I grew up seeing all the DIYs my father used to do to create, renovate and fix things in and around our house and the vast collection of tools he had accumulated over 40 years. He was more of a manual tools guy with just 3 electric tools, a drill, angle grinder and a welding machine (why would one need a welding machine at home). He has a storage room filled with all the tools and scrap materials dumped into a 10x8Ft cabinet that are 4ft deep. You cant reach your hand deep inside how much ever you try to stretch and if you have to get something from the rear, you have to crawl your head inside and reach for it. A lot of tools are so deep inside those shelves that I am sure many of them wouldn't have seen the daylight since 1978 which is when he built the house.
So when the tool bug hit me, I always wanted to buy things which he never had and the obvious choice was electric. I started with a Dremel, then a circular saw, a blower, polisher. My first cordless tool was a Cordless Vacuum (Dirt Devil). It was a 15v NiCd and hardly lasted 15 mins per charge. In a year the battery died.
Then in 2012, my friend gifted me a Milwaukee M12 Cordless kit with drill and an impact driver. I had seen this tools in US, but thought of it as some Chinese brand. Only after getting the tool, I came to know about the brand and how highly regarded it is in US.
The drill is so compact, light weight and powerful enough that this is still my go to tool for any screw driving or drilling that do not involve concrete. It can easily drill through cement/brick walls, tiles, steel and wood. Out of my entire tools, this is the most used/abused and still works fine even after 7 years.
It has a 10mm metal chuck, 2 speed gear, variable speed trigger and a led light. It has a brushed motor, rated torque of 30Nm with adjustable clutch, 400rpm in gear1 and 1500rpm in gear2. It can easily drive a screw into plywoods and soft woods without drilling.
The next one was the Milwaukee M12 impact driver. This is rated for 96Nm of torque. It can drive screws directly into hard wood and can remove rusted/stuck screws, nuts and bolts. I even tried removing the lug nuts of my alloy wheels and it did remove the lug nuts. But it took almost like a minute for each nut. Smaller nuts are a piece of cake and considering the compact and light weight, this is another frequently used tool for DIYs. This is also very useful for safely screwing/unscrewing Philips type screws since this will not slip and damage the screw head. Chances of a slip is very high when you use a drill or a manual screw driver for very tight screws.
This uses a 1/4Inch Hex driver which fits the common hex driver bits available. I also have a adapter to convert the 1/4 hex to 1/4, 3/8 and 1/2in Square drive to fit the sockets for nuts and bolts. Rated for 96Nm torque, it has a max speed of 2500rpm and 3300Impacts per minute. Also includes Led light and Variable speed trigger.
I was impressed by the m12 series and bought the next tool, The reciprocating saw. You can use it to cut wood or metal and has different type of blades with different lengths suiting each application.
The blades are universal type and provides easy removal/insertion with just a twist of the black knob. Compatible blades are available here in Bangalore from Bosch, Dewalt etc.
After using the 12v tools for a couple of years, I wanted an impact wrench powerful enough to remove lug nuts. In 2014, Milwaukee launched its 18V high torque impact wrenches capable of 1000Nm+ torque. The price was too high ($600+). There was no competition for Milwaukee and youtube were filled with videos of people removing rusted axle bolts, and beating pneumatic wrenches. I somehow resisted the purchase and in an year, DeWalt launched the DCF899 with 1500Nm of breakaway torque. I could no longer resist and I bought it through a friend who carried it to India. This is the most powerful and most expensive tool I have bought so far, unfortunately it is also the least used tool in my inventory. How many times would you need a 1000Nm+ torque for a DIY? However the only consolation is the fact that the tool is so powerful that even after 5 years of launch, DeWalt haven't updated/upgraded the tool and the competition is still catching up. This tool has become a legend and is still rated the best cordless impact wrench.
A size comparison with Milwauke.
It is a heavy tool at 3.5Kg with battery and is built to withstand falls from 6ft height. It has a 3 speed switch and also has a variable speed trigger. The 3 speed switch is good for controlling the torque. At speed 1, the max torque is ~250Nm, 2 at 500Nm and 3 at 1000Nm. This tool can destroy smaller nuts/bolts if you are not careful.
The following year, I was installing a wall mounted Inverter and required drilling through RCC which required a corded hammer drill. I wanted a cordless version and started searching for my next Dewalt drill since I already had the 18v battery and Charger. It was the time DeWalt had launched the 60v(54v) Flexvolt batteries and were giving free 60V batteries with most of their tools. I picked up their Hammer drill and got a 60v(54v) Flexvolt battery and charger.
The 60v(54v) battery along with the 20v(18v) cousin. The 60v battery is backward compatible and can be used in all Dewalt 18v/20v XR tools
This has a 2 speed gear, Brushless Motor with 70Nm Torque, adjustable clutch and Variable speed trigger. The slide switch above the battery is for adjusting the LED light brightness. The 3rd position is torch mode and the led stays on until you switch it off.
In 5 years, I had purchased atleast one cordless tool each year and I thought that to be a good strategy to build up my arsenal.
Next year, I bought 2 Milwaukee M12s. A rotary tool (Dremel) and a MultiTool. I already had a Dremel 3000, but couldn't resist the cordless craze. The rotary tool is a just a clone of Dremel and all dremel accessories fits on this tool.
![Tools for a DIYer-1rotary.jpg](https://www.team-bhp.com/forum/attachments/diy-do-yourself/1938232d1688451052t-tools-diyer-1rotary.jpg)
Speed is rated at 5000-37000rpm. Unlike other Milwaukees, this one do not have an led light.
The MultiTool, for those who are not aware of it, is a multipurpose oscillating tool. With different accessories, it can be used as a scraper, grinder, cutter, sander, saw. Also there are somethings that only a multitool can do, like cutting perfect square holes or cutting off nails in between joints.
This one has a speed dial marked from 2 - 12 (Cant understand why they couldn't make it 1-10 or 1-12) and is rated for 5000-20000 oscillation per minute. This too do not have an led light.
Last year I ordered a Dewalt 20v compact blower. Unfortunately, none of my friends could carry it to India and the item is lying in California. I am hoping someone would bring it during Christmas this year. This one can blow 100CFM of air at 200kmph. This is the smallest blower from DeWalt and have models rated for 450CFM at 280kmph.
![Tools for a DIYer-dewaltblower.jpg](https://www.team-bhp.com/forum/attachments/diy-do-yourself/1938238d1688451105t-tools-diyer-dewaltblower.jpg)
Pic copied from Amazon.
Another Dewalt I ordered early this year is the 20v Angle grinder. This one is rated for 850W and 9000rpm no load speed. This was ordered from Sydney (
https://sydneytools.com.au/) and again is yet to reach me.
![Tools for a DIYer-dewaltanglegrinder.jpg](https://www.team-bhp.com/forum/attachments/diy-do-yourself/1938239d1688451105t-tools-diyer-dewaltanglegrinder.jpg)
Thanksgiving is the best time to order tools from US and this week I have my eyes set on a Dewalt 20V JigSaw.
Next: The batteries and chargers.
