Old 24th May 2018, 12:24   #76
Thanked: 1,150 Times
Re: DIY : Cleaning your MAF Sensor for Rs 120
Can some please help me identify the MAF sensor in the Ford EcoSport TDCi engine bay?
I have the image of engine bay, however it is not getting uploaded here.
Your help is highly appreciated!
ObsessedByFIAT is online now
Old 24th May 2018, 12:32   #77
Thanked: 21,451 Times
Highlighted in yellow
DIY : Cleaning your MAF Sensor for Rs 120-engine_01.jpg
a4anurag is offline   (3) Thanks
Old 24th May 2018, 12:39   #78
That was quick! Thanks!
Mine is a 2014 make TDCi and seems there are a few changes in the engine layout. Nevertheless this surely helps and planning bro clean the sensor over the weekend. Let's see how it goes! Will update the thread.
I am also planning to get the EGR cleaned, bit would need professional help for that.
My car has run 50k and feel it's the right time for a clean up.
ObsessedByFIAT is online now   (1) Thanks
Old 24th May 2018, 12:53   #79
Welcome buddy. Here's another image showing the exploded view of the air cleaner in your car.
DIY : Cleaning your MAF Sensor for Rs 120-screenshot_20180524124703_01.jpg
Figure No.: 12B579 that's the MAF sensor which plugs into the air filter box unit. You'll see a waterproof connector on the air filter box. That's the MAF sensor unit.
a4anurag is offline   (4) Thanks
Old 24th May 2018, 13:07   #80
panky12345's Avatar
Thanked: 172 Times
Folks. Interesting thread. Can someone please guide me where to locate MAF sensor in Gen-I Honda Amaze diesel.
panky12345 is offline
Old 24th May 2018, 13:32   #81
Thanked: 61,463 Times
If possible I would always try to use a special dedicated MAF cleaning spray. They are designed specifically to clean dirt, grime, grease etc and will evaporate quickly whilst containing no alcohol.
As mentioned before. If the sensors isn't dirty, cleaning isn't going to make any difference. If possible, check for codes with a suitable OBD scanner as a dirty sensor will throw out a code. Often before it becomes noticeable in performance
Jeroen
Jeroen is offline   (1) Thanks
Old 24th May 2018, 13:33   #82
paragsachania's Avatar
Thanked: 27,205 Times
Ideally, the MAF Sensor is always located very close to the Air Filter compartment in all cars.
So there is Air intake hose, followed by Air Filter element inside the Air filter compartment and then the MAF Sensor that will always have an electronic coupler attached to a cylindrical object.
Please refer to the pic from the official review:
DIY : Cleaning your MAF Sensor for Rs 120-20180524-13.31.14.jpg
paragsachania is offline   (7) Thanks
Old 28th May 2018, 10:02   #83
Alright! So armed with the knowledge I got from this thread (and thanks for sharing with everyone!) I got down to clean the MAF sensor on Sunday morning.
Earlier I was experiencing a little hesitation in the cars acceleration and the fuel consumption had also gone up considerably. May even be attributed to the summer season though.
So, the plan was to clean the MAF and see the difference in the car behaves.
MAF sensor in EcoSport Diesel is very easy to remove. Just two screws need to be opened and the disconnect the power supply to the unit and we can slide it out.
Though the sensor itself wasn't too dirty, I thought of cleaning the air filter as well. This turned out to be a major contributor to the car's offlate behaviour. In one word, the air filter was "dusty".
Even with a slight tap, there was a lot of black soot/dust that it was giving out. So took the air filter to a near by puncture repair shop and blew pressurized air. Though I will soon have to get the air filter changed, for another 3-4k kilometres it should be fine.
I could immediately feel a difference the way car rolled post the air filter and MAF cleaning excercise!
Post this, I filled the tank upto auto cut and last 100 odd kilometres is showing around 16 kmpl on the MID. Up from around 14 kmpl.
ObsessedByFIAT is online now   (3) Thanks
Old 21st June 2018, 13:46   #84
itwasntme's Avatar
Thanked: 14,171 Times
My 7 year old 110k km Cruze's MAF sensor is throwing up an error. Symptoms were that the engine would suddenly die out during gear changes, but come back on immediately.
