Old 12th October 2007, 21:06   #1
1self's Avatar
Thanked: 334 Times
Eyelids - DIY - Very Easy
Hey Guys,
Just finished installing body coloured eyelids on my Elantra.
This is the plastic file cover from which i cut the shapes.
This is without the eyelids.
This is with the eyelids...looks so aggressive!! The shape of the grille helps!!
I got the body coloured painting done from the dealer workshop (for free!!) as this colour (Charming Grey) is not readily available elsewhere.
1self is offline   (1) Thanks
Old 12th October 2007, 21:12   #2
Vid6639's Avatar
Thanked: 44,133 Times
The car looks good, but will the plastic lids be able to withstand the headlights heat? They don't look like the normal eyelid plastic.
Vid6639 is offline
Old 12th October 2007, 21:36   #3
theMAG's Avatar
Thanked: 1,821 Times
What did you use to fasten the plastics to the headlights?
theMAG is offline
Old 12th October 2007, 21:42   #4
whicked wheels's Avatar
Thanked: 83 Times
Hey vid it looks good. Hope the plastic can take the heat as moral says,nice idea though. I hope the painter had used plastic primer as basecoat or else the paint might peel off.
whicked wheels is offline
Old 12th October 2007, 21:46   #5
1self's Avatar
Thanked: 334 Times
@ Mag: I used normal double sided tape (3M).
@vid: I used the thickest plastic sheet i could find at the local stationary store (1mm thick).
1self is offline
Old 12th October 2007, 22:15   #6
1self's Avatar
Thanked: 334 Times
A Closeup
i am adding this pic as a close up of the eyelid.
Old 12th October 2007, 22:15   #7
Vid6639's Avatar
The double side tape will melt easily and will be a difficult proposition to clean it. The 1mm plastic also may not last long.
Try out and see if it starts to melt or deform before using it for long duration. Best bet is to remove them at night.
Vid6639 is offline
Old 12th October 2007, 22:18   #8
1self's Avatar
Thanked: 334 Times
@ vid: ok...i will check first...though i used it in the evening today (headlight on for 30mins)...nothing happened....will keep an eye on it though.
1self is offline
Old 12th October 2007, 22:34   #9
Cyrus43's Avatar
Thanked: 230 Times
very creative buddy..car looks very nice
Cyrus43 is offline
Old 12th October 2007, 22:51   #10
jayz's Avatar
Nice job dude looks gorgeous, hope the tape holds on.
jayz is offline
Old 12th October 2007, 23:22   #11
kpzen's Avatar
Thanked: 1,882 Times
Very innovative stuff and perfect design .
Though i'm not sure if it will last long with double side sticker.
kpzen is offline
Old 12th October 2007, 23:26   #12
badboyscad's Avatar
Thanked: 483 Times
a very good diy job indeed..creative too..waiting to hear about long term durability of the eyelids
badboyscad is offline
Old 14th October 2007, 03:07   #13
rohan_fonseca's Avatar
Thanked: 9 Times
1self great job. Please keep us updated how the sticking tape lasts.
rohan_fonseca is offline
Old 14th October 2007, 07:42   #14
1self's Avatar
Thanked: 334 Times
Hey guys!
Used the headlights today for a GOOD two hours...no probs...& the cleaning guy cleaned with water in the morning...(mind you i use dual HID's so there is a LOT more heat)...still no probs.
1self is offline
Old 14th October 2007, 12:37   #15
payam's Avatar
Car looks amazing,where did you get them?in pune?how much did it cost you?are there variety in their color ?
payam is offline
