Old 13th June 2015, 11:48   #1051
Thanked: 2,815 Times
Re: Tools for a DIYer
Damn, that is one HUGE and solid drill! And looks like a vintage one. Where did you source it from?
The drill is over 45 years old.
The bits I bought in Tajikistan, in 2007 when I had gone there for a 2 week stint. They are Chinese and should be available where ever hardware is sold. In Delhi the main market is in Chawri Bazar, but I believe they are available in Goving Puri also.
Aroy is offline   (1) Thanks
Old 14th June 2015, 12:13   #1052
diyguy's Avatar
Thanked: 581 Times
Preferably get one that is 300mm or longer. I have a 20mm carbide, 450mm long drill.
My biggest fear when drilling is the bit breaking and flying as shrapnel. I am not an expert but have broken a bit once though it did not fly. Is this something that happens with the longer bits? How does one protect against?
diyguy is offline
Old 14th June 2015, 15:34   #1053
adrian's Avatar
Thanked: 1,263 Times
A helmet with face shield, eye protection goggles and gloves are a must when using power tools.
regards Arun
adrian is offline
Old 14th June 2015, 20:40   #1054
lapis_lazuli's Avatar
Thanked: 2,911 Times
Where can I find some high temperature grease, in small quantity, say 0.5-1kg pack? I am talking of copper grease/moly (molybdenum disulfide) grease (commonly, for use in brakes, brake pad replacements). Online or any other outlet preferably in Delhi NCR region would be great. OTOH, any grease, non soap based, capable of withstanding 300-400 degrees C plus, would do.
lapis_lazuli is offline
Old 15th June 2015, 17:40   #1055
http://www.dowcorning.com/applicatio...OD&country=IND
(http://www.dowcorning.com/applicatio...IND&language=E )
https://www.iocl.com/products/IndustrialGreases.aspx
http://www.tolexo.com/skf-high-visco...se-319215.html
Aroy is offline
Old 15th June 2015, 19:17   #1056
Thanked: 3,009 Times
Google and search for any dealers in your area for Omega lubricant. They have some of the best lubricants in the market for extreme application. Omega are Australian based company. But mind you they are pricey though.
unk9ja is offline
Old 16th June 2015, 11:45   #1057
sagarpadaki's Avatar
Thanked: 6,117 Times
Purchased Dremel 3000 off PayTM. Got a sweet 40% cashback which meant the tool cost came to 3900 bucks
Used the tool right away to smooth-en the edge of a table glass to a curved shape using one of the grinding bits provided. The tool did the job well. The rubber body is very ergonomic and helps keep a firm control over the tool.
A must have tool for all DIY'ers
sagarpadaki is online now   (1) Thanks
Old 21st June 2015, 10:37   #1058
adrian's Avatar
Made a couple of additions to my tools
Automatic wire stripper / cutter
Glue gun
Foot switch
This is of a local make and is a six speed one. Don't have any specification details stamped on it. The pin reads 9 amps and so it is useless with the angle grinder. As of now I am planning to take it apart and make it more heavy duty and make it a simple on / off type by throwing away the resistors. The singer shop here only had the foot controller and motor combo for sale. I am still on the look out for an industrial grade foot switch like the one below
regards Arun
adrian is offline
Old 21st June 2015, 18:01   #1059
fine69's Avatar
Thanked: 1,467 Times
So I used Berger's White Primer (ST) Solvent Thinnable on a metal door that I was planning to paint.
http://www.bergerpaints.com/products...hite-primer-st
After putting one entire coat of this primer I was told by someone that this particular primer is only meant for wooden doors and not the metal.
How badly screwed am I? I've wasted almost an entire day putting that one coat on and do not have the energy to strip it down using sandpaper. Is it really going to damage the door if I leave it as it is for a week so that I can get a painter from outside to sand it and then use the right primer, help please :(
fine69 is offline
Old 22nd June 2015, 10:38   #1060
fine69's Avatar
Spoke to a painter, there isn't any issue and I can use the metal primer and then paint the door, phew!
fine69 is offline
Old 2nd July 2015, 12:05   #1061
I have the screw driver bits like those circled in Red in the below pic. I want to use them with a drill machine which require the kind of adapter circled in Yellow.Any idea where i can get the adapter alone?
Old 2nd July 2015, 14:20   #1062
ilangop's Avatar
Thanked: 912 Times
Attachment 1388510
You don't need an adaptor. You can insert them and positively lock them in between the 3 jaws of the collet.
Just ensure you have a speed & direction controlling knob in your drill machine.
ilangop is offline
Old 2nd July 2015, 14:52   #1063
Thing is those bits are small in length, 2 cms max. And if i am screwing a screw a bit deep(2-3 cms inside from surface) then the collet will not allow the bit to reach the screw head.
Old 2nd July 2015, 18:29   #1064
Check out at Azeez Trading Company on the SJP road. It is on the left towards KR market from Town hall side just as the Sirsi circle flyover ramp starts. He has a good variety of tools. Speak to the owner who is a Muslim, he will suggest you an alternate if they don't have a solution.
But these days they stay closed during afternoons and close early at 1730-1800hrs due to Ramzan.
unk9ja is offline
Old 2nd July 2015, 19:14   #1065
adrian's Avatar
Why don't you use screw driver bits for power drills ?
regards adrian
adrian is offline
