Old 9th March 2016, 16:38   #1276
fine69's Avatar
Thanked: 1,467 Times
Re: Tools for a DIYer
Is there a substitute to using Torque wrench? I need to fit some heavy duty hook eye anchor bolts on the walls and realized that they require specific torque to be applied to these bolts. I don't really want to buy a torque wrench costing 10k so looking for an alternative here.
While we are on the topic, I have never seen any of the carpenters using torque wrench when using anchor bolts, they tighten them with all their might and the bolt tends to hang on to stuff pretty well too. In fact I have a pull-up bar hanging from anchor bolts which the carpenter had tightened using a regular adjustable spanner, no torque measurement considered at all.
fine69 is offline
Old 9th March 2016, 16:46   #1277
ajitkommini's Avatar
Thanked: 124 Times
Is there some place that offers high value tools like this on rent? The local hardware guy near my place has a collection of large drills, demolition hammers etc. displayed outside the store that he gives out on a rental basis. There might be some similar service for precision tools as well.
ajitkommini is offline
Old 9th March 2016, 19:00   #1278
Thanked: 2,786 Times
How much torque is specified? Normally tightening fully (10-12mm dia bolt) with 300mm long arm of the wrench does the job for most masonry jobs. Torque ratings are given for critical fastener. Just enough to tighten them but not enough to break the bolt. In general the "just enough" stretches the bolt a tiny bit, so it is not to be used a second time
Aroy is offline
Old 9th March 2016, 19:01   #1279
Thanked: 52,801 Times
You can make your own Torque wrench, have a look:
http://www.engineeringtoolbox.com/to...le-d_1909.html
Not sure why the carpenters don’t use them, maybe they havent got them, or they don’t know what specific torque needs to be applied? Or they haven’t got a clue why you would need to torque. But then again, I have seen a number of houses and apartments collapsing in India over the last year. So somebody got something wrong or forgot something!
Jeroen
Jeroen is offline   (1) Thanks
Old 9th March 2016, 19:07   #1280
Thad E Ginathom's Avatar
Thanked: 27,360 Times
I never heard of torque wrenches being used outside of mechanics!
Perhaps, though, where lives may depend on a bolt (eg lift-shaft fittings or building safety-harness points) it might be necessary for the manufacturers to state such a thing.
My bet is that they want to prevent overtightening, as many installers would go for this "all their might" approach. I see plumbers doing the same thing with screw-thread steel pipes.
Thad E Ginathom is online now
Old 9th March 2016, 19:07   #1281
fine69's Avatar
http://www.boun.in/Anchore7ba.html?T...d%29%20Anchors
Are you saying that if I normally tighten it enough, it should be ok. I don't mean to use it ever again, just put it and forget it.
Or would using too much of strength defeat the purpose of the anchor bolt?
EDIT: My objective is to put these bolts (in the link) in the wall so that they don't come out even if I try to pull them out with all my strength. I will be using them for a workout.
fine69 is offline
Old 9th March 2016, 20:10   #1282
See the posts above, which give a method of measuring the torque and in your case getting the right torque for tightening the bolt.
If it is a 10mm or 12mm bolt, tightening with all your strength will be fine (it is difficult to break the bolt), for thinner bolt you may break it by over tightening.
In my experience, anchor bolts in the wall need tightening enough to prevent their working loose with vibration, but you have to be sure that the hole in the wall is not only the proper diameter, but the wall material should be solid brick/concrete, not plaster or material which will crumble. All our geysers (20L and 30L) models are secured using 8mm bolts, tightened till they are firmly embedded.
Anchor bolts expand as you tighten them, so once fully tightened you can not pull them out, unless the wall material crumbles.
Aroy is offline   (1) Thanks
Old 9th March 2016, 21:54   #1283
Torque wrenches are (or should be) used in all sorts of application and or industries. Other then car mechanics, marine/naval engineers uses them on a vast array of different equipement, they are used in the aviation industry.
They are used in the telecom industry, certain (fiber) connectors need to be torque-ed properly.
People who put up the likes of ferris wheels and such use them.
Lots of bits and pieces on many industrial plants require torque wrenches. E.g. think of pressure vessels.
We often think of torque wrenches as putting a lot of torque on a bolt/nut. But it’s about getting the exact correct amount. The torque that is needed to properly install a simple fiber connector is very small. A six year old has enough strength. But the trick is to get it exact right so the fiber doesn’t deform, but it’s still tight enough to ensure a water tight seal.
Watch makers use torque wrenches! The list is endless.
If you want some of the basics behind torque, have a look at this:
Way past the DIY stage, but here is the sort of stuff we used on the big marine Diesels etc. This (hydraulic) tool actually stretches the bolt without twisting (torquing) it. Very precise loading of the bolts!
Enjoy, Jeroen
Old 9th March 2016, 22:41   #1284
Yes, like I said: mechanics. I never limited that to cars! But no matter: nice examples
The last torque wrench I came close to was in the hands of my dentist: he was getting the torque on an implant right.
Old 11th March 2016, 18:13   #1285
Thanked: 3,000 Times
Bosch has announced an offer on the aquatek and the screw driver set combo in Bangalore. Details are herewith.
unk9ja is offline
Old 11th March 2016, 19:52   #1286
Jaguar's Avatar
Thanked: 2,676 Times
Any idea what this battery is called and if it is available locally? This came out of my Panasonic trimmer and the same is available in ali express. A regular rechargable AA battery fits the slot but there is about 1-2 mm gap at the negative terminal side for which I need to do some juggad if I can't get the exact battery.
Jaguar is offline
Old 12th March 2016, 10:43   #1287
Thanked: 383 Times
Attachment 1484829
Please see the attached battery specs file. The code 1409A is listed on pg 3. Have pasted the relevant portion below. This is a 6V battery. So I don't think your idea of using a regular AA battery will work. Duracell and Eveready product numbers are listed. I am sure you will be able to get these in the US, but it may not be easily available here. Try the consumer electronics service outlets.
reverse_gear is offline   (1) Thanks
Old 15th March 2016, 17:35   #1288
Thanked: 7,293 Times
Guys any recommendations for a precision screwdriver set? Not able to conclusively decide on one based on the user reviews on the shopping portals.
Dry Ice is offline
Old 22nd March 2016, 22:47   #1289
thoma's Avatar
Thanked: 1,447 Times
I'm looking for a budget-yet-not-flimsy power saw for some DIY wood works; jigsaw or circular.
Any suggestions?
thoma is offline
Old 24th March 2016, 13:03   #1290
tharian's Avatar
Thanked: 8,138 Times
3M has this treatment for the exhaust system of the car.
I had enquired at one branch and they said it is a silver coating which I think is nothing but paint to prevent rusting and give it a new look .They quoted over 1k for the same and it sounded like it is useful on stock exhaust systems.
I would want to do this as a DIY on my car. The exhaust system on my car is a aftermarket one from Red Rooster and it had a coating which has worn off now over 4 years. Few years back I had bought this rust proof coating which was in a can and sprayed that on the pipe and before I knew it , peeled off.
Does anyone have an idea of a good rust proof spray which can withstand heat as well for use on the exhaust system. Thankfully, there is no issue of rust in the system and I would like to give a fresh look and at the same time proof it from future age related breakages.
tharian is offline