My trusted Chevy workshop has cleaned it and fitted it back and am keeping a close eye on it for now. A new one is 7.5k and not available outside Chevy service! Am superstitious about fitting used parts into my cars so cannot go down the scrapped parts route.
Not that I mind a part failing at 110k km but the cost is prohibitive!
itwasntme is online now
Old 13th July 2018, 16:08   #85
Turrrb0's Avatar
Thanked: 660 Times
Hello all,
I have purchased 99.9% pure IPA (https://www.amazon.in/gp/product/B07...?ie=UTF8&psc=1) and want to do the MAF sensor cleaning. From what I can see, with the way those of you who have carried out this procedure, no body tried to fill the IPA in a spray bottle and used that to spray the MAF sensor down. I was thinking of trying it that way, will that be an effective way to do it, will I cause any harm to the sensor? Or is there any specific reason as to dipping the sensor in a ziploc filled with IPA.
Reg
Turrrb0 is offline   (1) Thanks
Old 10th August 2018, 18:58   #86
lemedico's Avatar
Thanked: 2,353 Times
could anyone please instruct me on how to access the MAF sensor on a VW Polo 2014 petrol? I have a major error code on an OBD scan: code number P0068... Mass air flow sensor and throttle body position related error.
I currently have a FE of around 6-7kmpl
Anyone who's done a cleanup on their VW/SKODA, please link me to a video or webpage with instructions of how to dismantle the MAF sensor
thanks!
lemedico is online now
Old 11th August 2018, 11:19   #87
Turrrb0's Avatar
Thanked: 660 Times
thanks!
The MAF sensor should ideally be in the hose between the air box and the throttle body. You can identify it as a sort of probe with an electrical clip connector going into the hose. Though I don't know exactly where the MAF sensor for the polo is, what I have described should help you figure it out.
PS: To clean the sensor elements. Instead of filling the IPA in a 'Ziploc' bag, I filled the IPA into an old and clean 'Colin' spray bottle and sprayed the sensor until the bottle was empty with the nozzle on the 'stream' setting. It cleaned it up good and is a more economical way of using the IPA. IMHO you don't have to spray the entire bottle, and just half or 2/3rd of it is enough to do the job.
Give the whole thing a wipe in the end while being careful not to touch the sensor elements.
Hope I was of some help to you!
Turrrb0 is offline   (4) Thanks
Old 14th June 2019, 18:30   #88
lemedico's Avatar
Originally Posted by lucifer919 View Post
You don't necessarily need a specific MAF sensor spray/cleaner. There are carburettor/throttle body cleaner sprays you get in the market (ABRO/STP) that can be used for this. It costs about 100/150 INR for a spray can and will last you over the lifetime of your car. I've been using this for the past 5+ years on all my cars.
there are many google pages which say throttle body cleaner sprays should not be used to clean the MAF sensors, but MAF sensor cleaning spray can be used to clean the throttle body.
have you used the throttle body spray to clean your MAF sensor? was it ok and do you recommend it, because MAF sensor cleaning sprays are NOT available anywhere I look, online or offline but throttle body cleaners are easily available. I want to clean the sensor on my Jazz 2009, please advice
Old 19th June 2019, 11:06   #89
Turrrb0's Avatar
Thanked: 660 Times
Go the Isopropyl alcohol way. It is way more cost effective and does a fine job. Make sure to get the maximum concentration of the liquid possible. it's available on Amazon and should be available in your local chemist as well.
Regarding the MAF spray there is one I've seen on amazon but it's imported and costs some Rs. 2600 per can. Not worth it IMO.
Edit: Correction its for Rs. 3200 +
https://www.amazon.in/dp/B000J19XSA/...v_ov_lig_dp_it
Old 8th February 2020, 13:14   #90
..........because MAF sensor cleaning sprays are NOT available anywhere I look, online or offline but throttle body cleaners are easily available. I want to clean the sensor on my Jazz 2009, please advice
MAF sensor cleaner from liquimoly is easily available online on amazon, but is much cheaper when bought direct from LM distributors, for example, the one in bangalore( bharat kumar +91 88674 67625)
Just bought TB cleaner, MAF cleaner and injector cleaner from him.
Happy motoring!
rnkaushal is offline   (2) Thanks
