Old 27th July 2010, 10:36   #226
sajjt's Avatar
Thanked: 116 Times
@Deralte Sir, Bingo!!! the keyword is "usage" is what hit the nail. I agree completely, one should go based on the usage. Thank you very much for helping me understand; now next time when I go buying one, I'm sure to review your post & hit the market; I'll buy things based on my needs.
I'm looking for buying a hand tool, that is something like this to serve the following purpose by simply changing the blades
1. Cut wall, glad if it could cut concrete
2. Cut metals such as iron/alumunium, wood & water pipes (both Gi & Pvc)
3. Additionally extend to polish car like this
I don't want a heavy dutier, but a medium one for house hold purpose to aid in plumbing & light motorcycle work.
My questions are...
1. First of all, is my list valid? I mean, can I accomplish the multiple cutting jobs by simply changing the blades & without varying the RPM's or the machine? More simpler words, does one machine fit to do all the jobs?
2. Can I simply replace the blade with a buff & extend to polish the car? Is there such a model available?
3. I intend to buy Bosch, any additional information is highly appreciated on how to look for a ideal machine. Thanks.
Angle Grinding wheel can be used for cutting with the correct wheel, but it's mainly used for grinding so using it for other usage like cutting will be not an easy job.
I don't think that it can be used for car polishing as its rpm is too high to make scratches while you doing. One slip of hand will set you back by a couple of thousands for the re paint. But if you have enough patience and skills then it may work.
sajjt is offline
Old 27th July 2010, 12:05   #227
mkh
Thanked: 135 Times
DA polisher
Anyone has an idea where in bangalore ( or around) can we get a DA polisher- used basically for surface treatment?
mkh is offline
Old 27th July 2010, 13:33   #228
Thad E Ginathom's Avatar
Thanked: 29,921 Times
Another of my cautionary notes: an angle grinder is a very dangerous tool: eye protection, and preferably more, ia an absolute must.
Thad E Ginathom is offline
Old 27th July 2010, 13:44   #229
aargee's Avatar
Thanked: 10,048 Times
Ok, I'll buy a pair of goggles even if they don't give one free along with it. But any help on the model/specification is highly appreciated.
aargee is offline
Old 28th July 2010, 00:28   #230
Hmmm... don't know. There are probably international standards, but do they get applied here? something hard sent flying by a grinding wheel is pretty destructive.
Full-face protection would be ideal...
Old 28th July 2010, 05:32   #231
aargee's Avatar
Ok, I'll wear a helmet
Jokes apart, any idea on the cost of this? Personally I prefer Bosch, but still, are there any other renowned brands? I don't want those Chinese imports.
aargee is offline
Old 28th July 2010, 06:37   #232
Mpower's Avatar
Thanked: 1,735 Times
you need safety glasses that cover the sides. IF you are wearing regular glasses then you need side sheilds.
Mpower is offline
Old 28th July 2010, 09:17   #233
aargee's Avatar
No Sir, I'm really intending to buy the safety googles, as I've seen the sparks that throws up when cutting the iron bars during constructions & would like to buy this. Infact, I would like to wear gloves & set out to work like a professional. Though people might make fun, but the gloves help in holding the iron bar, without me having to pour water often when cutting.
I used to hate tools & loved working with hands; but then the outcome of using the tools is really awesome, great quality work without much experience is what impressed me & hence the look out for tools.
I cannot afford for something like Wurth, Craftsman or Pferd right now, so I guess I've to settle for Bosch. Appreciate to suggest some alternatives for Bosch for wide choices & suggestions on purchasing. Tks.
aargee is offline
Old 3rd August 2010, 18:18   #234
aargee's Avatar
Update
I inquired about GWS 6-100 - MINI ANGLE GRINDER & the price is about 1850 which is little discounted than the normal selling price of Rs 2130 against the MRP 43XX. I hope this is normal. Now this comes with some 3 disc plates, which I think is for sanding; for my need on metal & wood cutting, there're 2 blades that costs around Rs 200 each.
They also showed one more product, Hitachi, which is as good as Bosch & its "Made in Malaysia" product & the store owner said Hitachi was better than Bosch as its little heavy duty when compared.
Which one should be better? Hitachi or Bosch. My requirements are not more than cutting a thing sheet of metal or pipe or wood of 3-4 inches thick. Pls provide your opinion
Bosch - BOSCH Angle Grinder GWS 6-100 [GWS 6-100] - RM213.00 : Technotools, Hand Tools & Equipment Distributor
Hitachi - Hitachi G10Sr3 Angle Grinder 100mm / 4" Disc 730w 240v : Tooled-Up.com
aargee is offline
Old 3rd August 2010, 19:15   #235
I've never had an angle grinder, but I think this is a cutting and grinding tool for metal and masonry. I don't think you can sand with it, or cut wood cleanly.
Could be wrong, though!
Old 3rd August 2010, 19:40   #236
aargee's Avatar
I'm confident it can be used for sanding, like you said, I too have my own questions on how it can be used to cutting wood. For masonry, they use something like this for cutting the steel - Bosch Power Tools in Online Buyer's Guide, atleast that's what they're using near my house (not bosch though). This hand tool can be used even for cutting through the wall. Basically, I think, this tool is good to make any 3 inches cutting or something of that sort due to the limitation on the blade's size.
If there's a tool to remove the rounded screws (changed from hexagon to circular) or highly tightened screws, that's one of the greatest asset of my lifetime. Does anyone know or heard about such a tool? Any pointers are highly appreciated. Tks.
aargee is offline
Old 3rd August 2010, 21:16   #237
There is a tool for removing stuck bolts, but I never actually had it in my hands. I guess it would work with rounded (how did you do that? using the wrong size key? Tut tut ) hex-head bolts, as it would grip in the hole. Sorry, don't even know what it is called.
Old 4th August 2010, 08:58   #238
aargee's Avatar
Aaah!!! I need to know that name as I frequently encounter such bolts; one such is my frontal disc brake on my Rx which has promptly refused to be removed & the pads are tightened with the discs. It also has shaved off the hexagon edges so that its almost circular now. I'd to release the other bolt to let go off some oil to make it free.
Can someone help me on this pls? Pls point out a suitable tool that can be used to remove (unscrew) highly tightened bolts. Would appreciate even if it were a machine tool. Tks.
aargee is offline
Old 4th August 2010, 09:53   #239
DerAlte's Avatar
Thanked: 2,920 Times
Keep a can of WD40 handy for such occasions. If when removing a bolt you feel that it is going to strip the bolt (too tight), spritz some below the bolt head and, if exposed, the thread side, and wait for some time before trying again. Prevention is better than cure , so be careful while removing bolts or nuts.
DerAlte is offline
Old 4th August 2010, 10:06   #240
aargee's Avatar
Sorry sir, I'm weak in this area. Are you talking about this one? If not, pls educate. Tks.
But since the damage is already done, is there any remedy now or any recommendation on tool is highly appreciated. I'm looking forward to buy that Bosch tool & few other tools & would like to buy a tool for the bolts that are giving me hard time along with WD40. Any suggestion on tool is greatly appreciated. Tks.
aargee is offline
