performs the actions for you. The gesture control can also be used in combination with voice control in which you tell the car to do a certain action and then point towards it. For example, you can point towards a certain window and then tell the vehicle to open that window and it will open it for you. This is a very impressive feature and the fluidity of this system is particularly impressive.
The onboard electronics system is powered by
02 x Qualcomm Snapdragon 8155 Processors and
24GB of Ram and let me tell you, these are not just numbers, they give you a very fluidly smooth experience when using any of the screens. There is no lag at all, everything happens very quickly and while we might not know the refresh rate of the screens, it seems to be pretty high to show all the graphics move very smoothly, speaking of which, the Graphical User Interface of the vehicle is designed very well, which, even with my lack of understanding the Chinese language, was easy to use, even though everything is currently in Chinese.
